Vista - spaces and variable in path
Old 11-15-2008   #1 (permalink)
stay_tuned001
I am trying to write a script that runs a series of commands from a
server. The server from where the commands run depends upon where the
end user is located. At the start of the script, I ask for the name of
the server:
Wscript.StdOut.Write "Please enter SMS server name: "
strsvr = Wscript.StdIn.ReadLine
Then I start running the commands like this:
Set wshShell = WScript.CreateObject ("WSCript.shell")
wshshell.run "\\" & strsvr & "\foldername\foldername\foldername
\install.exe", , True
My problem is when there are spaces in the path. I know that using 3
sets of quotes solves the problem with spaces, but this does not work
when I use a variable in the middle of the entire path, like this:
wshshell.run "\\" & strsvr & """\foldername\folder name\folder name
\install.exe""", , True
Nor does assigning the path to a variable work, such as:
installPath = """\foldername\folder name\folder name\install.exe"""
wshshell.run "\\" & strsvr & installPath, , True
I have just started teaching myself vbscript, so I'm still very new to
this.
Any help would greatly appreciated
Old 11-15-2008   #2 (permalink)
Tom Lavedas
Re: spaces and variable in path
On Nov 15, 4:04*pm, stay_tuned...@xxxxxx wrote:
> server. *The server from where the commands run depends upon where the
> the server:
> this.
The quotes need to enclose the entire path. So, in this case, the
construct should look something like this ...
installPath = "\foldername\folder name\folder name\install.exe"
wshshell.run """\\" & strsvr & installPath & """", , True
Or use the Chr(34) construct instead ...
wshshell.run Chr(34) & "\\" & strsvr & installPath & Chr(34), , True
Tom Lavedas
Old 11-15-2008   #3 (permalink)
stay_tuned001
> > the server:
> > this.
> The quotes need to enclose the entire path. *So, in this case, the
> Tom Lavedas
Worked like a charm!!!!
I cannot thank you enough. I've been struggling with this for days.
Old 11-16-2008   #4 (permalink)
Tom Lavedas
> > > the server:
Quote:
> > > this.
Quote:
> > Tom Lavedas
> I cannot thank you enough. *I've been struggling with this for days.
Glad to be of some assistance.
Tom Lavedas
Spaces in script path PowerShell
VBS script with spaces in executable path VB Script
Re: running a program with spaces in Path with invoke-expression PowerShell
invoke-expression with .exe that has spaces in its path PowerShell
script with spaces in the path PowerShell
