| | Help with Null please How can I pass a Null value to an update script. Here is what I am currently using. However, instead of filling in 01/01/1900 I want the value in the field to be blank. Sub DoUpdateAccession if strADate = "" then strADate = 01/01/1900 Else strADate = strADate End if Set rsUpdateAccession = server.createobject("adodb.recordset") conn.webqry_UpdateAccession strADate End Sub |
| | Re: Help with Null please RICK wrote: Quote: > How can I pass a Null value to an update script. > hi Rick, As best I recall, an UNINITIALIZED vbs variable will return a null, if tested. Your "" value refers an empty STRING (not a null). To test for null, you can use the IsNull function, or you can use VarType and test for vbNull. cheers, jw ____________________________________________________________ You got questions? WE GOT ANSWERS!!! ..(but, no guarantee the answers will be applicable to the questions) |
| | Re: Help with Null please "RICK" <RICK@xxxxxx> wrote in message news:CCD68295-DBA6-48DA-84C8-C4EA3B5A3E7B@xxxxxx Quote: > How can I pass a Null value to an update script. Here is what I am > currently > using. However, instead of filling in 01/01/1900 I want the value in the > field to be blank. > > Sub DoUpdateAccession > > if strADate = "" then > strADate = 01/01/1900 > Else strADate = strADate > End if > > Set rsUpdateAccession = server.createobject("adodb.recordset") > conn.webqry_UpdateAccession strADate > > End Sub > > > > generally you cannot simply assign a blank string. With AD objects you must use the PutEx method and pass the ADS_PROPERTY_CLEAR constant (which has a value of 1) to it. This clears the attribute. For example see this link: http://www.microsoft.com/technet/scr.../usmdvb06.mspx I don't know what you are updating, but I suspect a similar limitation applies. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| [string]$a = $null; $a -eq $null; $a -eq "" | PowerShell | |||
| why is $_.Name null for this? | PowerShell | |||
| Why is this null? | PowerShell | |||
| Re: "Error: 'null' is null or not an object" when trying to view video | Vista performance & maintenance | |||
| Gotcha: $null to [string] IS NOT $null | PowerShell | |||
