Vista - ADSI: Making an Explicit Call to GetInfoEx and Enumerating Results
Old 12-10-2008   #1 (permalink)
Larry
"Rather than download most attributes of an object, you can selectively load
or refresh the local property cache with a specific attribute or set of
attributes by using the GetInfoEx method."
Desired output, the actual Active Directory values for the attributes in the
array.
CODE:
Set objUser = GetObject _
("LDAP://cn=TestUser, ou=Users, OU=Sbd, dc=us, dc=Fabrikam, dc=com")
arrAttributes = Array("description", "name")
objUser.GetInfoEx arrAttributes, 0
For Each Attribute In arrAttributes
WScript.Echo Attribute
Next
EXPECTED OUTPUT:
Account used for testing.
TestUser
ACTUAL OUTPUT:
description
name
What am I misunderstanding? The array shouldn't actually be composed of the
strings "description" and "name" but the returned values of those AD
attributes.
Old 12-10-2008   #2 (permalink)
Richard Mueller [MVP]
Re: Making an Explicit Call to GetInfoEx and Enumerating Results
"Larry" <Larry@xxxxxx> wrote in message
news:74A40BA2-7F23-4CA9-B6D9-7D722E99F89E@xxxxxx
> load
> the
> array.
> CODE:
> Next
> EXPECTED OUTPUT:
> TestUser
> ACTUAL OUTPUT:
> description
> name
> the
> attributes.
The array itself is unchanged by the GetInfoEx method. Instead, all values
are cached. You then can use the Get method to retrieve the values. For
example:
WScript.Echo objUser.Get("Attribute")
Next
The main reason I am aware of to use the GetInfoEx method is to retrieve the
value of operational attributes (also called constructed). The GetInfoEx
method forces AD to calculate the values.
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
Old 12-10-2008   #3 (permalink)
"Richard Mueller [MVP]" <rlmueller-nospam@xxxxxx> wrote in
message news:utsLPVuWJHA.5064@xxxxxx
>> load
>> the
>> array.
>> CODE:
>> Next
>> EXPECTED OUTPUT:
>> TestUser
>> ACTUAL OUTPUT:
>> description
>> name
>> the
>> attributes.
> example:
> Next
> the value of operational attributes (also called constructed). The
> GetInfoEx method forces AD to calculate the values.
> Richard Mueller
I should point out that in this case, with attributes description and name,
the GetInfoEx method is not required. It simply loads the attribute values
into the cache (local memory). The advantage is that all of the values are
retrieved at once, in one request to AD, rather than one request per
attribute. The Get method retrieves the values from the cache first, and
only requests from AD if the value is not already in the cache.
Richard Mueller
Old 12-10-2008   #4 (permalink)
Larry
Thanks for clearing that up.
> > load
> > the
> > array.
> > CODE:
> > Next
> > EXPECTED OUTPUT:
> > TestUser
> > ACTUAL OUTPUT:
> > description
> > name
> > the
> > attributes.
> example:
> Next
> Richard Mueller
Error when making video call - (0x8100039d) Live Messenger
having a problem with making a video call Live Messenger
call of duty 4....making me ill ??? Gaming
Enumerating group membership & ADSI PowerShell
RE: Option Explicit PowerShell
