Vista - Pls help me create a CSV named from a varible in VBS
Old 11-19-2008   #1 (permalink)
GazzaJagman
I'm trying to create a csv file that is named after the data I'm trying to
pass data to.
I want a script that finds the server hostname and then creates a CSV file
based on that name. I'm using VBS and WMI to find the machine's host name and
I'll be adding a load more objects later (which i why I chose to use WMI).
This script will eventually form an audit of a server. I know how to create a
CSV file and pass data to it, I just can't seem to work out how to rename the
file as a varible:
On Error Resume Next
Set objFS = CreateObject("Scripting.FileSystemObject")
Set objNewFile = objFS.CreateTextFile("Audit.csv")
'HostName
strComputer = "."
Set HN = GetObject("winmgmts:\\" & strComputer & "\root\CIMV2")
Set colItems = HN.ExecQuery( _
"SELECT * FROM Win32_OperatingSystem",,48)
Set HostName = objItem.CSName
For Each objItem in colItems
Wscript.Echo objItem.CSName & ","
Next
objFile.Close
Can anyone help me?
Regards,
Gareth Cooper
"Science is what we hope for...Technology is what we get stuck with"
Old 11-19-2008   #2 (permalink)
GazzaJagman
RE: Pls help me create a CSV named from a varible in VBS
opps...
I had an Echo there when I needed a Write,
objNewFile.Write objItem.CSName & ","
"GazzaJagman" wrote:
Quote:
> Hi,
> pass data to.
> file as a varible:
> 'HostName
> strComputer = "."
> Next
> objFile.Close
> Can anyone help me?
> Regards,
> Gareth Cooper
Old 11-19-2008   #3 (permalink)
GazzaJagman
Sorted! I worked it out through trial and error (mostly errors).
I used:
Dim strComputer
'HostName'
strComputer = "."
Set objNewFile = objFS.CreateTextFile(objItem.CSName & ".CSV")
objNewFile.WriteLine "HostName, "
Next
objNewFile.Close
This script looks up a Server's hostname and then creates a CSV file using
the Hostname as a filename. It then populates the CSV file with a heading of
Hostname,
followed by the entry.
Regards,
Gareth Cooper
Quote:
> opps...
Quote:
> > Hi,
> > pass data to.
> > file as a varible:
> > 'HostName
> > strComputer = "."
> > Next
> > objFile.Close
> > Can anyone help me?
> > Regards,
> > Gareth Cooper
Re: re-named folders by WLM Live Mail
Un-named trojan Live Messenger
Files named WindowsLiveContact Vista General
Local $varible scope? PowerShell
Multiple Named Networks Vista networking & sharing
