Vista - script that checks whether a pc is connecting to LAN
Old 10-08-2008   #1 (permalink)
tree leafs
is there a sample script that can check whether a pc is connecting to LAN?
The script needs to be run when the user logs on.
thanks
Old 10-08-2008   #2 (permalink)
Richard Mueller [MVP]
Re: script that checks whether a pc is connecting to LAN
> thanks
The computer will be authenticated (connected) to the domain before the user
logs on. Otherwise the user has logged on locally. There are several ways to
check for a domain (check if the computer has authenticated to a domain),
but all methods I'm aware of involve error trapping and a timeout (maybe 10
seconds) if there is no connection.
=== Method 1 ====
On Error Resume Next
Set objRootDSE = GetObject(LDAP://RootDSE)
If (Err.Number = 0) Then
On Error GoTo 0
Wscript.Echo "Authenticated to domain " &
objRootDSE.Get("defaultNamingContext")
Else
On Error GoTo 0
Wscript.Echo "Not authenticated to domain"
End If
=== Method 2 ====
Set objSysInfo = CreateObject("ADSystemInfo")
On Error GoTo 0
Wscript.Echo "Authenticated to domain " & objSysInfo.DomainDNSName
Else
On Error GoTo 0
End If
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
Old 10-09-2008   #3 (permalink)
tree leafs
Thanks very much.
"Richard Mueller [MVP]" <rlmueller-nospam@xxxxxx> wrote in
message news:Ov1YgQUKJHA.4324@xxxxxx
Quote:
> tree leafs wrote:
>> LAN?
>> thanks
> user logs on. Otherwise the user has logged on locally. There are several
> ways to check for a domain (check if the computer has authenticated to a
> domain), but all methods I'm aware of involve error trapping and a timeout
> (maybe 10 seconds) if there is no connection.
> === Method 1 ====
> On Error GoTo 0
> Else
> On Error GoTo 0
> End If
> === Method 2 ====
> On Error GoTo 0
> Else
> On Error GoTo 0
> End If
> Richard Mueller
Old 10-22-2008   #4 (permalink)
Python
I had an intermittent problem where (on a dialup connection while at the
cottage) I would lose connections to the DNS. I wrote a little GUI which
would execute ipconfig and extract the IP addresses of the internet
connection (my computer, default gateway, DNS) every five seconds, log the
results and display them in the GUI. It uses kixforms (free download) for
the GUI. You can strip out the code and do away with the GUI. Code
follows...
' Name:
' ip.vbs
' Description:
' This script monitors an internet connection. It provides a GUI which
displays the IP '
' address and status for
' o the computer on which the script is running
' o the server assigned as the gateway
' o the server assigned as the primary domain name server
' o the server assigned as the alternate domain name server
' The connections are tested every 5 seconds. Also displayed
' o the number of times each connection has failed
' o the time of the last connection failure
' Results are logged to the file identified in LogFile.
' Notes:
' GUI provided by kixForms version 2.46
' Audit:
' 2008-09-28 jdeg original code
'create an instance of the kixForms system object
Dim System: Set System = CreateObject("KiXtart.System")
'define the form
Dim frmMain: Set frmMain = System.Form()
frmMain.Size = System.Size(409, 214)
frmMain.Text = "Internet Connection Monitor"
frmMain.FormBorderStyle = 2
Dim lblAddress: Set lblAddress = frmMain.Controls.Label
lblAddress.AutoSize = True
lblAddress.Size = System.Size(58, 13)
lblAddress.Text = "IP Address"
lblAddress.Location = System.Point(155, 12)
Dim lblFailed: Set lblFailed = frmMain.Controls.Label
lblFailed.AutoSize = True
lblFailed.Size = System.Size(35, 13)
lblFailed.Text = "Failed"
lblFailed.Location = System.Point(250, 12)
Dim lblLastFailed: Set lblLastFailed = frmMain.Controls.Label
lblLastFailed.AutoSize = True
lblLastFailed.Size = System.Size(58, 13)
lblLastFailed.Text = "Last Failed"
lblLastFailed.Location = System.Point(315, 12)
'My Computer Stats
Dim staMe: Set staMe = frmMain.Controls.Label
staMe.BackColor = System.Color.FromName("Lime")
staMe.Size = System.Size(20, 20)
staMe.BorderStyle = 1
staMe.Location = System.Point(11, 38)
