| | Setting COM Port Properties, Named pipe I want to set the COM port properties of a virtual machine to a named pipe, i.e. value of Name of COM port 1 of a machine to \\.\pipe\<Machine Name>. But I wish to do through running VBScript on Host Machine, same as I do to set memory and other properties of VM. can anyone help me on this? Any input would be of great help... |
| Hyper-V -sharing modem for sbs server - How do you connect a com port to a named pipe | Virtual Server | |||
| Unable to open Properties Tab to change TCP/IP settings on Ethernet Port | Network & Sharing | |||
| Pipe a pipe command to a file | VB Script | |||
| Support for Named Pipe | PowerShell | |||
