| | Help me to populate MSDatagrid Hi. This sample whork fine in VBScript but dont is the best pratice MSChart1.ColumnCount = 4 MSChart1.RowCount = 8 For Column = 1 To 4 For Row = 1 To 8 MSChart1.Column = Column MSChart1.Row = Row MSChart1.Data = Row * 100 Next Next This sample dont whork. This sample (best pratice) whork fine in VBasic V6, but in VBScript the MSchart dont change anithing and dont whork. I think the problem is in the assignation MSChart1.ChartData = DF. Wher is the problem? Please hel me. ReDim DF(8, 4) MSChart1.ColumnCount = 8 MSChart1.RowCount = 4 For Column = 0 To 4 For Row = 0 To 4 DF(Row, Column) = Row * 100 Next Next MSChart1.ChartData = DF H. |
| How to populate MSChart? | VB Script | |||
| address bar won't populate contacts | Vista mail | |||
| User Accounts Don't Populate To Remove | Vista account administration | |||
| Dynamically populate unattend.xml | Vista installation & setup | |||
