Vista - Help please Creat AD Group include description
Old 12-03-2008   #1 (permalink)
Clubsprint
Hi
I've hobbled together a script that creates AD groups from the contents of a
text file. I'm wondering how I can include
a description from the same text file?
script start================
Dim OrgUnit, GroupName, fso, f, objOU, objGroup
DIM sFile, oFSO, sText, oFile
Const ADS_GROUP_TYPE_GLOBAL_GROUP = &h2
Const ADS_GROUP_TYPE_SECURITY_ENABLED = &h80000000
Set oFSO = CreateObject("Scripting.FileSystemObject")
sFile = "C:\test1.txt"
If oFSO.FileExists(sFile) Then
Set oFile = oFSO.OpenTextFile(sFile, 1)
Set objOU = GetObject("LDAP://ou=Groups,dc=FABRIKAM,dc=COM")
Do While Not oFile.AtEndOfStream
GroupName = oFile.ReadLine
If Trim(GroupName) <> "" Then
Set objGroup = objOU.Create("Group", "cn="& GroupName)
objGroup.Put "sAMAccountName", GroupName
objGroup.Put "groupType", ADS_GROUP_TYPE_GLOBAL_GROUP Or _
objGroup.SetInfo
End If
Loop
oFile.Close
Else
WScript.Echo "C:\test1.txt does not exist."
End If
script end===========================
C:\test1.txt looks like this
EngDept Engineering Department
TechDef Technical Definitions
MoPool Motor Pool
HR Human Resources
etc.
Old 12-03-2008   #2 (permalink)
Richard Mueller [MVP]
Re: Help please Creat AD Group include description
Clubsprint wrote:
> a text file. I'm wondering how I can include
> objGroup.SetInfo
> End If
> Loop
> oFile.Close
> Else
> End If
> MoPool Motor Pool
> HR Human Resources
> etc.
Group objects have a description attribute. The trick is to parse each line
of your file to retrieve the values. One potential problem is that
sAMAccountName values can have spaces, so it can be difficult to tell where
the sAMAccountName ends and the description begins. In my example below, I
assume the sAMAccountNames have no embedded spaces, so the first space
delimits the two values.
A few notes. You bind to objOU twice in the script, and the second statement
gets executed for every line read from the file. You only need to bind once
(assuming all groups are created in the same OU). Also, you Dim a few unused
variables. And I would recommend using Option Explicit. My suggestion
follows:
Option Explicit
Dim GroupName, objOU, objGroup
Dim sFile, oFSO, oFile
Dim sLine, iIndex, sDesc
sLine = Trim(oFile.ReadLine)
If (sLine <> "") Then
' Parse line for sAMAccountName and description.
' It is assumed that the first space delimits the two values.
iIndex = InStr(sLine, " ")
GroupName = Left(sLine, iIndex - 1)
sDesc = Trim(Mid(sLine, iIndex + 1))
' Create the group and assign values.
Set objGroup = objOU.Create("Group", "cn=" & GroupName)
objGroup.Put "description", sDesc
objGroup.SetInfo
End If
Loop
oFile.Close
Else
End If
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
Old 12-04-2008   #3 (permalink)
Clubsprint
Thanks Richard. as usual a whole lot of help plus some education as well.
I was trying to do it with the split function and failing dismally.
Mark
"Richard Mueller [MVP]" <rlmueller-nospam@xxxxxx> wrote in
message news:uK0Uw8bVJHA.5420@xxxxxx
Quote:
> Clubsprint wrote:
>> of a text file. I'm wondering how I can include
>> objGroup.SetInfo
>> End If
>> Loop
>> oFile.Close
>> Else
>> End If
>> MoPool Motor Pool
>> HR Human Resources
>> etc.
> line of your file to retrieve the values. One potential problem is that
> where the sAMAccountName ends and the description begins. In my example
> below, I assume the sAMAccountNames have no embedded spaces, so the first
> statement gets executed for every line read from the file. You only need
> to bind once (assuming all groups are created in the same OU). Also, you
> Dim a few unused variables. And I would recommend using Option Explicit.
> My suggestion follows:
> Option Explicit
> objGroup.SetInfo
> End If
> Loop
> oFile.Close
> Else
> End If
> Richard Mueller
Old 12-04-2008   #4 (permalink)
I first thought of using Split, but your example had too many space
characters. I can't tell if the file uses tab characters, but if so, you
might be able to use that in the Split function. Or, if the description
starts at a specific column (which did not appear to be the case), you might
use that. I mention this as my method will fail if the group name has
embedded spaces, which is possible. For example, if one row in the file is:
Test Group Group to test applications
there may be no reliable way to parse it. If the values are delimited by tab
characters, you might try Split(sLine, vbTab).
Richard Mueller
"Clubsprint" <spamspamspamspam@xxxxxx> wrote in message
news:gh9qo3$qp7$1@xxxxxx-01.bur.connect.com.au...
> Mark
>>> objGroup.SetInfo
>>> End If
>>> Loop
>>> oFile.Close
>>> Else
>>> End If
>>> MoPool Motor Pool
>>> HR Human Resources
>>> etc.
>> Option Explicit
>> objGroup.SetInfo
>> End If
>> Loop
>> oFile.Close
>> Else
>> End If
>> Richard Mueller
Error 183 Unable to creat new folder Vista General
add user to group /group scope - Global /Group type - Security PowerShell
creat account Vista mail
Help. Can't creat photo emails Live Mail
cannot creat new mail Vista mail