Dim lblMe: Set lblMe = frmMain.Controls.TextBox
lblMe.Size = System.Size(90, 20)
lblMe.Text = "My Computer"
lblMe.Location = System.Point(37, 38)
Dim adrMe: Set adrMe = frmMain.Controls.TextBox
adrMe.Size = System.Size(100, 20)
adrMe.Location = System.Point(133, 38)
Dim totMe: Set totMe = frmMain.Controls.TextBox
totMe.Size = System.Size(61, 20)
totMe.Location = System.Point(239, 38)
totMe.Alignment = 1
Dim lstMe: Set lstMe = frmMain.Controls.TextBox
lstMe.Size = System.Size(72, 20)
lstMe.Location = System.Point(306, 38)
'Gateway Computer Stats
Dim staGateway: Set staGateway = frmMain.Controls.Label
staGateway.BackColor = System.Color.FromName("Lime")
staGateway.Size = System.Size(20, 20)
staGateway.BorderStyle = 1
staGateway.Location = System.Point(11, 68)
Dim lblGateway: Set lblGateway = frmMain.Controls.TextBox
lblGateway.Size = System.Size(90, 20)
lblGateway.Text = "Gateway"
lblGateway.Location = System.Point(37, 68)
Dim adrGateway: Set adrGateway = frmMain.Controls.TextBox
adrGateway.Size = System.Size(100, 20)
adrGateway.Location = System.Point(133, 68)
Dim totGateway: Set totGateway = frmMain.Controls.TextBox
totGateway.Size = System.Size(61, 20)
totGateway.Location = System.Point(239, 68)
totGateway.Alignment = 1
Dim lstGateway: Set lstGateway = frmMain.Controls.TextBox
lstGateway.Size = System.Size(72, 20)
lstGateway.Location = System.Point(306, 68)
'Primary DNS Stats
Dim staPrimary: Set staPrimary = frmMain.Controls.Label
staPrimary.BackColor = System.Color.FromName("Lime")
staPrimary.Size = System.Size(20, 20)
staPrimary.BorderStyle = 1
staPrimary.Location = System.Point(11, 98)
Dim lblPrimary: Set lblPrimary = frmMain.Controls.TextBox
lblPrimary.Size = System.Size(90, 20)
lblPrimary.Text = "Primary DNS"
lblPrimary.Location = System.Point(37, 98)
Dim adrPrimary: Set adrPrimary = frmMain.Controls.TextBox
adrPrimary.Size = System.Size(100, 20)
adrPrimary.Location = System.Point(133, 98)
Dim totPrimary: Set totPrimary = frmMain.Controls.TextBox
totPrimary.Size = System.Size(61, 20)
totPrimary.Location = System.Point(239, 98)
totPrimary.Alignment = 1
Dim lstPrimary: Set lstPrimary = frmMain.Controls.TextBox
lstPrimary.Size = System.Size(72, 20)
lstPrimary.Location = System.Point(306, 98)
'Alternate DNS Stats
Dim staAlternate: Set staAlternate = frmMain.Controls.Label
staAlternate.BackColor = System.Color.FromName("Lime")
staAlternate.Size = System.Size(20, 20)
staAlternate.BorderStyle = 1
staAlternate.Location = System.Point(11, 128)
Dim lblAlternate: Set lblAlternate = frmMain.Controls.TextBox
lblAlternate.Size = System.Size(90, 20)
lblAlternate.Text = "Alternate DNS"
lblAlternate.Location = System.Point(37, 128)
Dim adrAlternate: Set adrAlternate = frmMain.Controls.TextBox
adrAlternate.Size = System.Size(100, 20)
adrAlternate.Location = System.Point(133, 128)
Dim totAlternate: Set totAlternate = frmMain.Controls.TextBox
totAlternate.Size = System.Size(61, 20)
totAlternate.Location = System.Point(239, 128)
totAlternate.Alignment = 1
Dim lstAlternate: Set lstAlternate = frmMain.Controls.TextBox
lstAlternate.Size = System.Size(72, 20)
lstAlternate.Location = System.Point(306, 128)
'Status Bar
Dim StatusBar: Set StatusBar = frmMain.Controls.StatusBar
StatusBar.Size = System.Size(399, 22)
StatusBar.Text = ""
StatusBar.Location = System.Point(0, 156)
StatusBar.Dock = 2
'Timer
Dim Timer1: Set Timer1 = System.Timer()
Timer1.Enabled = True
Timer1.Interval = 5000
Timer1.OnTick = "Timer1_OnTick()"
Dim wso 'windows script shell helper object
Dim fso 'file system helper object
Dim HostName 'the name of the computer on which this script is
running '
Dim LogFile 'the file to log the results to
Dim LogOut 'text stream object for log file output
'create the helper objects
Set wso = CreateObject("Wscript.Shell")
Set fso = CreateObject("Scripting.FileSystemObject")
'get the name of the host computer from the environment variable
HostName = wso.ExpandEnvironmentStrings("%COMPUTERNAME%")
'initialize counters and status displays
MeFail = 0
MeLast = ""
GatewayFail = 0
GatewayLast = ""
PrimaryFail = 0
PrimaryLast = ""
