Vista - VBS script question
Old 10-20-2008   #1 (permalink)
rogv
VBS script question
I have a VBS script and it looks for a file in local drive:
LocFolder = "C:\myfiles"
It works fine.
I am trying to make adjustments so it can also read from a mapped
drive.
Any hints. thanks
Old 10-20-2008   #2 (permalink)
Pegasus \(MVP\)
Re: VB script question
"rogv" <rvaedex23@xxxxxx> wrote in message
news:c31ecefe-2708-4205-a179-565e2b109afd@xxxxxx
> It works fine.
> drive.
> Any hints. thanks
Have you tried UNC coding?
LocFolder = "\\RemotePC\ShareName\FolderName"
Old 10-20-2008   #3 (permalink)
rogv
On Oct 20, 4:15*pm, "Pegasus \(MVP\)" <I....@xxxxxx> wrote:
Quote:
> "rogv" <rvaede...@xxxxxx> wrote in message
Quote:
> > It works fine.
> > drive.
> > Any hints. *thanks
Yes, It says it cannot find path. For local folders it works OK.
Old 10-20-2008   #4 (permalink)
Pegasus \(MVP\)
news:d95a8d04-98ef-43c2-b5be-4ab68149fd86@xxxxxx
Quote:
> > It works fine.
> > drive.
> > Any hints. thanks
This means that you have a permission issue or a error in the name. Try this
humble command from a Command Prompt:
dir "\\RemotePC\ShareName\FolderName"
If this works and your script does not work then you should post your
script.
Old 10-21-2008   #5 (permalink)
rogv
Quote:
Quote:
Quote:
Quote:
> > > It works fine.
Quote:
> > > drive.
> > > Any hints. thanks
> Yes, It says it cannot find path. *For local folders it works OK.
> script.- Hide quoted text -
> - Show quoted text -
Does the folder has to be shared for it to work?
Old 10-22-2008   #6 (permalink)
Python
Re: VBS script question
If the drive is mapped then it can be treated as a local drive. You
shouldn't have to modify the code at all. I agree that it may be a
permission problem. If you are at a command prompt, can you "type" the file?
For example, let's assume that the mapped drive is "Z:" and the file you are
trying to read is
z:\myfolder\myfile.txt
Let us also assume that you are currently at the root of the C drive. What
happens when you do the following"
C:\>type z:\myfolder\myfile.txt
If you can list the file from the command prompt then your script should
work as well (but because I haven't seen your script I will reserve
judgement). What error do you get when you try to read from the mapped
drive?
Old 10-22-2008   #7 (permalink)
gimme_this_gimme_that
Don't forget that you need to escape spaces, colons and back slashes.
All I have handy is this unescape VBA method - but you get the
idea ...
Function unescape(s As String) As String
s = Application.Substitute(s, "%20", " ")
s = Application.Substitute(s, "%3A", ":")
s = Application.Substitute(s, "%5C", "\")
unescape = s
End Function
Incidentally VBScript has an escape function built in. WScript I
haven't checked.
question on: HTA and format to include external script file VB Script
vbs script question VB Script
Question - flushing out powershell.exe when existing a script PowerShell
Newbie question - Is there a script/command to do a backup of a di PowerShell
Newbie Question: Here-Script with PowerShell PowerShell
