Vista - Need help with powerpoint automation...
Old 10-22-2008   #1 (permalink)
reinhold.fiedler
the script found at msdn scripting guys does end with an error if the
option "END WITH BLACK SLIDE" is "NOT" selected in the poperpoint
option menue. can anybody help me?
tested with pp2003 & pp2007
code http://www.microsoft.com/technet/scr.../ofppvb01.mspx
Const ppAdvanceOnTime = 2
Const ppShowTypeKiosk = 3
Const ppSlideShowDone = 5
Set objPPT = CreateObject("PowerPoint.Application")
objPPT.Visible = True
Set objPresentation = objPPT.Presentations.Open("C:\test.ppt")
objPresentation.Slides.Range.SlideShowTransition.AdvanceTime = 2
objPresentation.Slides.Range.SlideShowTransition.AdvanceOnTime = TRUE
objPresentation.SlideShowSettings.AdvanceMode = ppAdvanceOnTime
objPresentation.SlideShowSettings.ShowType = ppShowTypeKiosk
objPresentation.SlideShowSettings.StartingSlide = 1
objPresentation.SlideShowSettings.EndingSlide =
objPresentation.Slides.Count
Set objSlideShow = objPresentation.SlideShowSettings.Run.View
Do Until objSlideShow.State = ppSlideShowDone
If err Then
wscript.echo "Error number " & err & " : " & Err.description
Exit Do
End If
wscript.sleep 20
Loop
after this line an error occurs
Error number -2147467259 : SlideShowView.State : Object does not
exist.
with the option "END WITH BLACK SLIDE" set there ist no problem at
all!!
please help!
Old 10-23-2008   #2 (permalink)
Tom Lavedas
Re: Need help with powerpoint automation...
On Oct 22, 9:47*pm, "reinhold.fied...@xxxxxx"
> codehttp://www.microsoft.com/technet/scriptcenter/scripts/office/ppt/ofpp....
> * * * * *If err Then
> * * * * * * wscript.echo "Error number " & err & " : " & Err.description
> * * * * * * Exit Do
> * * * * * * * * End If
> * * * * * * * *wscript.sleep 20
> Loop
> exist.
> all!!
> please help!
It would seem to me that there needs to be an "On Error Resume Next"
statement in there for this to work correctly, something like this ...
If err.Number <> 0 Then
' And I don't think this next line is really necessary (or useful
except for debugging)
wscript.echo "Error number " & err.Number & " : " &
Err.description
Exit Do
End If
wscript.sleep 20
Loop
Now it won't show an error, regardless of how the presentation is set
up. The error still exists, but is handled by the procedure. Since
it's not fatal, it's just ignored.
(My other additions are only cosmetic, but I think they make the code
more understandable - easing later maintenance.)
Tom Lavedas
http://members.cox.net/tglbatch/wsh/
Excel does not die using automation .NET General
Powershell OLE Automation? PowerShell
Automation error 440 Vista General
Excel automation PowerShell
