| | Help to build a Requery Hi. With second query, un error is generated: "The object objRecordset is already open" With this code is possible to requery the object "objRecordset" without clouse it? adOpenStatic = 3 adLockOptimistic = 3 adUseClient = 3 Set objConnection = CreateObject("ADODB.Connection") Set objRecordset = CreateObject("ADODB.Recordset") StrCnn = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\Supervisao\Descarga.mdb;Persist Security Info=False" objRecordset.CursorLocation = adUseClient objRecordset.Open "SELECT * FROM RegVag" , StrCnn ,adOpenStatic, adLockOptimistic QueryHistActuDesc="TRANSFORM IIf(IsNull(SUM(Vagonas)),0,SUM(Vagonas)) SELECT Data FROM RegVag Where Data = #"+ CarRegDataIn + "# group by Data order by Data Asc PIVOT 'P' & CodMat In ('P1','P2','P3','P4','P5','P6')" objRecordset.Open QueryHistActuDesc, StrCnn ,adOpenStatic, adLockOptimistic Set Descarga_DataGrid1.DataSource = objRecordset IF not objRecordSet.EOF then DVE(0)=CInt(objRecordSet.Fields(1).Value) DVE(1)=CInt(objRecordSet.Fields(2).Value) DVE(2)=CInt(objRecordSet.Fields(3).Value) DVE(3)=CInt(objRecordSet.Fields(4).Value) DVE(4)=CInt(objRecordSet.Fields(5).Value) DVE(5)=CInt(objRecordSet.Fields(6).Value) else DVE(0)=0 DVE(1)=0 DVE(2)=0 DVE(3)=0 DVE(4)=0 DVE(5)=0 end if QueryHistActuDesc="TRANSFORM IIf(IsNull(SUM(Paletes)),0,SUM(Paletes)) SELECT Data FROM RegVag Where Data = #"+ CarRegDataIn + "# group by Data order by Data Asc PIVOT 'P' & CodMat In ('P1','P2','P3','P4','P5','P6')" objRecordset.Open QueryHistActuDesc, StrCnn ,adOpenStatic, adLockOptimistic IF not objRecordSet.EOF then DVE(9)=CInt(objRecordSet.Fields(1).Value) DVE(10)=CInt(objRecordSet.Fields(2).Value) DVE(11)=CInt(objRecordSet.Fields(3).Value) DVE(12)=CInt(objRecordSet.Fields(4).Value) DVE(13)=CInt(objRecordSet.Fields(5).Value) DVE(14)=CInt(objRecordSet.Fields(6).Value) else DVE(9)=0 DVE(10)=0 DVE(11)=0 DVE(12)=0 DVE(13)=0 DVE(14)=0 end if objRecordset.close Thanks H |
| | Re: Help to build a Requery "Henrique" <wq@xxxxxx> wrote in message news:newscache$mhr9ak$vic$1@xxxxxx Quote: > Hi. > > > With second query, un error is generated: "The object objRecordset is > already open" > > With this code is possible to requery the object "objRecordset" without > clouse it? > > adOpenStatic = 3 > adLockOptimistic = 3 > adUseClient = 3 > Set objConnection = CreateObject("ADODB.Connection") > Set objRecordset = CreateObject("ADODB.Recordset") > StrCnn = "Provider=Microsoft.Jet.OLEDB.4.0;Data > Source=C:\Supervisao\Descarga.mdb;Persist Security Info=False" > objRecordset.CursorLocation = adUseClient > objRecordset.Open "SELECT * FROM RegVag" , StrCnn ,adOpenStatic, > adLockOptimistic > > QueryHistActuDesc="TRANSFORM IIf(IsNull(SUM(Vagonas)),0,SUM(Vagonas)) > SELECT Data FROM RegVag Where Data = #"+ CarRegDataIn + "# group by Data > order by Data Asc PIVOT 'P' & CodMat In ('P1','P2','P3','P4','P5','P6')" > objRecordset.Open QueryHistActuDesc, StrCnn ,adOpenStatic, > adLockOptimistic > > Set Descarga_DataGrid1.DataSource = objRecordset > > IF not objRecordSet.EOF then > DVE(0)=CInt(objRecordSet.Fields(1).Value) > DVE(1)=CInt(objRecordSet.Fields(2).Value) > DVE(2)=CInt(objRecordSet.Fields(3).Value) > DVE(3)=CInt(objRecordSet.Fields(4).Value) > DVE(4)=CInt(objRecordSet.Fields(5).Value) > DVE(5)=CInt(objRecordSet.Fields(6).Value) > else > DVE(0)=0 > DVE(1)=0 > DVE(2)=0 > DVE(3)=0 > DVE(4)=0 > DVE(5)=0 > end if > > > > QueryHistActuDesc="TRANSFORM IIf(IsNull(SUM(Paletes)),0,SUM(Paletes)) > SELECT Data FROM RegVag Where Data = #"+ CarRegDataIn + "# group by Data > order by Data Asc PIVOT 'P' & CodMat In ('P1','P2','P3','P4','P5','P6')" > objRecordset.Open QueryHistActuDesc, StrCnn ,adOpenStatic, > adLockOptimistic > IF not objRecordSet.EOF then > DVE(9)=CInt(objRecordSet.Fields(1).Value) > DVE(10)=CInt(objRecordSet.Fields(2).Value) > DVE(11)=CInt(objRecordSet.Fields(3).Value) > DVE(12)=CInt(objRecordSet.Fields(4).Value) > DVE(13)=CInt(objRecordSet.Fields(5).Value) > DVE(14)=CInt(objRecordSet.Fields(6).Value) > else > DVE(9)=0 > DVE(10)=0 > DVE(11)=0 > DVE(12)=0 > DVE(13)=0 > DVE(14)=0 > end if > > objRecordset.close > > > > Thanks > > H > to issue both queries at once. Then use the NextRecordset method. http://www.w3schools.com/ADO/met_rs_nextrecordset.asp -- Joe Fawcett (MVP - XML) http://joe.fawcett.name |
| New Build | Vista hardware & devices | |||
| Powershell for Longhorn Build Build 6001 | PowerShell | |||
| Vista Build 5744 doesn't want to upgrade build 5536 | Vista installation & setup | |||
| Vista public build 5384, nerds build 5472 | Vista General | |||
| Build NO. | Vista mail | |||
