| Guest | How to print a web page with VBA? With VBA, I do something like the following: Set obIe = CreateObject("InternetExplorer.Application") obIe.navigate (URLaddress) The page loads, and now I want to print the page. I've tried: obIe.print me.print printer.print obIe.document.print and some others. Nothing I've tried works. Does anyone know the correct way to do this? Thank you in advance. |
| Guest | Re: How to print a web page with VBA? I haven't tested this, but I think it should work: obIe.ExecWB 6, 0 You should also make sure the page is fully loaded before calling it: Do Until obIe.ReadyState = 4 Loop Quote: > With VBA, I do something like the following: > > Set obIe = CreateObject("InternetExplorer.Application") > obIe.navigate (URLaddress) > > The page loads, and now I want to print the page. > > I've tried: > obIe.print > me.print > printer.print > obIe.document.print > > and some others. Nothing I've tried works. Does anyone know the > correct way to do this? > > Thank you in advance. |
| Guest | RE: How to print a web page with VBA? Hi, here is a VBScript (tested) that print a Web page. I think it will also work in VBA. Link: http://www.scriptbox.at.tt/index.php...age.vbs&list=1 alt. Link: http://scriptbox.boris-toll.at/index...age.vbs&list=1 "Dudely" wrote: Quote: > With VBA, I do something like the following: > > Set obIe = CreateObject("InternetExplorer.Application") > obIe.navigate (URLaddress) > > The page loads, and now I want to print the page. > > I've tried: > obIe.print > me.print > printer.print > obIe.document.print > > and some others. Nothing I've tried works. Does anyone know the > correct way to do this? > > Thank you in advance. > |
| Guest | Re: How to print a web page with VBA? Quote: > > here is a VBScript (tested) that print a Web page. > > I think it will also work in VBA. > the same code I already posted. The code, so people don't have to track it down: On Error Resume Next Const OLECMDID_PRINT = 6 Const OLECMDEXECOPT_DONTPROMPTUSER = 2 Const PRINT_WAITFORCOMPLETION = 2 Dim oIExplorer : Set oIExplorer = CreateObject("InternetExplorer.Application") oIExplorer.Navigate "http://www.scriptbox.at.tt/" oIExplorer.Visible = 1 Do while oIExplorer.ReadyState <> 4 wscript.sleep 1000 Loop oIExplorer.ExecWB OLECMDID_PRINT, OLECMDEXECOPT_DONTPROMPTUSER -------------- Or for anyone who wants to get the actual file, the real download link is here: http://www.boris-toll.at/scriptbox/d...d%20print%20a% 20Web%20Page.vbs&filename=Open%20and%20print%20a%20Web%20Page.vbs |
| Guest | Re: How to print a web page with VBA? This doccumentation of ExecWB might be useful to people. The parameter options are not easy to find. ExecWB Method object.ExecWB nCmdID, nCmdExecOpt, [pvaIn], [pvaOut] object Required. An object expression that evaluates to an object in the Applies To list. nCmdID Required. A long integer that represents the identifier of the command to execute. nCmdExecOpt Required. A long integer that represents the options set for executing the command. pvaIn Optional. A variant used for specifying command input arguments. pvaOut Optional. A variant used for specifying command output arguments ______________ first parameter - nCmdID options: ______________ OLECMDID_OPEN = 1, OLECMDID_NEW = 2, OLECMDID_SAVE = 3, OLECMDID_SAVEAS = 4, OLECMDID_SAVECOPYAS = 5, OLECMDID_PRINT = 6, OLECMDID_PRINTPREVIEW = 7, OLECMDID_PAGESETUP = 8, OLECMDID_SPELL = 9, OLECMDID_PROPERTIES = 10, OLECMDID_CUT = 11, OLECMDID_COPY = 12, OLECMDID_PASTE = 13, OLECMDID_PASTESPECIAL = 14, OLECMDID_UNDO = 15, OLECMDID_REDO = 16, OLECMDID_SELECTALL = 17, OLECMDID_CLEARSELECTION = 18, OLECMDID_ZOOM = 19, OLECMDID_GETZOOMRANGE = 20 OLECMDID_UPDATECOMMANDS = 21 OLECMDID_REFRESH = 22 OLECMDID_STOP = 23 OLECMDID_HIDETOOLBARS = 24 OLECMDID_SETPROGRESSMAX = 25 OLECMDID_SETPROGRESSPOS = 26 OLECMDID_SETPROGRESSTEXT = 27 OLECMDID_SETTITLE = 28 OLECMDID_SETDOWNLOADSTATE = 29 OLECMDID_STOPDOWNLOAD = 30 } OLECMDID; Elements OLECMDID_OPEN File menu, Open command