Vista - Printer info
Old 12-02-2008   #1 (permalink)
Dave
Printer info
Is it possible to connect to a network printers and get information such as
serial number and model? I have the queue name and IP, but I need to get some
other info such as above. We have a mixture of many makes and models here and
the HP tool is causing some network issues so that's not an option. Thanks.
Old 12-02-2008   #2 (permalink)
Paul Weterings
Re: Printer info
use netsnmp and call that (snmpget) from vbscript
example from Nate Rice:
Function SNMPGET(vServer, vCommunityString, vOID)
On Error Resume Next
'This function will return the data from an SNMP get from the
specified
'server and the specified OID. The information will have to be parsed
'afterward. The info will be retuned as the string or variable
"SNMPGET".
'This script is provided under the Creative Commons license located
'at http://creativecommons.org/licenses/by-nc/2.5/ . It may not
'be used for commercial purposes with out the expressed written consent
'of NateRice.com
Const OpenAsDefault = -2
Const FailIfNotExist = 0
Const ForReading = 1
Set WshShell = CreateObject("WScript.Shell") 'Create filesystem objects
sTemp = WshShell.ExpandEnvironmentStrings("%TEMP%")
sTempFile = sTemp & "\runresult.tmp" 'Create working file string
'Run the SNMPGET command and save results to tmp file
WshShell.Run "%comspec% /C " & vSNMPGetPath & "\snmpget -c " & _
vCommunityString & " -v 1 " & vServer & " " & vOID & " > " & _
sTempFile, 0, True
'Read tmp file for snmpget results
Set oFSO = CreateObject("Scripting.FileSystemObject")
Set fFile = oFSO.OpenTextFile(sTempFile, ForReading, FailIfNotExist, _
OpenAsDefault)
SNMPGET = fFile.Readline
If InStr(SNMPGET, "STRING:") > 0 Then
aSNMPGET = Split(SNMPGET, "STRING:")
vTemp = Replace(Trim(aSNMPGET(1)), Chr(34), "")
SNMPGET = vTemp
ElseIf InStr(SNMPGET, "INTEGER:") > 0 Then
aSNMPGET = Split(SNMPGET, "INTEGER:")
vTemp = Trim(aSNMPGET(1))
vTemp = vTemp + 0
SNMPGET = vTemp
ElseIf InStr(SNMPGET, "IpAddress:") > 0 Then
aSNMPGET = Split(SNMPGET, "IpAddress:")
SNMPGET = vTemp
End If
fFile.Close
oFSO.DeleteFile (sTempFile)
End Function
/ ) Regards,
/ /_________
_|__|__) Paul Weterings
/ (O_) http://www.servercare.nl
__/ (O_)
____(O_)
Old 12-03-2008   #3 (permalink)
heintz.larry
Re: Printer info
On Dec 2, 3:19*pm, Paul Weterings <Paul-nospam-@xxxxxx-dot-com>
> * * *On Error Resume Next
> * * *'This function will return the data from an SNMP get from the
> specified
> * * *'server and the specified OID. The information will have to beparsed
> * * *'afterward. The info will be retuned as the string or variable
> "SNMPGET".
> * * *'This script is provided under the Creative Commons license located
> * * *'athttp://creativecommons.org/licenses/by-nc/2.5/. It may not
> * * *'be used for commercial purposes with out the expressed written consent
> * * *'of NateRice.com
> * * *Const OpenAsDefault = -2
> * * *Const FailIfNotExist = 0
> * * *Const ForReading = 1
> * * *Set WshShell = CreateObject("WScript.Shell") 'Create filesystem objects
> * * *sTemp = WshShell.ExpandEnvironmentStrings("%TEMP%")
> * * *sTempFile = sTemp & "\runresult.tmp" 'Create working file string
> * * *'Run the SNMPGET command and save results to tmp file
> * * *WshShell.Run "%comspec% /C " & vSNMPGetPath & "\snmpget -c " &_
> * * *vCommunityString & " -v 1 " & vServer & " " & vOID & " > " & _
> * * *sTempFile, 0, True
> * * *'Read tmp file for snmpget results
> * * *Set oFSO = CreateObject("Scripting.FileSystemObject")
> * * *Set fFile = oFSO.OpenTextFile(sTempFile, ForReading, FailIfNotExist, _
> * * *OpenAsDefault)
> * * *SNMPGET = fFile.Readline
> * * *If InStr(SNMPGET, "STRING:") > 0 Then
> * * * * *aSNMPGET = Split(SNMPGET, "STRING:")
> * * * * *vTemp = Replace(Trim(aSNMPGET(1)), Chr(34), "")
> * * * * *SNMPGET = vTemp
> * * *ElseIf InStr(SNMPGET, "INTEGER:") > 0 Then
> * * * * *aSNMPGET = Split(SNMPGET, "INTEGER:")
> * * * * *vTemp = Trim(aSNMPGET(1))
> * * * * *vTemp = vTemp + 0
> * * *ElseIf InStr(SNMPGET, "IpAddress:") > 0 Then
> * * * * *aSNMPGET = Split(SNMPGET, "IpAddress:")
> * * *End If
> * * *fFile.Close
> * * *oFSO.DeleteFile (sTempFile)
> End Function
> * / ) *Regards,
> / /_________
> * * * _|__|__) Paul Weterings
> * * / (O_) * *http://www.servercare.nl
> __/ *(O_)
> ____(O_)
You can try this as well.....
Dim computername,objWMIService,colItems,objItem
computername = "PUT_COMPUTERNAME_HERE"
Set objWMIService = GetObject("winmgmts:\\" & computername & "\root
\cimv2")
Set colItems = objWMIService.ExecQuery("Select * from Win32_Printer",,
48)
For Each objItem in colItems
Select Case objItem.DetectedErrorState
Case 4
ErrState = "Out of Paper"
Case 5
ErrState = "Toner low"
Case 6
ErrState = "Printing"
Case 9
ErrState = "Offline"
Case Else
ErrState = objItem.DetectedErrorState
End Select
wscript.echo "Name:" & objItem.Name
wscript.echo "Share Name:" & objItem.ShareName
wscript.echo "Comment:" & objItem.Comment
wscript.echo "Error State:" & ErrState
wscript.echo "Driver name:" & objItem.DriverName
wscript.echo "BIDI Enable:" & objItem.EnableBIDI
wscript.echo "Job Count Since Last Reset:" &
objItem.JobCountSinceLastReset
wscript.echo "Location:" & objItem.Location
wscript.echo "Port Name:" & objItem.PortName
wscript.echo "Published:" & objItem.Published
wscript.echo "Queued:" & objItem.Queued
wscript.echo "Shared:" & objItem.Shared
wscript.echo "Status:" & objItem.Status
wscript.echo "============================================"
Next
Set colItems = nothing
Set objWMIService = nothing
Larry
www.windowsadminscripts.com
w= cInt(left(info,inStr(info,"x") -1)) VB Script
Directory printer: Video info General Discussion
Please wait while the printer sends info. to Windows Vista print fax & scan
How do I change the administrator info and the registration info?? Vista account administration
Probs trying to use snmp to get info from printer PowerShell
