Vista Tutorial - How to terminate a Win32 process without using "winmgmts:"
Old 10-10-2008   #1 (permalink)
Smoreno
Guest
Hello,
I use the following script to terminate the process listed in it. As the
server gets loaded killing the process (terminate()) takes longer as the load
increases. The WMI service takes longer find and kill the process.
Other than calling WMI, is there another way to kill the process via script
that doesn't take a long time?
strComputer = "."
Set objWMIService = GetObject("winmgmts:" _
& "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2")
Set colProcessList = objWMIService.ExecQuery _
("Select * from Win32_Process Where Name = 'pcsws.exe'")
For Each objProcess in colProcessList
colProperties = objProcess.GetOwner(strNameOfUser)
If strusername = strnameofuser Then
objProcess.Terminate()
Else
End If
Next
Smoreno - ADOT
Old 10-10-2008   #2 (permalink)
James Whitlow
Guest
Re: How to terminate a Win32 process without using "winmgmts:"
"Smoreno" <Smoreno@xxxxxx> wrote in message
news:BC3F0888-3984-455B-8752-69DEEF321B11@xxxxxx
Quote:
> Hello,
> load
> script
You might consider shelling out to Taskkill:
http://technet.microsoft.com/en-us/l.../bb491009.aspx
I don't know if it is going to be faster or not, but it does allow you
to filter by username.
Old 10-10-2008   #3 (permalink)
Smoreno
Guest
Hello,
how do you determine the process id for the app to kill? This is a Citrix
environment so I need to make sure that the only the process ID for a
specific user is killed.
Don't we have to use WMI to determine the process ID for that?
Smoreno - ADOT
Quote:
> > Hello,
> > load
> > script
Old 10-10-2008   #4 (permalink)
James Whitlow
Guest
Quote:
Quote:
>> > Hello,
>> > the
>> > the
>> > load
>> > script
>> you
> Hello,
You can use 'tasklist.exe' to list tasks with associated PID. However,
'taskkill.exe' allows you to specify a username, so you should be able to
isolate it's task killing to a specific user. I have not used 'taskkill.exe'
before, I was just offering it up as an alternative to WMI.
Can you offer the group additional details on what you are trying to
accomplish? We might be able to offer you other options if we better
understand what you are trying to accomplish.
Old 10-11-2008   #5 (permalink)
mr_unreliable
Guest
hi Smoreno,
In addition to wmi and the previously mentioned TaskKill,
I suggest taking a look at sysInternals "Process Explorer":
http://technet.microsoft.com/en-us/s.../bb896653.aspx
The sysInternals group was previously run by Mark Russinovich,
but has since been taken over by microsoft (as you can see by
the url). The Process Explorer utility will tell you everything
you ever wanted to know about your running processes, and more
to the point will allow you to kill a process (either from the
main menu, or a context menu). However, I can't say whether
it will be any faster than wmi, except that M.R. is one clever
guy and if there is a faster way -- he knows it.
The Process Explorer utility is not scriptable, other than via
appactivate and sendkeys. However I would strongly advise against
sending keys (ever!), and just using the gui provided.
If you happen to be courageous enough, or foolhardy enough to
call api's from script, then that is probably the "fastest way"
to kill a process. There are plenty of code samples available
to show how to do it. In short, you "walk-the-process-list"
(there are different ways to do this, depending on the system
you are using). You walk-the-process-list to get the process ID
of the process you are looking to terminate. Then to terminate
the process you use OpenProcess to open the process for termination,
then you use TerminateProcess api. WMI is nothing more than a
scriptable interface to this sort of code. Any delays you are
seeing may be due to the fact that it is not so simple to terminate
a process. There is a lot of "checking" to do (looking for child
threads, child processes, de-allocating system resources, freeing
dll's, etc). There is a "laundry list" to things that must be done
to properly terminate a process, and that may be taking time.
cheers, jw
____________________________________________________________
You got questions? WE GOT ANSWERS!!! ..(but, no guarantee
the answers will be applicable to the questions)
"This application has requested the Runtime to terminate it in an unusual way." Vista performance & maintenance
"X is not a valid Win32 application" Error on EVERY executable Vista account administration
How to terminate a "For Each" statement VB Script
"this application has requested the runtime to terminate in an unusual way" Software
"*.pps is not a valid Win32 application" error message in Windows Vista installation & setup