OLECMDID_NEW File menu, New command OLECMDID_SAVE File menu, Save command OLECMDID_SAVEAS File menu, Save As command OLECMDID_SAVECOPYAS File menu, Save Copy As command OLECMDID_PRINT File menu, Print command OLECMDID_PRINTPREVIEW File menu, Print Preview command OLECMDID_PAGESETUP File menu, Page Setup command OLECMDID_SPELL Tools menu, Spelling command OLECMDID_PROPERTIES File menu, Properties command OLECMDID_CUT Edit menu, Cut command OLECMDID_COPY Edit menu, Copy command OLECMDID_PASTE Edit menu, Paste command OLECMDID_PASTESPECIAL Edit menu, Paste Special command OLECMDID_UNDO Edit menu, Undo command OLECMDID_REDO Edit menu, Redo command OLECMDID_SELECTALL Edit menu, Select All command OLECMDID_CLEARSELECTION Edit menu, Clear command OLECMDID_ZOOM View menu, Zoom command (see below for details) OLECMDID_GETZOOMRANGE Retrieves zoom range applicable to View Zoom. (See below for details.) OLECMDID_UPDATECOMMANDS Informs the receiver, usually a frame, of state changes. The receiver can then query the status of the commands whenever convenient. OLECMDID_REFRESH Asks the receiver to refresh its display. Implemented by the document/object. OLECMDID_STOP Stops all current processing. Implemented by the document/object. OLECMDID_HIDETOOLBARS View Menu, Toolbars command. Implemented by the document/object to hide its toolbars. OLECMDID_SETPROGRESSMAX Sets the maximum value of a progress indicator if one is owned by the receiving object, usually a frame. The minimum value is always zero. OLECMDID_SETPROGRESSPOS Sets the current value of a progress indicator if one is owned by the receiving object, usually a frame. OLECMDID_SETPROGRESSTEXT Sets the text contained in a progress indicator if one is owned by the receiving object, usually a frame. If the receiver currently has no progress indicator, this text should be displayed in the status bar (if one exists) as with IOleInPlaceFrame::SetStatusText. OLECMDID_SETTITLE Sets the title bar text of the receiving object, usually a frame. OLECMDID_SETDOWNLOADSTATE Called by the object when downloading state changes. Takes a VT_BOOL parameter, which is TRUE if the object is downloading data and FALSE if it not. Primarily implemented by the frame. OLECMDID_STOPDOWNLOAD Stops the download when executed. Typically, this command is propagated to all contained objects. When queried, sets MSOCMDF_ENABLED. Implemented by the document/object. ____________________ second parameter - nCmdExecOpt options: ____________________ OLECMDEXECOPT_DODEFAULT = 0, OLECMDEXECOPT_PROMPTUSER = 1, LECMDEXECOPT_DONTPROMPTUSER = 2, OLECMDEXECOPT_SHOWHELP = 3 OLECMDEXECOPT_DODEFAULT Prompt the user for input or not, whichever is the default behavior. OLECMDEXECOPT_PROMPTUSER Execute the command after obtaining user input. OLECMDEXECOPT_DONTPROMPTUSER Execute the command without prompting the user. For example, clicking the Print toolbar button causes a document to be immediately printed without user input. OLECMDEXECOPT_SHOWHELP Show help for the corresponding command, but do not execute |
| | #6 (permalink) |
| Guest | Re: How to print a web page with VBA? Oh wow. Is that really the VBA way to do it? I've never heard of ExecWB (which means nothing, but) how does one know where to find or look for something like that in the first place? Thank you very very much! I'll give it a try. On Oct 10, 7:19*am, "mayayana" <mayaXXy...@xxxxxx> wrote: Quote: > This doccumentation of ExecWB might be useful to people. > The parameter options are not easy to find. > > ExecWB Method > > object.ExecWB nCmdID, nCmdExecOpt, [pvaIn], [pvaOut] > > object Required. An object expression that evaluates to an object in the > Applies To list. > nCmdID Required. A long integer that represents the identifier of the > command to execute. > nCmdExecOpt Required. A long integer that represents the options set for > executing the command. > pvaIn Optional. A variant used for specifying command input arguments. > pvaOut Optional. A variant used for specifying