| | Cancel Process that is a System Task I'm using VBS trying to cancel a process who's user is SYSTEM. The code below work just fine for any process that I've started, but if I try one that has a user of SYSTEM it doesn't work. strComputer = "." Set objWMIService = GetObject("winmgmts:" _ & "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2") Set colProcessList = objWMIService.ExecQuery _ ("Select * from Win32_Process Where Name = ""MqrServerMon.exe""") For Each objProcess in colProcessList objProcess.Terminate() Next WSCript.Echo "Just killed process " _ & " on " & strComputer This is pretty standard code to do this, but it just does not seem to be working for the system users. Thanks for any suggestions. Rodney |
| | Re: Cancel Process that is a System Task "Installer" <Installer@xxxxxx> wrote in message news:29729467-CD51-4EA5-AD1C-8D7B892CE174@xxxxxx Quote: > I'm using VBS trying to cancel a process who's user is SYSTEM. The code > below work just fine for any process that I've started, but if I try one > that > has a user of SYSTEM it doesn't work. > > strComputer = "." > Set objWMIService = GetObject("winmgmts:" _ > & "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2") > > Set colProcessList = objWMIService.ExecQuery _ > ("Select * from Win32_Process Where Name = ""MqrServerMon.exe""") > > For Each objProcess in colProcessList > objProcess.Terminate() > Next > WSCript.Echo "Just killed process " _ > & " on " & strComputer > > This is pretty standard code to do this, but it just does not seem to be > working for the system users. > > Thanks for any suggestions. > Rodney see a screen message that tells you the reason. |
| | Re: Cancel Process that is a System Task Yes, I have no problem with taskkill. My problem with using taskkill from the shell command is that it ignores my vbHide parameter and I get the pop-up cmd prompt. This looks really awful during an install so I was trying to get everything into vbscript. Thanks for the idea. "Pegasus (MVP)" wrote: Quote: > > "Installer" <Installer@xxxxxx> wrote in message > news:29729467-CD51-4EA5-AD1C-8D7B892CE174@xxxxxx Quote: > > I'm using VBS trying to cancel a process who's user is SYSTEM. The code > > below work just fine for any process that I've started, but if I try one > > that > > has a user of SYSTEM it doesn't work. > > > > strComputer = "." > > Set objWMIService = GetObject("winmgmts:" _ > > & "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2") > > > > Set colProcessList = objWMIService.ExecQuery _ > > ("Select * from Win32_Process Where Name = ""MqrServerMon.exe""") > > > > For Each objProcess in colProcessList > > objProcess.Terminate() > > Next > > WSCript.Echo "Just killed process " _ > > & " on " & strComputer > > > > This is pretty standard code to do this, but it just does not seem to be > > working for the system users. > > > > Thanks for any suggestions. > > Rodney > Can you kill the task with taskkill.exe? If you can't the you'll probably > see a screen message that tells you the reason. > > > |
| | Re: Cancel Process that is a System Task "Installer" <Installer@xxxxxx> wrote in message news:1D0FF693-FDCD-431B-9428-981DE417C8B0@xxxxxx Quote: > Yes, I have no problem with taskkill. My problem with using taskkill from > the shell command is that it ignores my vbHide parameter and I get the > pop-up > cmd prompt. This looks really awful during an install so I was trying to > get > everything into vbscript. > > Thanks for the idea. subsequently found that I could not terminate System tasks either when using your code. On the other hand I could use the "taskkill" work-around without getting a pop-up Command Prompt by running this code: Set ObjWshShell = WScript.CreateObject("WScript.Shell") ObjWshShell.Run "taskkill.exe /f /im MqrServerMon.exe", 0, False |
| | Re: Cancel Process that is a System Task "Installer" wrote: Quote: > Yes, I have no problem with taskkill. My problem with using taskkill from > the shell command is that it ignores my vbHide parameter and I get the pop-up > cmd prompt. This looks really awful during an install so I was trying to get > everything into vbscript. > > Thanks for the idea. > > "Pegasus (MVP)" wrote: > Quote: > > > > "Installer" <Installer@xxxxxx> wrote in message > > news:29729467-CD51-4EA5-AD1C-8D7B892CE174@xxxxxx Quote: > > > I'm using VBS trying to cancel a process who's user is SYSTEM. The code > > > below work just fine for any process that I've started, but if I try one > > > that > > > has a user of SYSTEM it doesn't work. > > > > > > strComputer = "." > > > Set objWMIService = GetObject("winmgmts:" _ > > > & "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2") > > > > > > Set colProcessList = objWMIService.ExecQuery _ > > > ("Select * from Win32_Process Where Name = ""MqrServerMon.exe""") > > > > > > For Each objProcess in colProcessList > > > objProcess.Terminate() > > > Next > > > WSCript.Echo "Just killed process " _ > > > & " on " & strComputer > > > > > > This is pretty standard code to do this, but it just does not seem to be > > > working for the system users. > > > > > > Thanks for any suggestions. > > > Rodney > > Can you kill the task with taskkill.exe? If you can't the you'll probably > > see a screen message that tells you the reason. > > > > > > Your WMI code should work providing that you use the right privileges: strComputer = "." Set objWMIService = GetObject("winmgmts:" _ & "{impersonationLevel=impersonate, " _ & "(Debug)}!