Vista - Need help with a vbs script
Old 10-20-2008   #1 (permalink)
Clayton Sutton
Hello everyone,
I am running MSDE 2000 to backup a Microsoft Office SharePoint Server 2007.
Blow is the .vbs script that I am using to back the server up.
Can someone help me edit the script to do a restore?
What the script does is backup the data each day and place it in a folder by
the name of the date. for example, I want to restor the folder called
"D:\20081017". Within that folder are the following files -
ADMINBackup.bak, ITBackup.bak, LCBackup.bak, SPBackup.bat, SPSCBackup.bak
and spbrtoc.xml.
Here is the script:
' New sites need to be added to this script or they will NOT be backedup!
Option Explicit
Dim objFSOim dNow, yy, mm, ddim NewFolderim ws
Set objFSO = CreateObject("Scripting.FileSystemObject")
dNow = Now
yy = Year(dNow)
mm = Right("00" & Month(dNow), 2)
dd = Right("00" & Day(dNow), 2)
NewFolder = "D:\SharePointBackup\" & yy & mm & dd
'Create the folder
objFSO.CreateFolder NewFolder
Set ws=CreateObject("WScript.Shell")
' Site Backups
ws.Run "stsadm -o backup -url http://wtamusp01:44327/sites/it -filename " &
NewFolder & "\ITBackup.bak"
ws.Run "stsadm -o backup -url http://wtamusp01:44327/sites/lc -filename " &
NewFolder & "\LCBackup.bak"
ws.Run "stsadm -o backup -url http://wtamusp01:44327/sites/sp -filename " &
NewFolder & "\SPBackup.bak"
ws.Run "stsadm -o backup -url http://wtamusp01:44327/sites/spsc -filename "
& NewFolder & "\SPSCBackup.bak"
ws.Run "stsadm -o backup -url http://wtamusp01:44327/ssp/admin -filename " &
NewFolder & "\ADMINBackup.bak"
' Full Server Farm Backup
ws.Run "stsadm -o backup -directory " & NewFolder & " -backupmethod full"
WScript.Quit
TIA,
Clayton
Logon Script Causing Laptops To Hang - Problems in script? VB Script
problem passing args to script 'There is no script engine for file extenstion' VB Script
Include another script, keep variables in included script? PowerShell
Script file has 'OS Handle' error when run from script PowerShell
Can you drag-n-drop a file on top of a PS script to run the script? PowerShell
