Vista - Group membership script not working-help
Old 11-25-2008   #1 (permalink)
Clubsprint
I'm trying to create a file with a list of all users in a group and it's not
working. I just end up with an empty file.
Start script
On Error Resume Next
Dim OrgUnit, GroupName, fso, f
Const ForReading = 1, ForWriting = 2, ForAppending = 8
Const OverwriteExisting = True
'delete existing copy of file
'Set objFSO = CreateObject("Scripting.FileSystemObject")
'objFSO.DeleteFile("C:\grouplist.txt")
OrgUnit = "Users"
GroupName = "Domain Users"
Set objGroup = GetObject _
'("LDAP://cn=Domain Users,cn=Users,dc=us,dc=com,dc=gov,dc=au")
For Each objMember in objGroup.Members
Set fso = CreateObject("Scripting.FileSystemObject")
Set f = fso.OpenTextFile("C:\groups\" & GroupName & ".txt", ForAppending,
True)
f.WriteLine objMember.Name
f.close
Next
MsgBox "File Created was C:\goups\" & GroupName & ".txt"
'Wscript.echo "Script Finished"
'start app
'RetVal = Process.Create (AppPath,WorkingDirectory,null,PID)
End Script
"Domain Users" is a group under the "Users"
I've also tried
(LDAP://cn=Domain Users,ou=Users,dc=us,dc=com,dc=gov,dc=ca)
What am I doing wrong?
Thanks
Old 11-25-2008   #2 (permalink)
Richard Mueller [MVP]
Re: Group membership script not working-help
"Clubsprint" <spamspamspamspam@xxxxxx> wrote in message
news:ggifit$po8$1@xxxxxx-01.bur.connect.com.au...
> not working. I just end up with an empty file.
> Start script
> OrgUnit = "Users"
> True)
> f.close
> Next
> 'start app
> End Script
> I've also tried
> Thanks
Most methods and attributes exposed by the LDAP provider, such as the
Members method of the group object, do not reveal membership in the
"primary" group. I would expect that all users in your domain have the group
"Domain Users" designated as their "primary". If so, the Members method of
the group object will return no member objects. The group will appear to be
empty.
An example VBScript program that enumerates all members of any group,
including membership due to group nesting and membership in the "primary"
group is linked here:
http://www.rlmueller.net/List%20Memb...0a%20Group.htm
If you don't want the membership due to nesting, comment out the recursive
call to Sub EnumGroup. The program retrieves the value of the
primaryGroupToken attribute of the designated group, then uses ADO to
retrieve all objects in AD that have the same value assigned to their
primaryGroupID attribute. This is probably the best way to determine all
objects (users, computers, groups) that have the group designated as their
"primary".
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
Old 11-26-2008   #3 (permalink)
Clubsprint
Thanks Richard. You saved the day again.
"Richard Mueller [MVP]" <rlmueller-nospam@xxxxxx> wrote in
message news:usww1n3TJHA.1172@xxxxxx
>> Start script
>> OrgUnit = "Users"
>> True)
>> f.close
>> Next
>> 'start app
>> End Script
>> I've also tried
>> Thanks
> group "Domain Users" designated as their "primary". If so, the Members
> method of the group object will return no member objects. The group will
> appear to be empty.
> "primary".
> Richard Mueller
check group membership PowerShell
Script to query user information based upon group membership VB Script
Get group membership PowerShell
Get Group Membership for a User PowerShell
Group Membership Vista mail
