| | less than and greater than signs/response.write Pulling data from a database with response.write. The fields have "<" and ">" signs. How can I get the full field to display. Currently, the fields are being truncated at the signs. Rick |
| | Re: less than and greater than signs/response.write response.write Server.HTMLEncode(yourtext) http://msdn.microsoft.com/en-us/library/ms525347.aspx Assuming you mean ASP... Tim "RICK" <RICK@xxxxxx> wrote in message news:8CDC5E06-7A67-415D-BAA0-2B1503598AE3@xxxxxx Quote: > Pulling data from a database with response.write. The fields have "<" and > ">" signs. How can I get the full field to display. Currently, the > fields > are being truncated at the signs. > > Rick |
| | Re: less than and greater than signs/response.write "RICK" <RICK@xxxxxx> wrote in message news:8CDC5E06-7A67-415D-BAA0-2B1503598AE3@xxxxxx Quote: > Pulling data from a database with response.write. The fields have "<" and > ">" signs. How can I get the full field to display. Currently, the > fields > are being truncated at the signs. > > Rick square brackets, "[]". Or, you may need to "escape" the characters. The escape character depends on your DBMS. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| Windows backup greater flexibility | Vista performance & maintenance | |||
| application installer wants XP sp1 or greater... | Vista General | |||
| build 5800 or greater | Vista General | |||
| Greater Than on doubles | PowerShell | |||
| New HDD - greater performance? | Vista General | |||