\\" _ & strComputer & "\root\cimv2") Set colProcessList = objWMIService.ExecQuery _ ("Select * from Win32_Process " _ & "Where Name = 'someprocess.exe'") For Each objProcess in colProcessList intRetVal = objProcess.Terminate() Next WSCript.Echo "Just killed process " _ & " on " & strComputer -- urkec |
| | #6 (permalink) |
| | Re: Cancel Process that is a System Task "urkec" <urkec@xxxxxx> wrote in message news:6FC247B8-94DB-4E9B-A746-0DDF9031E5F6@xxxxxx Quote: > "Installer" wrote: > Quote: >> Yes, I have no problem with taskkill. My problem with using taskkill >> from >> the shell command is that it ignores my vbHide parameter and I get the >> pop-up >> cmd prompt. This looks really awful during an install so I was trying to >> get >> everything into vbscript. >> >> Thanks for the idea. >> >> "Pegasus (MVP)" wrote: >> Quote: >> > >> > "Installer" <Installer@xxxxxx> wrote in message >> > news:29729467-CD51-4EA5-AD1C-8D7B892CE174@xxxxxx >> > > I'm using VBS trying to cancel a process who's user is SYSTEM. The >> > > code >> > > below work just fine for any process that I've started, but if I try >> > > one >> > > that >> > > has a user of SYSTEM it doesn't work. >> > > >> > > strComputer = "." >> > > Set objWMIService = GetObject("winmgmts:" _ >> > > & "{impersonationLevel=impersonate}!\\" & strComputer & >> > > "\root\cimv2") >> > > >> > > Set colProcessList = objWMIService.ExecQuery _ >> > > ("Select * from Win32_Process Where Name = ""MqrServerMon.exe""") >> > > >> > > For Each objProcess in colProcessList >> > > objProcess.Terminate() >> > > Next >> > > WSCript.Echo "Just killed process " _ >> > > & " on " & strComputer >> > > >> > > This is pretty standard code to do this, but it just does not seem to >> > > be >> > > working for the system users. >> > > >> > > Thanks for any suggestions. >> > > Rodney >> > >> > Can you kill the task with taskkill.exe? If you can't the you'll >> > probably >> > see a screen message that tells you the reason. >> > >> > >> > > > Your WMI code should work providing that you use the right privileges: > > > strComputer = "." > > Set objWMIService = GetObject("winmgmts:" _ > & "{impersonationLevel=impersonate, " _ > & "(Debug)}!\\" _ > & strComputer & "\root\cimv2") > > Set colProcessList = objWMIService.ExecQuery _ > ("Select * from Win32_Process " _ > & "Where Name = 'someprocess.exe'") > > For Each objProcess in colProcessList > intRetVal = objProcess.Terminate() > Next > WSCript.Echo "Just killed process " _ > & " on " & strComputer > > > -- > urkec qualifier, yet your version works. What exactly does (Debug) do? |
| | #7 (permalink) |
| | Re: Cancel Process that is a System Task "Pegasus (MVP)" wrote: Quote: > AFAICS, the only difference between the OP's code and yours is the (Debug) > qualifier, yet your version works. What exactly does (Debug) do? This privilege (SE_DEBUG_PRIVILEGE) is required to kill other users's processes. You need to be an admin to be able to activate this privilege or this one have to be manually granted to a user with the security policy editor. The link below is very interesting (Specifically Table 6.8 : Privileges and descriptions). Hope this helps. -- Gilles LAURENT MVP Windows Server - Admin Frameworks http://glsft.free.fr |
| | #8 (permalink) |
| | Re: Cancel Process that is a System Task "Pegasus (MVP)" wrote: Quote: > > "urkec" <urkec@xxxxxx> wrote in message > news:6FC247B8-94DB-4E9B-A746-0DDF9031E5F6@xxxxxx Quote: > > "Installer" wrote: > > Quote: > >> Yes, I have no problem with taskkill. My problem with using taskkill > >> from > >> the shell command is that it ignores my vbHide parameter and I get the > >> pop-up > >> cmd prompt. This looks really awful during an install so I was trying to > >> get > >> everything into vbscript. > >> > >> Thanks for the idea. > >> > >> "Pegasus (MVP)" wrote: > >> > >> > > >> > "Installer" <Installer@xxxxxx> wrote in message > >> > news:29729467-CD51-4EA5-AD1C-8D7B892CE174@xxxxxx > >> > > I'm using VBS trying to cancel a process who's user is SYSTEM. The > >> > > code > >> > > below work just fine for any process that I've started, but if I try > >> > > one > >> > > that > >> > > has a user of SYSTEM it doesn't work. > >> > > > >> > > strComputer = "." > >> > > Set objWMIService = GetObject("winmgmts:" _ > >> > > & "{impersonationLevel=impersonate}!