Vista - Need help with script
Old 10-17-2008   #1 (permalink)
VascoSputs
Dear All,
I have been tasked with creating a script that will rename computers on my
network. The script should be able to do the following.
Rename the computer name to the serial number of the computer
Change the computer description to the username of the logged on user.
I ran this script found on the internet for test purposes
This code renames a computer in its domain and on the computer itself.
' This script works only against Windows XP and Windows Server 2003
computers.
' From the book "Windows Server Cookbook" by Robbie Allen
' Publisher: O'Reilly Media
' ISBN: 0-596-00633-0
' Book web site: http://rallenhome.com/books/winsckbk/code.html
' ------ SCRIPT CONFIGURATION ------
strComputer = "<ComputerName>" ' e.g. joe-xp
strNewComputer = "<NewComputerName>" ' e.g. joe-pc
strDomainUser = "<DomainUserUPN>" ' e.g. administrator@xxxxxx
strDomainPasswd = "<DomainUserPasswd>"
strLocalUser = "<ComputerAdminUser>" ' e.g. joe-xp\administrator
strLocalPasswd = "<ComputerAdminPasswd>"
' ------ END CONFIGURATION ---------
' Connect to Computer
set objWMILocator = CreateObject("WbemScripting.SWbemLocator")
objWMILocator.Security_.AuthenticationLevel = 6
set objWMIComp = objWMILocator.ConnectServer(strComputer, _
"root\cimv2", _
strLocalUser, _
strLocalPasswd)
set objWMICompSys = objWMIComp.Get("Win32_ComputerSystem.Name='" & _
strComputer & "'")
' Rename Computer
intRC = objWMICompSys.Rename(strNewComputer, _
strDomainPasswd, _
strDomainUser)
if intRC <> 0 then
WScript.Echo "Rename failed with error: " & intRC
else
WScript.Echo "Successfully renamed " & strComputer & " to " &
strNewComputer
end if
WScript.Echo "Rebooting system..."
Set colOS = objWMIComp.InstancesOf("Win32_OperatingSystem")
for each objOS in colOS
objOS.Reboot()
next
Plugging in all parameters as needed but it returns the following error
SWbemLocator RPC server is unavailable.
What should I do.
Need assistance please
Thanks
VascoSputs
EdemObong
Old 10-17-2008   #2 (permalink)
Al Dunbar
Re: Need help with script
Please don't multi-post.
/Al
"VascoSputs" <VascoSputs@xxxxxx> wrote in message
news:2807B13D-C343-4D30-B782-0B1F670DB31C@xxxxxx
Quote:
> Dear All,
> computers.
> "root\cimv2", _
> strLocalUser, _
> strLocalPasswd)
> strComputer & "'")
> ' Rename Computer
> strDomainPasswd, _
> strDomainUser)
> if intRC <> 0 then
> else
> strNewComputer
> end if
> objOS.Reboot()
> next
> What should I do.
> Thanks
> VascoSputs
> EdemObong
Logon Script Causing Laptops To Hang - Problems in script? VB Script
problem passing args to script 'There is no script engine for file extenstion' VB Script
Include another script, keep variables in included script? PowerShell
Script file has 'OS Handle' error when run from script PowerShell
Can you drag-n-drop a file on top of a PS script to run the script? PowerShell
