Vista - Format the system volume
Old 11-05-2008   #1 (permalink)
David Trimboli
I'm working on a script for Windows deployment that is supposed to
detect the active partition on the computer's first disk and reformat it
(and leave all other partitions alone). The script will run in Windows
PE 2.0, so I can use WMI classes introduced with Windows Vista. I've
been trying to figure out how to use Win32_DiskPartition and
Win32_Volume to coordinate this format. The trouble is,
Win32_DiskPartition doesn't know anything about volumes, and
Win32_Volume doesn't know anything about partitions.
Does anybody have any advice on the basic flow of this script? I know
how to script WMI; I'm just not sure which classes and methods have the
tools I need.
David Trimboli
Windows Systems Analyst
Cold Spring Harbor Laboratory
43 GB System File in System Volume Information on 160 GB partition Vista General
System Volume Vista performance & maintenance
Can't Shrink System Volume? Vista performance & maintenance
not able to format newly created shrink volume Vista installation & setup
2nd HDD will not format with NTFS system Vista hardware & devices