\\" & strComputer & > >> > > "\root\cimv2") > >> > > > >> > > Set colProcessList = objWMIService.ExecQuery _ > >> > > ("Select * from Win32_Process Where Name = ""MqrServerMon.exe""") > >> > > > >> > > For Each objProcess in colProcessList > >> > > objProcess.Terminate() > >> > > Next > >> > > WSCript.Echo "Just killed process " _ > >> > > & " on " & strComputer > >> > > > >> > > This is pretty standard code to do this, but it just does not seem to > >> > > be > >> > > working for the system users. > >> > > > >> > > Thanks for any suggestions. > >> > > Rodney > >> > > >> > Can you kill the task with taskkill.exe? If you can't the you'll > >> > probably > >> > see a screen message that tells you the reason. > >> > > >> > > >> > > > > > Your WMI code should work providing that you use the right privileges: > > > > > > strComputer = "." > > > > Set objWMIService = GetObject("winmgmts:" _ > > & "{impersonationLevel=impersonate, " _ > > & "(Debug)}!\\" _ > > & strComputer & "\root\cimv2") > > > > Set colProcessList = objWMIService.ExecQuery _ > > ("Select * from Win32_Process " _ > > & "Where Name = 'someprocess.exe'") > > > > For Each objProcess in colProcessList > > intRetVal = objProcess.Terminate() > > Next > > WSCript.Echo "Just killed process " _ > > & " on " & strComputer > > > > > > -- > > urkec > AFAICS, the only difference between the OP's code and yours is the (Debug) > qualifier, yet your version works. What exactly does (Debug) do? > > > It is the short form (that you can use in the winmgmts: moniker) of SeDebugPrivilege. You can also enable it with objWMIService.Security_.Privileges.AddAsString("SeDebugPrivilege") or Const wbemPrivilegeDebug = 19 objWMIService.Security_.Privileges.Add(wbemPrivilegeDebug) See here for the complete list of privileges: http://msdn.microsoft.com/en-us/libr...58(VS.85).aspx -- urkec |
| | #9 (permalink) |
| | Re: Cancel Process that is a System Task "Pegasus (MVP)" <I.can@xxxxxx> wrote in message news:%23Iq4oitTJHA.5860@xxxxxx Quote: > > "urkec" <urkec@xxxxxx> wrote in message > news:6FC247B8-94DB-4E9B-A746-0DDF9031E5F6@xxxxxx Quote: >> "Installer" wrote: >> Quote: >>> Yes, I have no problem with taskkill. My problem with using taskkill >>> from >>> the shell command is that it ignores my vbHide parameter and I get the >>> pop-up >>> cmd prompt. This looks really awful during an install so I was trying >>> to get >>> everything into vbscript. >>> >>> Thanks for the idea. >>> >>> "Pegasus (MVP)" wrote: >>> >>> > >>> > "Installer" <Installer@xxxxxx> wrote in message >>> > news:29729467-CD51-4EA5-AD1C-8D7B892CE174@xxxxxx >>> > > I'm using VBS trying to cancel a process who's user is SYSTEM. The >>> > > code >>> > > below work just fine for any process that I've started, but if I try >>> > > one >>> > > that >>> > > has a user of SYSTEM it doesn't work. >>> > > >>> > > strComputer = "." >>> > > Set objWMIService = GetObject("winmgmts:" _ >>> > > & "{impersonationLevel=impersonate}!\\" & strComputer & >>> > > "\root\cimv2") >>> > > >>> > > Set colProcessList = objWMIService.ExecQuery _ >>> > > ("Select * from Win32_Process Where Name = ""MqrServerMon.exe""") >>> > > >>> > > For Each objProcess in colProcessList >>> > > objProcess.Terminate() >>> > > Next >>> > > WSCript.Echo "Just killed process " _ >>> > > & " on " & strComputer >>> > > >>> > > This is pretty standard code to do this, but it just does not seem >>> > > to be >>> > > working for the system users. >>> > > >>> > > Thanks for any suggestions. >>> > > Rodney >>> > >>> > Can you kill the task with taskkill.exe? If you can't the you'll >>> > probably >>> > see a screen message that tells you the reason. >>> > >>> > >>> > >> >> Your WMI code should work providing that you use the right privileges: >> >> >> strComputer = "." >> >> Set objWMIService = GetObject("winmgmts:" _ >> & "{impersonationLevel=impersonate, " _ >> & "(Debug)}!\\" _ >> & strComputer & "\root\cimv2") >> >> Set colProcessList = objWMIService.ExecQuery _ >> ("Select * from Win32_Process " _ >> & "Where Name = 'someprocess.exe'") >> >> For Each objProcess in colProcessList >> intRetVal = objProcess.Terminate() >> Next >> WSCript.Echo "Just killed process " _ >> & " on " & strComputer >> >> >> -- >> urkec > AFAICS, the only difference between the OP's code and yours is the (Debug) > qualifier, yet your version works. What exactly does (Debug) do? |
| How to write a script to process it as a task? | PowerShell | |||
| Cancel export certificate process in Windows Vista with IE 7 | Vista security | |||
| Windows Task Manager or Process Explorer? | General Discussion | |||
| Ending process in Task Manager doesn't end it | Vista performance & maintenance | |||
| System Idle Process | Vista performance & maintenance | |||
