Vista - Finding 16-bit applications / MS-DOS
Old 10-15-2008   #1 (permalink)
Jakob
Hi!
I am looking for scripted way to find out which .exe files of a system
are 16-bit applications.
Does anybody have an idea which methode i could use?
Thanks!
Jakob
Old 10-15-2008   #2 (permalink)
Pegasus \(MVP\)
Re: Finding 16-bit applications / MS-DOS
"Jakob" <jakob.hager@xxxxxx> wrote in message
news:e1c14a3d-0ccd-4562-968c-f37820182e40@xxxxxx
Quote:
> Hi!
> Thanks!
> Jakob
You could run this batch file:
@echo off
set target=c:\Program Files\My Application
if exist c:\DOS.txt del c:\DOS.txt
for %%a in ("%target%\*.exe") do filever "%%a" | find /i " DOS " >>
c:\DOS.txt
notepad c:\DOS.txt
You can get filever.exe from here:
http://www.microsoft.com/downloads/d...displaylang=en
I'm finding for.. Software
finding files Vista file management
Several applications are trying to access the internet to specific ip address 10.0.0.138 & 224.0.0.2, while ARE NOT internet applications! ref/eDN3072784783 Vista General
Finding files Vista file management
finding the iso for rc1 Vista General
