Vista - Re: Weird script issues
Old 10-31-2008   #1 (permalink)
Richard Mueller [MVP]
"Phyxious" <Phyxious@xxxxxx> wrote in message
news:7DC77019-6E19-47E4-A23F-EBB99D02F85C@xxxxxx
Quote:
>I am having a few issues that I am unsure of. When running my script
>against
> remote machines I always use IP Address. For some reason on some machines
> I
> will get remote server does not exist, even though I can ping it. If I use
> the host name it will work or for some it still fails. Any idea why this
> would be?
> My next issue is on a few machines I have a WMI query accessing the
> Win32_ComputerSystem class. When retrieving the UserName property, it will
> return NULL even though there is a user logged in. Why is this?
> Any help is greatly appriciated. Thank you.
We may need to see the script. For example, if you use "On Error Resume
Next" an error can be raised and all you see is that a Null is displayed.
The script may fail to attach to the remote computer because of error,
firewall, DCOM disabled, a problem with WMI, etc. If you use "On Error
Resume Next", comment it out.
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
Old 11-03-2008   #2 (permalink)
Phyxious
I can not find the machine that was causing this issue so I can not give you
the exact error that was occuring. But here is portion of my code:
sComputer = InputBox("Enter IP Address", "IP Address", "150.142.")
Set oWMIService = GetObject("winmgmts:{impersonationlevel=impersonate}!\\" &
sComputer & "\root\cimv2")
'On Error Resume Next
' Call Win32_ComputerSystem class to get information about the pc
Set cComputerSystem = oWMIService.ExecQuery("SELECT * FROM
Win32_ComputerSystem")
' Loop through the collection and store data in variables
For Each oComputerSystem In cComputerSystem
With oComputerSystem
If InStr(.Manufacturer, "Hewlett") > 0 Then
sProductNumber = ProductNumber(sComputer)
sManufacturer = "HP"
sModel = Mid(.Model, InStr(.Model, "Compaq"), 13)
Else
sManufacturer = "Dell"
sModel = .Model
End If
aUserName = Split(.UserName, "\")
sPCName = .Name
End With
Next
sDomain = aUserName(0)
sUserName = aUserName(1)
It would fail at the line aUserName = Split(.UserName, "\") because
..UserName is NULL. Now at the time I ran the script I verified that a user is
logged on by using SysInternals psloggedon application, so really I do not
understand why it would come back NULL
> >against
> > I
> > would be?
> Richard Mueller
Old 11-03-2008   #3 (permalink)
news:048E1ED5-3E47-4551-AED3-3FE9C67BE812@xxxxxx
>you
> Else
> sModel = .Model
> End If
> sPCName = .Name
> End With
> Next
> is
The only time I get the error "Invalid use of Null: 'Split'" is when no one
is logged into the computer. I assume that you get a value for sPCName, so
you know that the script successfully connected to the remote computer. If
so, that means you can retrieve .Name but not .UserName, which cannot be
explained.
Since in general you will not know if someone is logged in (or you wouldn't
be retrieving .UserName) it would make sense to check for the Null
condition. Perhaps similar to:
sName = .UserName
If Not IsNull(sName) Then
aUserName = Split(sName, "\")
sUserName aUserName(1)
Else
sDomain = "none"
sUserName = "none"
End If
End With
I did not bother to check if UBound of aUserName is greater than 0, as in my
tests there is always a "\" in the value of .UserName, even if the user is
local.
Richard Mueller
End With
Some Weird Desktop Shortcut Icon Issues General Discussion
Weird CPU usage and memory allocation issues... General Discussion
Re: Weird script issues VB Script
Weird Connection Issues Vista mail
Weird RAM Issues General Discussion
