Vista - VBscript Help
Old 10-25-2008   #1 (permalink)
gazamon
VBscript Help
Hi all,
I've been racking my brain trying to figure out what is wrong with
this. The script runs and fails at line 60 (For Each objPatch in
ColPatches). Any help would be appreciatd. Thanks in advance.
'On Error Resume Next
strKB = Inputbox ("Enter the KB Number")
' in KB917537 format
x = 2
'Create an Excel Work Sheet
Set objExcel = CreateObject("Excel.Application")
objExcel.Visible = True
objExcel.Workbooks.Add
objExcel.Cells(1, 1).Value = "Machine Name"
objExcel.Cells(1, 2).Value = "KB"
objExcel.Cells(1, 3).Value = "Installed On"
objExcel.Cells(1, 4).Value = "Report Time Stamp"
objExcel.Range("A1:G1").Select
objExcel.Selection.Interior.ColorIndex = 19
objExcel.Selection.Font.ColorIndex = 11
objExcel.Selection.Font.Bold = True
objExcel.Cells.EntireColumn.AutoFit
'Read machine names from a txt file
Set Fso = CreateObject("Scripting.FileSystemObject")
Set InputFile = fso.OpenTextFile("MachineList.Txt")
Do While Not (InputFile.atEndOfStream)
strComputer = InputFile.ReadLine
intRow = x
objExcel.Cells(intRow, 1).Value = strComputer
GetPatchInfo
objExcel.Cells(intRow, 4).Value = Now()
x = x + 1
Loop
Wscript.Echo "Done"
'Get patch Status from WMI
Sub GetPatchInfo
Set objWMIService = GetObject("winmgmts:" & _
"{impersonationLevel=Impersonate}!\\" & strComputer & "\root
\cimv2")
Set colPatches = objWMIService.ExecQuery _
("Select * From Win32_QuickFixEngineering Where HotFixID = ‘”&
strKB”’'")
objExcel.Cells(intRow, 2).Value = objPatch.Description
objExcel.Cells(intRow, 3).Value = objPatch.InstalledOn
Next
End Sub
Old 10-25-2008   #2 (permalink)
James Whitlow
Re: VBscript Help
<gazamon@xxxxxx> wrote in message
news:8255ab1f-fc41-4a92-ba04-43d0f57e53ff@xxxxxx
Quote:
> Hi all,
>strKB”’'")
I think it is a problem with your quotes & a missing 'For'. Your single
and double quotes in the HotFixID area above have high ascii values. It
looks like Word of other editor has done some auto-formatting for you. Try
chaning the line to:
("Select * From Win32_QuickFixEngineering " _
& "Where HotFixID = '" & strKB & "'")
Also, just below that line, insert:
For Each objPatch in colPatches
I ran it with these changes on my WinXP Pro SP2 computer and it works.
Old 10-27-2008   #3 (permalink)
Gaz
Re: VBscript Help
On Oct 25, 1:07*pm, "James Whitlow" <jwhitlow.60372...@xxxxxx>
wrote:
Quote:
> <gaza...@xxxxxx> wrote in message
Quote:
> > Hi all,
> > *Set colPatches = objWMIService.ExecQuery _
> > * *("Select * From Win32_QuickFixEngineering Where HotFixID = ‘”&
> >strKB”’'")
> * I think it is a problem with your quotes & a missing 'For'. Your single
> * ("Select * From Win32_QuickFixEngineering " _
> * & "Where HotFixID = '" & strKB & "'")
> * Also, just below that line, insert:
> * I ran it with these changes on my WinXP Pro SP2 computer and it works..
That did the trick.. Thanks for the help
Old 12-10-2008   #4 (permalink)
Vista
Re: VBscript Help
Hello all. In using this VBS, it works great until it finds a computer not on the network and it errors out. Is there a way to add a line to skip the error and continue with the server list? Thanks
Old 12-10-2008   #5 (permalink)
Tom Lavedas
Re: VBscript Help
On Dec 10, 12:06*pm, hgiljr <gu...@xxxxxx-email.com> wrote:
Quote:
> Hello all. *In using this VBS, it works great until it finds a computer
> skip the error and continue with the server list? *Thanks
> hgiljr
There are a couple of ways. The most direct method is to turn off
error trapping around the sensitive code and then have your procedure
handle the error, something like this ...
' in the sub ...
Sub GetPatchInfo
on error resume next
"{impersonationLevel=Impersonate}!\\" & strComputer _
& "\root\cimv2")
if err.number <> 0 then exit sub
' the rest of the code ...
The other approach is to 'ping' the computer and proceed only if it's
on line. Here is a version of such a procedure that works in all WSH
equipped environments ...
Function IsConnectible(sHost, iPings, iTO)
' Returns True or False based on the output from ping.exe
' Authors: Alex Angelopoulos/Torgeir Bakken
' Modified by: Tom Lavedas
' Works an "all" WSH versions
' sHost is a hostname or IP
' iPings is number of ping attempts
' iTO is timeout in milliseconds
' if values are set to "", then defaults below used
Dim nRes
If iPings = "" Then iPings = 1 ' default number of pings
If iTO = "" Then iTO = 250 ' default timeout per ping
with CreateObject("WScript.Shell")
nRes = .Run("%comspec% /c ping.exe -n " & iPings & " -w " & iTO
_
& " " & sHost & " | find ""TTL="" > nul 2>&1", 0, True)
end with
IsConnectible = (nRes = 0)
End Function
it would be used in the Do Loop something like ...
if IsConnectible(strComputer, 1, 500) then GetPatchInfo
HTH.
BTW, it might be more productive to formulate your question as a new
post, since people may not go to the end of an old thread like this
one to find you new post. It all depends on the reader setup they're
using whether they'll even see it.
Tom Lavedas
http://there.is.no.more/tglbatch/
Old 12-10-2008   #6 (permalink)
ekkehard.horner
Re: VBscript Help
> ' in the sub ...
> Sub GetPatchInfo
> & "\root\cimv2")
On Error GoTo 0
Old 12-10-2008   #7 (permalink)
Tom Lavedas
Re: VBscript Help
On Dec 10, 1:15*pm, "ekkehard.horner" <ekkehard.hor...@xxxxxx>
Quote:
> > There are a couple of ways. *The most direct method is to turn off
Quote:
> > ' in the sub ...
> > Sub GetPatchInfo
> > * Set objWMIService = GetObject("winmgmts:" & _
> > * * *"{impersonationLevel=Impersonate}!\\" & strComputer _
> > * * *& "\root\cimv2")
> > * if err.number <> 0 then exit sub
> * *On Error GoTo 0> ' the rest of the code ...
Right!
Tom Lavedas
Old 12-11-2008   #8 (permalink)
Vista
Re: VBscript Help
Worked. thanks agian
New to VBscript, Help please! VB Script
CSS and VBscript VB Script
Where is VBscript now? VB Script
How to do No hang up VBScript (nohup for VBScript) VB Script
vbscript and HTA help VB Script