AlternateFail = 0
AlternateLast = ""
'open the log file
LogFile = "c:\ip.log"
set LogOut = fso.OpenTextFile(LogFile,8,true)
'initialize the display and start the timer
Timer1_OnTick
'periodically update the display until the user closes the form
frmMain.Visible = "True"
on error resume next
Do 'While frmMain.Visible
Execute(frmMain.DoEvents)
if err.Number <> 0 then wscript.Quit
Loop
FormClose
Function FormClose()
msgbox "closing"
End Function
'this function handles the timer event
Function Timer1_OnTick ()
'refresh the addresses of all connections
GetAddresses
if adrMe.Text = "n/a" then exit function
'ping the addresses in turn and update the display
If Ping(adrMe.Text) Then
staMe.BackColor = "Lime"
staMe.Tag = True
Else
staMe.BackColor = "Red"
staMe.Tag = False
MeFail = MeFail + 1
MeLast = Time
End If
totMe.Text = MeFail
lstMe.Text = MeLast
LogIt "Me"
If Ping(adrGateway.Text) Then
staGateway.BackColor = "Lime"
staGateway.Tag = True
Else
staGateway.BackColor = "Red"
staGateway.Tag = False
GatewayFail = GatewayFail + 1
GatewayLast = Time
End If
totGateway.Text = GatewayFail
lstGateway.Text = GatewayLast
Logit "Gateway"
If Ping(adrPrimary.Text) Then
staPrimary.BackColor = "Lime"
staPrimary.Tag = True
Else
staPrimary.BackColor = "Red"
staPrimary.Tag = False
PrimaryFail = PrimaryFail + 1
PrimaryLast = Time
End If
totPrimary.Text = PrimaryFail
lstPrimary.Text = PrimaryLast
LogIt "Primary"
If Ping(adrAlternate.Text) Then
staAlternate.BackColor = "Lime"
staAlternate.Tag = True
Else
staAlternate.BackColor = "Red"
staAlternate.Tag = False
AlternateFail = AlternateFail + 1
AlternateLast = Time
End If
totAlternate.Text = AlternateFail
lstAlternate.Text = Alternatelast
LogIt "Alternate"
StatusBar.Text = "Last Update at " & Now()
End Function
'endregion
Function LogIt ( node )
Dim status
Dim address
Execute "status = sta" & node & ".Tag"
Execute "address = adr" & node & ".Text"
LogOut.Write Now & " "
LogOut.Write Left(node&Space(10),10)
LogOut.WriteLine iif(status,"responding","not responding")
End Function
Function iif ( condition , tval , fval )
if condition then iif = tval else iif = fval
End Function
Function GetAddresses ()
Dim exe
Dim result
Dim active
Dim i
Set exe = wso.Exec("ipconfig /all")
Do While exe.Status = 0
WScript.Sleep 100
Loop
result = exe.Stdout.ReadAll
result = Replace(result,vbCr,"")
result = Split(result,vbLf)
active = False
For i = 0 To UBound(result)
line = result(i)
If InStr(line,"IP Address") > 0 Then active = True
If active Then
Select Case True
Case InStr(line,"IP Address") > 0
adrMe.Text = Trim(Split(line,":")(1))
Case InStr(line,"Default Gateway") > 0
adrGateway.text = Trim(Split(line,":")(1))
Case InStr(line,"DNS Servers") > 0
adrPrimary.Text = Trim(Split(line,":")(1))
adrAlternate.Text = Trim(result(i+1))
End Select
End If
Next
if not active then
adrMe.Text = "n/a"
adrGateway.Text = "n/a"
adrPrimary.Text = "n/a"
adrAlternate.Text = "n/a"
end if
End Function
Function Ping ( ipaddress )
Dim PingResults 'collection of instances of Win32_PingStatus class
Dim PingResult 'single instance of Win32_PingStatus class
Set PingResults =
GetObject("winmgmts:{impersonationLevel=impersonate}//" _
& HostName & "/root/cimv2"). ExecQuery("SELECT * FROM
Win32_PingStatus " _
& "WHERE Address = '" + ipaddress + "'")
Ping = False
For Each PingResult In PingResults
If PingResult.StatusCode = 0 Then
Ping = True
End If
Next
End Function
"tree leafs" <treeleafs@xxxxxx> wrote in message
news:eBRG8ifKJHA.740@xxxxxx
Quote:
> Thanks very much.
Quote:
>> tree leafs wrote:
>>> LAN?
>>> thanks
>> timeout
>> === Method 1 ====
>> On Error GoTo 0
>> Else
>> On Error GoTo 0
>> End If
>> === Method 2 ====
>> On Error GoTo 0
>> Else
>> On Error GoTo 0
>> End If
>> Richard Mueller
Quicken does not print checks in Vista 64 Software
checks for messages but nbox not checked. Live Mail
Can one start a script after connecting to a specific wireless network? Vista installation & setup
WLM checks mail whenever network is connected Live Mail
Newsgroup checks for new newsgroups and then loses new news Live Mail
