Vista - Re: Help required with file size checking script
Old 11-05-2008   #1 (permalink)
Richard Mueller [MVP]
"Jason" <spamspamspam@xxxxxx> wrote in message
news:Xns9B4DAC1F9F7A3spamspamspamSpanishI@xxxxxx
Quote:
> Hi,
> I'm new to VBscript & a bit rusty with programming in general, I've just
> started working on a script that will probably be run at logon & would
> like
> a few pointers before I start.
> I want the script to check the size of the users default pst file & if the
> size is above 1.7 Gig display a warning message &, if possible, open up an
> email to notify me of the problem.
> The scenario I have is that all the users here have their pst files stored
> on the C drive; they are all stored in folder "C:\PST\" with the PST file
> itself being named after the user (i.e. C:\PST\user1.pst, C:\PST\user2pst,
> etc). I could rename everyone's PST file to the same filename
> (outlook.pst)
> but we do have a few users who share a computer, so that would cause a
> problem too.
> Does anyone have any ideas about how to tackle this with VBscript? I
> suppose the pseudo code would be something like:
> What files are in the C:\PST folder that have a '.pst' extension
> Are any of them above 1.7 GB
> If so display a warning box
> When the box has been closed open up a pre-filled email to be sent to the
> IT dept
> I'd be interested to know what functions within VBscript would help me
> achieve my goals, particularly ones that work with the file system?
> Many thanks, Jason
You can use either the FileSystemObject or the CIM_Datafile class of WMI to
retrieve properties of files. Since there may be more than one user, it
seems prudent to retrieve the username from the wshNetwork object. This
allows you to specify the correct *.pst file for the user. For example,
using the FileSystemObject:
Option Explicit
Dim objNetwork, strUserName, strFile, objFile, lngSize
Set objNetwork = CreateObject("Wscript.Network")
' Retrieve current user name.
strUserName = objNetwork.UserName
' Specify the pst file for this user.
strFile = "c:\PST\" & strUserName & ".pst"
' Retrieve the file size.
Set objFSO = CreateObject("Scripting.FileSystemObject")
' Trap error if file not found.
On Error Resume Next
Set objFile = objFSO.GetFile(strFile)
If (Err.Number = 0) Then
On Error GoTo 0
lngSize = CLng(objFile.Size)
If (lngSize > 1700000000) Then
Call MsgBox("Your output *.pst file is too large")
End If
End If
On Error GoTo 0
The same thing using WMI would be (watch for line wrapping):
Option Explicit
Dim objNetwork, strUserName, strComputer, strFile
Dim objWMIService, colFiles, objFile, lngSize
' Retrieve current user name and computer name.
strComputer = objNetwork.Computer
Set objWMIService = GetObject("winmgmts:" _
& "{impersonationLevel=impersonate,authenticationLevel=Pkt}!\\" _
& strComputer & "\root\cimv2")
Set colfiles = objWMIService.ExecQuery _
("SELECT * FROM CIM_Datafile WHERE Name = '" & Replace(strFile, "\",
lngSize = 0
For Each objFile In colFiles
lngSize = CLng(objFile.FileSize)
Next
End If
Sending email from a script is another matter. You might be able to use CDO.
See these example:
http://www.microsoft.com/technet/scr.../mssmvb01.mspx
http://www.microsoft.com/technet/scr.../mssmvb02.mspx
Since all users presumably have Outlook, you might be able to use the
Outlook object to create an email message. Someone else might have an
example:
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
Old 11-05-2008   #2 (permalink)
Jason
"Richard Mueller [MVP]" <rlmueller-nospam@xxxxxx> wrote in
news:#CYCq92PJHA.576@xxxxxx:
Quote:
>> Hi,
>> just started working on a script that will probably be run at logon &
>> would like
>> if the size is above 1.7 Gig display a warning message &, if
>> possible, open up an email to notify me of the problem.
>> stored on the C drive; they are all stored in folder "C:\PST\" with
>> the PST file itself being named after the user (i.e.
>> C:\PST\user1.pst, C:\PST\user2pst, etc). I could rename everyone's
>> PST file to the same filename (outlook.pst)
>> a problem too.
>> the IT dept
>> me achieve my goals, particularly ones that work with the file
>> system?
>> Many thanks, Jason
> WMI to retrieve properties of files. Since there may be more than one
> user, it seems prudent to retrieve the username from the wshNetwork
> object. This allows you to specify the correct *.pst file for the
> user. For example, using the FileSystemObject:
> Option Explicit
> On Error GoTo 0
> End If
> End If
> On Error GoTo 0
> Option Explicit
> lngSize = 0
> Next
> End If
> use CDO. See these example:
> http://www.microsoft.com/technet/scr...ssage/smtpmail
Quote:
> mssmvb02.mspx
> example:
Thanks Richard, that's a great reply, I've got more than enough there to
be able to give it a really good go.
Jason.
Re: PS Script to automate checking date of file and delete if old PowerShell
Error checking with WMI Lastreboot script PowerShell
Checking the Existing of files and their size ... PowerShell
Re: checking for results when executing a script PowerShell
Checking Mailbox Size Vista mail
