Vista - Script to create Dialup connection on XP
Old 10-23-2008   #1 (permalink)
David Kerber
I've been looking for several hours, and can't seem to locate the
information I need to write a vbscript to create a dialup networking
connection (New network connection, using modem) on XP. Can somebody
point me in a useful direction?
What I need is a pointer to either the wmi commands to do this, or a
command-line utility that I can pass parameters to. I know vbscript
pretty well, but can't find the utilities or commands I need to create a
new network connection with it.
TIA!
/~\ The ASCII
\ / Ribbon Campaign
X Against HTML
/ \ Email!
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).
Old 10-27-2008   #2 (permalink)
David Kerber
Re: Script to create Dialup connection on XP
In article <MPG.236abe5f8270800f989cb9@xxxxxx>,
ns_dkerber@xxxxxx_WarrenRogersAssociates.com says...
Anybody???
/~\ The ASCII
\ / Ribbon Campaign
X Against HTML
/ \ Email!
Help! Vista Cannot create dialup/VPN connections "The wizard cannot create the connection" Vista networking & sharing
how to create a new vpn connection using script o batch VB Script
BT Dialup connection Vista General
Setup a Dialup Connection Vista General
Blackberry Dialup connection interupts wireless connection Vista networking & sharing
