Vista - Reset IE7 Settings
Old 10-10-2008   #1 (permalink)
Steven Andrews
Reset IE7 Settings
Hello all
I'm looking for a vbscript / command line that is able to reset IE 7
Settings.
Target OS is XP Pro SP3.
The GUI method: Internet Explorer 7 / Tools / Internet options /
Advanced / Reset.
Restricted user or admin permissons are not an issue (IE: If vbscript
must run as local admin that is Ok - I suspect it will be necessary).
I found nothing useful on google. (That may just be my googling skills
are lacking!)
Steve.
How can I reset external monitor settings? Vista hardware & devices
Update Settings Spontaneously Reset Vista General
Power Settings reset problem Vista performance & maintenance
factory reset/default settings Vista performance & maintenance
mail settings get reset automatically Vista mail
