Vista - script to extract and create contacts
Old 12-10-2008   #1 (permalink)
Guillermo G. Lovato
i need a script similar to this one:
http://www.microsoft.com/technet/scr...8/hey0605.mspx
but instead of outputing to .msg each contact i need to create them in a
contact subfolder of my choice, how do i do that?
Old 12-10-2008   #2 (permalink)
Pegasus \(MVP\)
Re: script to extract and create contacts
"Guillermo G. Lovato" <glovato@xxxxxx> wrote in message
news:uOgLZlrWJHA.1184@xxxxxx
This link might work for you:
How Can I Convert an Outlook Email Message into a Text File
http://www.microsoft.com/technet/scr...5/hey1205.mspx
If not then I recommend you download the whole Scripting Guy file and check
it for other items that have the word "Outlook" inside.
Old 12-11-2008   #3 (permalink)
Guillermo G. Lovato
Exporting it to text is of no use as importing it back is tiresome as it
doesn't exports as CSV and the import isn't direct and botchy at best(cuts
the names, choses name/last name wrong, etc).
i've already checked the scripting guy archive and there's nothing on
creating MAPI contacts, hence my question here, i have the first half which
is exporting, i need the rest now
"Pegasus (MVP)" <I.can@xxxxxx> wrote in message
news:eps4OmuWJHA.256@xxxxxx
> check it for other items that have the word "Outlook" inside.
Windows Live Mail Desktop - Can't create or edit contacts or send topeople in contacts list Live Mail
Script to extract XML data VB Script
how to create a new vpn connection using script o batch VB Script
Powershell Script to extract drive information PowerShell
Script to extract username from path statement PowerShell