command output arguments > > ______________ > first parameter - nCmdID options: > ______________ > > * * *OLECMDID_OPEN * * * * * * *= 1, > * * *OLECMDID_NEW * * * * * * * = 2, > * * *OLECMDID_SAVE * * * * * * *= 3, > * * *OLECMDID_SAVEAS * * * * * *= 4, > * * *OLECMDID_SAVECOPYAS * * * *= 5, > * * *OLECMDID_PRINT * * * * * * = 6, > * * *OLECMDID_PRINTPREVIEW * * *= 7, > * * *OLECMDID_PAGESETUP * * * * = 8, > * * *OLECMDID_SPELL * * * * * * = 9, > * * *OLECMDID_PROPERTIES * * * *= 10, > * * *OLECMDID_CUT * * * * * * * = 11, > * * *OLECMDID_COPY * * * * * * *= 12, > * * *OLECMDID_PASTE * * * * * * = 13, > * * *OLECMDID_PASTESPECIAL * * *= 14, > * * *OLECMDID_UNDO * * * * * * *= 15, > * * *OLECMDID_REDO * * * * * * *= 16, > * * *OLECMDID_SELECTALL * * * * = 17, > * * *OLECMDID_CLEARSELECTION * *= 18, > * * *OLECMDID_ZOOM * * * * * * *= 19, > * * *OLECMDID_GETZOOMRANGE * * *= 20 > * * *OLECMDID_UPDATECOMMANDS * *= 21 > * * *OLECMDID_REFRESH * * * * * = 22 > * * *OLECMDID_STOP * * * * * * *= 23 > * * *OLECMDID_HIDETOOLBARS * * *= 24 > * * *OLECMDID_SETPROGRESSMAX * *= 25 > * * *OLECMDID_SETPROGRESSPOS * *= 26 > * * *OLECMDID_SETPROGRESSTEXT * = 27 > * * *OLECMDID_SETTITLE * * * * *= 28 > * * *OLECMDID_SETDOWNLOADSTATE *= 29 > * * *OLECMDID_STOPDOWNLOAD * * *= 30 > > } OLECMDID; > > Elements > OLECMDID_OPEN > File menu, Open command > OLECMDID_NEW > File menu, New command > OLECMDID_SAVE > File menu, Save command > OLECMDID_SAVEAS > File menu, Save As command > OLECMDID_SAVECOPYAS > File menu, Save Copy As command > OLECMDID_PRINT > File menu, Print command > OLECMDID_PRINTPREVIEW > File menu, Print Preview command > OLECMDID_PAGESETUP > File menu, Page Setup command > OLECMDID_SPELL > Tools menu, Spelling command > OLECMDID_PROPERTIES > File menu, Properties command > OLECMDID_CUT > Edit menu, Cut command > OLECMDID_COPY > Edit menu, Copy command > OLECMDID_PASTE > Edit menu, Paste command > OLECMDID_PASTESPECIAL > Edit menu, Paste Special command > OLECMDID_UNDO > Edit menu, Undo command > OLECMDID_REDO > Edit menu, Redo command > OLECMDID_SELECTALL > Edit menu, Select All command > OLECMDID_CLEARSELECTION > Edit menu, Clear command > OLECMDID_ZOOM > View menu, Zoom command (see below for details) > OLECMDID_GETZOOMRANGE > Retrieves zoom range applicable to View Zoom. (See below for details.) > OLECMDID_UPDATECOMMANDS > Informs the receiver, usually a frame, of state changes. The receiver can > then query the status of the commands whenever convenient. > OLECMDID_REFRESH > Asks the receiver to refresh its display. Implemented by the > document/object. > OLECMDID_STOP > Stops all current processing. Implemented by the document/object. > OLECMDID_HIDETOOLBARS > View Menu, Toolbars command. Implemented by the document/object to hide its > toolbars. > OLECMDID_SETPROGRESSMAX > Sets the maximum value of a progress indicator if one is owned by the > receiving object, usually a frame. The minimum value is always zero. > OLECMDID_SETPROGRESSPOS > Sets the current value of a progress indicator if one is owned by the > receiving object, usually a frame. > OLECMDID_SETPROGRESSTEXT > Sets the text contained in a progress indicator if one is owned by the > receiving object, usually a frame. If the receiver currently has no progress > indicator, this text should be displayed in the status bar (if one exists) > as with IOleInPlaceFrame::SetStatusText. > OLECMDID_SETTITLE > Sets the title bar text of the receiving object, usually a frame. > OLECMDID_SETDOWNLOADSTATE > Called by the object when downloading state changes. Takes a VT_BOOL > parameter, which is TRUE if the object is downloading data and FALSE if it > not. Primarily implemented by the frame. > OLECMDID_STOPDOWNLOAD > Stops the download when executed. Typically, this command is propagated to > all contained objects. When queried, sets MSOCMDF_ENABLED. Implemented by > the document/object. > > ____________________ > second parameter - *nCmdExecOpt options: > ____________________ > > * * OLECMDEXECOPT_DODEFAULT * * * *= 0, > * * OLECMDEXECOPT_PROMPTUSER * * * = 1, > * * LECMDEXECOPT_DONTPROMPTUSER * *= 2, > * * OLECMDEXECOPT_SHOWHELP * * * * = 3 > > OLECMDEXECOPT_DODEFAULT > Prompt the user for input or not, whichever is the default behavior. > OLECMDEXECOPT_PROMPTUSER > Execute the command after obtaining user input. > OLECMDEXECOPT_DONTPROMPTUSER > Execute the command without prompting the user. For example, clicking the > Print toolbar button causes a document to be immediately printed without > user input. > OLECMDEXECOPT_SHOWHELP > Show help for the corresponding command, but do not execute |
| | #7 (permalink) |
| Guest | Re: How to print a web page with VBA? On Oct 9, 9:55*pm, "mayayana" <mayaXXy...@xxxxxx> wrote: Quote: > I haven't tested this, but I think it should work: > > obIe.ExecWB 6, 0 > > * *You should also make sure the page is fully loaded > before calling it: > > *Do Until obIe.ReadyState = 4 > *Loop > > > Quote: > > With VBA, I do something like the following: Quote: > > Set obIe = CreateObject("InternetExplorer.Application") > > obIe.navigate (URLaddress) Quote: > > The page loads, and now I want to print the page. Quote: > > I've tried: > > obIe.print > > me.print > > printer.print > > obIe.document.print Quote: > > and some others. *Nothing I've tried works. *Does anyone know the > > correct way to do this? Quote: > > Thank you in advance.- Hide quoted text - > - Show quoted text - a sleep 5000. It may have to do with the fact that I'm using the Click and Onclick methods (when I posted, I simplified so as not to confuse the real issue of needing to print), I really don't know and don't care about that at the moment, I do know the page is fully loaded, because I'm stepping through it and I don't move on until the page is done. The real issue: Your code works! Well, partially. It prints the first page, but not the second. There are only 2 pages. The second page is all images. For my purposes it's not absolutely critical that I get the second page, however it would be nice. Any ideas why it stops after the first page? In fact, I now notice that on the printed page it says "Page 1 of 1", so it doesn't even recognize that there's more than one page. Or perhaps 1 very long page? Thank you again |
| | #8 (permalink) |
| Guest | Re: How to print a web page with VBA? > Oh wow. Is that really the VBA way to do it? I've never heard of ExecWB (which means nothing, but) how does one know where to find or look for something like that in the first place? Quote: > control used in VB (which is also really just IE without the window frame "chrome"). It's not so easy to find out this stuff. That's why I posted the detailed documentation. IE has a fairly extensive object model. And the IE DOM for webpage scripting is far bigger. So it's hard to research it without having a local copy of the MSDN documentation. (The online MSDN system is a mess, full of dead links and bloat. When looking for one particular item I always start with Google. When you need to find a lot of info., like documentation of all IE object properties and methods, the spread out disarray of MSDN online makes that virtually impossible.) |
| | #9 (permalink) |
| Guest | Re: How to print a web page with VBA? Quote: > a sleep 5000. Quote: > I usually use it with WScript.Sleep 100 in the loop, but it should work either way. Quote: > first page, but not the second. There are only 2 pages. The second page is all images. Quote: > one navigates to. If there's a page 2, as with many news articles that run multiple pages, that's just a link on the first page. You'd have to navigate to that separately and load it as a second document. |
| Printmaster 18 will only print 1 page | Drivers | |||
| trying to print webpages - only 1 page will print | Vista General | |||
| Vista last page does not print -with print server | Vista print fax & scan | |||
| Web Page Will Not Print | Vista print fax & scan | |||
| print and page size | Vista performance & maintenance | |||
