| | How to save output of echo to a file or omit using echo and save it Hi, I have found a lot of scripts that display messages on the screen, but I failed to find one that would save it instead (effectively we should get rid of echo command completely, I assume). I don't want to use "cScript" command to invoke my script as it's not practical in many cases. Can anyone help. Example: ------------------- On Error Resume Next Set objGroup = GetObject _ ("LDAP://cn=Administrators,CN=BuiltIn,...,dc=uk") objGroup.GetInfo arrMemberOf = objGroup.GetEx("member") WScript.Echo "Members:" For Each strMember in arrMemberOf WScript.echo strMember Next --------------------- Thanks a lot. Kamil |
| | Re: How to save output of echo to a file or omit using echo and save it Kamil wrote: Quote: > > I have found a lot of scripts that display messages on the screen, but > I failed to find one that would save it instead (effectively we should > get rid of echo command completely, I assume). I don't want to use > "cScript" command to invoke my script as it's not practical in many > cases. Can anyone help. Example: > > ------------------- > On Error Resume Next > > Set objGroup = GetObject _ > ("LDAP://cn=Administrators,CN=BuiltIn,...,dc=uk") > objGroup.GetInfo > > arrMemberOf = objGroup.GetEx("member") > > WScript.Echo "Members:" > For Each strMember in arrMemberOf > WScript.echo strMember > Next > --------------------- > redirect the output to a text file. Otherwise you can use the FileSystemObject to write the output to a text file. For example: ========= Option Explicit Dim objGroup, objFSO, strFile, objFile Dim arrMembers, strMember Const ForWriting = 2 Const OpenAsASCII = 0 Const CreateIfNotExist = True ' Specify output file. strFile = "c:\scripts\report.txt" ' Open the file. Set objFSO = CreateObject("Scripting.FileSystemObject") Set objFile = objFSO.OpenTextFile(strFile, _ ForWriting, CreateIfNotExist, OpenAsASCII) ' Bind to the group object. Set objGroup = GetObject("LDAP://cn=Administrators,cn=BuiltIn,dc=MyDomain,dc=com") ' Retrieve member attribute. ' Trap error if there are no members. On Error Resume Next arrMembers = objGroup.GetEx("member") If (Err.Number = 0) Then On Error GoTo 0 ' Enumerate members and write to file. For Each strMember In arrMembers obFile.WriteLine strMember Next End If On Error GoTo 0 ' Clean up. objFile.Close -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| Echo results of script to file | PowerShell | |||
| echo output | PowerShell | |||
| No file open,save, save as | Vista General | |||
| What echo has do with Return value? | PowerShell | |||
| Any Way To Get Rid Of The Echo? | Vista music pictures video | |||
