| | ASP form write to DB issue Hi, I don't have much scripting experience and I need some help with a simple piece of code. Basically, I have a html form with a input field that posts the input to a ASP page (the ASP page must establish a connection to a SQL database and write the input from the form to a table). The content of the ASP page as follows: ' Declaring variables Dim rest_nme, data_source, con, sql_insert ' Receiving values from Form rest_nme = Request.Form("rest_nme") data_source = "Provider=SQLNCLI;Server=localhost;Database=RMS;Uid=user;Pwd=password;" sql_insert = "insert into database.dbo.table (rest_nme) values ('" & rest_nme & "')" ' Creating Connection Object and opening the database Set con = CreateObject("ADODB.Connection") con.Open data_source con.Execute sql_insert ' Done. Close the connection con.Close Set con = Nothing I know for a fact that the form input is passed to the ASP page correctly (if I post the form to email the value is correct), but the row thats being written to the SQL DB is empty. From the empty row thats being written I must assume that the connection string works and I have no idea where the issue might lie. Any suggestions would be much appreciated! |
| | Re: ASP form write to DB issue You might get an answer here but you'd probably be better off asking in an ASP group. This group is just for general VBS. Quote: > > I don't have much scripting experience and I need some help with a > simple piece of code. Basically, I have a html form with a input field > that posts the input to a ASP page (the ASP page must establish a > connection to a SQL database and write the input from the form to a > table). The content of the ASP page as follows: > > > ' Declaring variables > Dim rest_nme, data_source, con, sql_insert > > ' Receiving values from Form > rest_nme = Request.Form("rest_nme") > > data_source = > "Provider=SQLNCLI;Server=localhost;Database=RMS;Uid=user;Pwd=password;" > sql_insert = "insert into database.dbo.table (rest_nme) values ('" & > rest_nme & "')" > > ' Creating Connection Object and opening the database > Set con = CreateObject("ADODB.Connection") > con.Open data_source > con.Execute sql_insert > > ' Done. Close the connection > con.Close > Set con = Nothing > > I know for a fact that the form input is passed to the ASP page > correctly (if I post the form to email the value is correct), but the > row thats being written to the SQL DB is empty. From the empty row > thats being written I must assume that the connection string works and > I have no idea where the issue might lie. Any suggestions would be > much appreciated! |
| | Re: ASP form write to DB issue Do a response.write with the SQL and try running that using whatever tool comes with the DB. Tim <avdvyver@xxxxxx> wrote in message news:9d138a9a-0386-43d7-9f1c-ad95c7ceedba@xxxxxx Quote: > Hi, > > I don't have much scripting experience and I need some help with a > simple piece of code. Basically, I have a html form with a input field > that posts the input to a ASP page (the ASP page must establish a > connection to a SQL database and write the input from the form to a > table). The content of the ASP page as follows: > > > ' Declaring variables > Dim rest_nme, data_source, con, sql_insert > > ' Receiving values from Form > rest_nme = Request.Form("rest_nme") > > data_source = > "Provider=SQLNCLI;Server=localhost;Database=RMS;Uid=user;Pwd=password;" > sql_insert = "insert into database.dbo.table (rest_nme) values ('" & > rest_nme & "')" > > ' Creating Connection Object and opening the database > Set con = CreateObject("ADODB.Connection") > con.Open data_source > con.Execute sql_insert > > ' Done. Close the connection > con.Close > Set con = Nothing > > I know for a fact that the form input is passed to the ASP page > correctly (if I post the form to email the value is correct), but the > row thats being written to the SQL DB is empty. From the empty row > thats being written I must assume that the connection string works and > I have no idea where the issue might lie. Any suggestions would be > much appreciated! |
