| | HTA RDS Data Control problem I am trying to extract data from an .mdb file on my local HD using an .hta file with a RDS data control. No errors occur but no data is displayed either. I have tried several different connection strings but nothing works. I have also tried setting the Server parameter to various things but I still get the same result. Here is what I have in my .hta file. <blockquote> <span id=DataArea></span> </blockquote> <OBJECT classid="clsid:BD96C556-65A3-11D0-983A-00C04FC29E33" ID=dsoComposer HEIGHT=0 WIDTH=0> <PARAM NAME="Connect" VALUE="Driver={Microsoft Access Driver (*.mdb)};Dbq=c:\temp_2\db1.mdb;Uid=admin;Pwd=;"> <PARAM NAME="SQL" VALUE="select * from myResults"> </OBJECT> <table border='1' width='100%' cellspacing='0' datasrc=#dsoComposer> <THEAD><TR> <TD>Field1</TD> <TD>Field3</TD> <TD>Field4</TD> </TR> </THEAD> <TBODY> <TR> <TD><DIV datafld="Field1"></DIV></TD> <TD><DIV datafld="Field3"></DIV></TD> <TD><DIV datafld="Field4"></DIV></TD> </TR> </TBODY> </TABLE> |
| | Re: HTA RDS Data Control problem On Nov 17, 9:57*am, YukonJuan <jvstew...@xxxxxx> wrote: Quote: > I am trying to extract data from an .mdb file on my local HD using > an .hta file with a RDS data control. > No errors occur but no data is displayed either. *I have tried several > different connection strings but nothing works. *I have also tried > setting the Server parameter to various things but I still get the > same result. *Here is what I have in my .hta file. > > <blockquote> > <span id=DataArea></span> > </blockquote> > <OBJECT classid="clsid:BD96C556-65A3-11D0-983A-00C04FC29E33" > * * *ID=dsoComposer HEIGHT=0 WIDTH=0> > * * <PARAM NAME="Connect" VALUE="Driver={Microsoft Access Driver > (*.mdb)};Dbq=c:\temp_2\db1.mdb;Uid=admin;Pwd=;"> > * * <PARAM NAME="SQL" * * VALUE="select * from myResults"> > </OBJECT> > <table border='1' width='100%' cellspacing='0' datasrc=#dsoComposer> > <THEAD><TR> > <TD>Field1</TD> > <TD>Field3</TD> > <TD>Field4</TD> > </TR> > </THEAD> > <TBODY> > <TR> > <TD><DIV datafld="Field1"></DIV></TD> > <TD><DIV datafld="Field3"></DIV></TD> > <TD><DIV datafld="Field4"></DIV></TD> > </TR> > </TBODY> > </TABLE> and I can retrieve the data with no problem. |
| Which data control gives me this view? | .NET General | |||
| User Account Control & Data in the Program Files Folder | Vista account administration | |||
| Missing Data - Control Panel\Programs and Features | Vista General | |||
