| | Please help with folder search and copy script Hi VBS-Grouü, i have to find a sollution for the following, but i am afraid that this task is too hard for me as a vbs newbie... There is a folder which contains files like "12345678_BlaBla.doc". Or Folder\Subfolder\12345678_BlaBla.doc There is an additional destination folder-structure like this: FolderName1\12345678\serverdocuments.doc FolderName1\45642354\serverdocuments.doc FolderName2\12345678\serverdocuments.doc FolderName3\43233242\serverdocuments.doc What i have to do is to go throu a path (Structure), dake the first 8 letters/numers of the filenames, search for folders with the same name as the 8letters/numbers part of the filename, and copy the file in each folder that matches. Thank you all in advance Kind Regards Thomas |
| | Re: Please help with folder search and copy script "Thomas Niemann" <niemann.thomas@xxxxxx> wrote in message news:4936696d$0$31343$9b4e6d93@xxxxxx-online.net... Quote: > Hi VBS-Grouü, > > i have to find a sollution for the following, but i am afraid that this > task is too hard for me as a vbs newbie... > > There is a folder which contains files like "12345678_BlaBla.doc". > Or Folder\Subfolder\12345678_BlaBla.doc > > There is an additional destination folder-structure like this: > > FolderName1\12345678\serverdocuments.doc > FolderName1\45642354\serverdocuments.doc > FolderName2\12345678\serverdocuments.doc > FolderName3\43233242\serverdocuments.doc > > What i have to do is to go throu a path (Structure), dake the first 8 > letters/numers of the filenames, search for folders with the same name as > the 8letters/numbers part of the filename, and copy the file in each > folder that matches. > > > Thank you all in advance > > Kind Regards > > Thomas - FolderName1\12345678\serverdocuments.doc - FolderName2\12345678\serverdocuments.doc Are you saying that you wish to copy this file to both folders? What if the file already exists in one or the other target folder? Also: While the name "serverdocuments.doc" is permissible for a folder name, it is rather unusual to give a folder a ".doc" extension. Is this really what you mean? Lastly: Does it matter if your source file resides in "C:\Folder" or in "C:\Folder\Subfolder"? In other words, is the file supposed to be copied to the same target folder, regardless of its source folder? |
| | Re: Please help with folder search and copy script > The first 8 characters of "12345678_BlaBla.doc" match two folders: Quote: > - FolderName1\12345678\serverdocuments.doc > - FolderName2\12345678\serverdocuments.doc > Are you saying that you wish to copy this file to both folders? What if > the file already exists in one or the other target folder? letters/numbers of the files name. Quote: > Also: While the name "serverdocuments.doc" is permissible for a folder > name, it is rather unusual to give a folder a ".doc" extension. Is this > really what you mean? Quote: > Lastly: Does it matter if your source file resides in "C:\Folder" or in > "C:\Folder\Subfolder"? In other words, is the file supposed to be copied > to the same target folder, regardless of its source folder? there are folders in the destination structure containing the first 8 letters/numbers and copy/move it into it |
| Context Menu - Add COPY TO FOLDER and MOVE TO FOLDER | Tutorials | |||
| please help with folder search and copy | VB Script | |||
| Copy User Profile with VBS Script problem | General Discussion | |||
| Re: VB Script Code to get alert when a folder get changed in intranet FTP Folder | VB Script | |||
| Re: Copying CD files to folder, then copy folder to another hard drive, explorer hangs | Vista file management | |||
