| | Advanced find and replace using VBScript Howdy, I posted this in another section and was recommended to make this post in the VBScript section. Since I can't find any programs to do what I'd like to do, I tried to experiment using DOS commands from within WinXP. I have 1,262 .htm files. Almost all of them have a headline that is surrounded by the exact same strings -- In the front: <font face="Arial" size="5"><b> And in the back: </b></font> Some have the tags in backwards order -- In the front: <b><font face="Arial" size="5"> And in the back: </font></b> Also, every single one of them has near the top of the file this: <title>News -- Commander, U.S. 7th Fleet</title> I'd like to replace the "News -- Commander, U.S. 7th Fleet" with the headline that is in between the tags I meantioned at the beginning of this post. So I tried a quick test using FIND. Something like: find *.htm "<title>" > "</title>" > test.txt Voila, everything that began with a <title> and ended with </title> was input into test.txt, and each file name was included too. I wasn't too worried that test.txt contained not only what was INSIDE the <title> tags but the tags themselves, because I can use FrontPage's "find and replace" later on to clean that up. When I tried something similar using the font tags I mentioned above, everything got kind of hairy. I believe it is because strings are supposed to be identified inside quotes and the tags contain quotes themselves, so FIND got confused. Even if it worked I wouldn't know what to do next. I would have a file called test.txt that contained all the headlines I wanted, but I wouldn't know how to put them inside the <title> tags. Can anyone help? I don't know anything about VBScript ... Thank you very much. |
| | Re: Advanced find and replace using VBScript Matthew Schwarz wrote: Quote: > Howdy, > > I posted this in another section and was recommended to make this post in > the VBScript section. > > Since I can't find any programs to do what I'd like to do, I tried to > experiment using DOS commands from within WinXP. > > I have 1,262 .htm files. Almost all of them have a headline that is > surrounded by the exact same strings -- > In the front: <font face="Arial" size="5"><b> > And in the back: </b></font> > > Some have the tags in backwards order -- > In the front: <b><font face="Arial" size="5"> > And in the back: </font></b> > > Also, every single one of them has near the top of the file this: > <title>News -- Commander, U.S. 7th Fleet</title> > > I'd like to replace the "News -- Commander, U.S. 7th Fleet" with the > headline that is in between the tags I meantioned at the beginning of this > post. > > So I tried a quick test using FIND. > > Something like: find *.htm "<title>" > "</title>" > test.txt > > Voila, everything that began with a <title> and ended with </title> was > input into test.txt, and each file name was included too. > > I wasn't too worried that test.txt contained not only what was INSIDE the > <title> tags but the tags themselves, because I can use FrontPage's "find Quote: > replace" later on to clean that up. > > When I tried something similar using the font tags I mentioned above, > everything got kind of hairy. I believe it is because strings are supposed Quote: > be identified inside quotes and the tags contain quotes themselves, so Quote: > got confused. > > Even if it worked I wouldn't know what to do next. I would have a file > called test.txt that contained all the headlines I wanted, but I wouldn't > know how to put them inside the <title> tags. > > Can anyone help? I don't know anything about VBScript ... > > Thank you very much. Then save this VBScript file in the same folder and double click it. Does it do what you want? 'ReTitle-htms.vbs Const ForReading = 1, ForWriting = 2 Set fso = CreateObject("Scripting.FileSystemObject") title = "<title>News -- Commander, U.S. 7th Fleet</title>" count = 0 Set f = fso.GetFolder(".") Set fc = f.Files For Each f1 in fc If Ucase(Right(f1.Name, 4)) = ".HTM" Then Set f2 = fso.OpenTextFile (f1.Name, ForReading) arr = Split(f2.Read(f1.Size), vbCRLF) f2.Close For i = 0 to Ubound(arr) headline = "" If Left(arr(i), 31) = "<font face=""Arial"" size=""5""><b>"_ And Right(arr(i), 11) = "</b></font>" Then headline = Mid(arr(i), 32, Len(arr(i)) - 42) Exit For ElseIf Left(arr(i), 31) = "<b><font face=""Arial"" size=""5"">"_ And Right(arr(i), 11) = "</font></b>" Then headline = Mid(arr(i), 32, Len(arr(i)) - 42) Exit For End If Next If Not headline = "" Then For i = 0 to Ubound(arr) If arr(i) = title Then arr(i) = "<title>" & Trim(headline) & "</title>" Set f2 = fso.OpenTextFile (f1.Name, ForWriting, True) f2.Write Join(arr, vbCRLF) f2.Close count = count + 1 Exit For End If Next End If End If Next Wscript.Echo count & " files have been modified." 'end of ReTitle-htms.vbs -- Todd Vargo (Post questions to group only. Remove "z" to email personal messages) |
| find/replace on file | VB Script | |||
| Find & Replace in MSSQL Tables through PowerShell | PowerShell | |||
| Find and Replace Utility ? | Vista General | |||
| Advanced search - How to find something between dates? | Vista General | |||
| Find/Replace | PowerShell | |||