| | Re: ASP form write to DB issue On Nov 24, 2:04*pm, avdvy...@xxxxxx wrote: Quote: > Hi, > > I don't have much scripting experience and I need some help with a > simple piece of code. Basically, I have a html form with a input field > that posts the input to a ASP page (the ASP page must establish a > connection to a SQL database and write the input from the form to a > table). The content of the ASP page as follows: > > ' Declaring variables > Dim rest_nme, data_source, con, sql_insert > > ' Receiving values from Form > rest_nme = Request.Form("rest_nme") > > data_source = > "Provider=SQLNCLI;Server=localhost;Database=RMS;Uid=user;Pwd=password;" > sql_insert = "insert into database.dbo.table (rest_nme) values ('" & > rest_nme & "')" > > ' Creating Connection Object and opening the database > Set con = CreateObject("ADODB.Connection") > con.Open data_source > con.Execute sql_insert > > ' Done. Close the connection > con.Close > Set con = Nothing > > I know for a fact that the form input is passed to the ASP page > correctly (if I post the form to email the value is correct), but the > row thats being written to the SQL DB is empty. From the empty row > thats being written I must assume that the connection string works and > I have no idea where the issue might lie. Any suggestions would be > much appreciated! written: sql_insert = "insert into database.dbo.table (rest_nme) values ('"mydata"')" Check your quotes - escape double quotes with single quotes as shown above and below. Also check if you need the entire database.dbo.table - you might just need table. Below is my exact insert string from an app I wrote. This was using an access database, so it might be slightly different. StrSQL = "INSERT INTO verify ([name], [training], [ip], [user]) VALUES ('" & tName & "','" & tTraining & "','" & tIP & "','" & tUser & "')" Just keep at it... something will get it clicking. |
| | Re: ASP form write to DB issue avdvyver@xxxxxx wrote: Quote: > Hi, > > I don't have much scripting experience and I need some help with a > simple piece of code. Basically, I have a html form with a input field > that posts the input to a ASP page (the ASP page must establish a > connection to a SQL database and write the input from the form to a > table). The content of the ASP page as follows: > > > ' Declaring variables > Dim rest_nme, data_source, con, sql_insert > > ' Receiving values from Form > rest_nme = Request.Form("rest_nme") > > data_source = > Quote: > sql_insert = "insert into database.dbo.table (rest_nme) values ('" & > rest_nme & "')" sql_insert = "insert into database.dbo.table (rest_nme) values (?)" Quote: > > ' Creating Connection Object and opening the database > Set con = CreateObject("ADODB.Connection") > con.Open data_source Set cmd = CreateObject("ADODB.Command") cmd.commandtext=sql_insert cmd.commandtype = 1 '1=adCmdText set cmd.activeconnection=con cmd.execute ,rest_nme, 128 '128=adExecuteNoRecords Quote: > ' Done. Close the connection > con.Close > Set con = Nothing > variant array. See this message for more info: Your use of dynamic sql is leaving you vulnerable to hackers using sql injection: http://mvp.unixwiz.net/techtips/sql-injection.html http://www.sqlsecurity.com/DesktopDefault.aspx?tabid=23 See here for a better, more secure way to execute your queries by using parameter markers (tokens): http://groups-beta.google.com/group/...e36562fee7804e Personally, I prefer using stored procedures http://groups.google.com/group/micro...09dc1701?hl=en http://groups.google.com/groups?hl=e...tngp13.phx.gbl http://groups.google.com/groups?hl=e...TNGP11.phx.gbl http://www.google.com/groups?selm=eE...&output=gplain http://www.google.com/groups?hl=en&l...TNGP12.phx.gbl Using Command object: http://groups-beta.google.com/group/...e36562fee7804e -- HTH, Bob Barrows |
| Cannot write to drive "Media is write protected" | Vista hardware & devices | |||
| how to get powershell to write to event log or write a log file? | PowerShell | |||
| Write-Error doesn't write anyting | PowerShell | |||
| The disk is write-protected. Remove the write-protection or... | Vista General | |||
| newline in Write-Debug or Write-Verbose | PowerShell | |||
