| | csccmd not running in script Hello, I am editing a script to move users to a new file share. The changes to the new server work fine, but the last part of the script to change the offline files server never seems to run. WshShell.Run "c:\csccmd.exe /moveshare:\\OldShare\%username%$ \\DFS\user\shares\%username%" Never seems to run. Is there something wrong with this line or is their something I am missing. I'm on a deadline any help is appreciated. |
| | Re: csccmd not running in script "wcmulligan" <wcmulligan@xxxxxx> wrote in message news:CEDB4345-D420-4F3D-BDD5-64716B7C5651@xxxxxx Quote: > Hello, > > I am editing a script to move users to a new file share. The changes to > the > new server work fine, but the last part of the script to change the > offline > files server never seems to run. > > WshShell.Run "c:\csccmd.exe /moveshare:\\OldShare\%username%$ > \\DFS\user\shares\%username%" > > Never seems to run. Is there something wrong with this line or is their > something I am missing. > > I'm on a deadline any help is appreciated. the wshShell object. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| | Re: csccmd not running in script Thank you Richard, but this didn't do the trick either. I can run csccmd /moveshare:\\OldShare\%sername%$ \\DFS\user\shares\%username% from the command line or a batch file, but I can't get it to run in a script. I've checked and it runs up to the point of the command and then stops. Anyone have any ideas that might help? "Richard Mueller [MVP]" wrote: Quote: > > "wcmulligan" <wcmulligan@xxxxxx> wrote in message > news:CEDB4345-D420-4F3D-BDD5-64716B7C5651@xxxxxx Quote: > > Hello, > > > > I am editing a script to move users to a new file share. The changes to > > the > > new server work fine, but the last part of the script to change the > > offline > > files server never seems to run. > > > > WshShell.Run "c:\csccmd.exe /moveshare:\\OldShare\%username%$ > > \\DFS\user\shares\%username%" > > > > Never seems to run. Is there something wrong with this line or is their > > something I am missing. > > > > I'm on a deadline any help is appreciated. > I always prefix commands with "%comspec% /c" when I use the Run method of > the wshShell object. > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab - http://www.rlmueller.net > -- > > > |
| | Re: csccmd not running in script I'm not familiar with the csccmd utility, but the %username% environment variable resolves correctly when I run commands with the Run method. I would use: strCmd = "%comspec% /c csccmd /moveshare:\\OldShare\%username%$ \\DFS\user\shares\%username%" Set objShell = CreateObject("Wscript.Shell") intReturn = objShell.Run(strCmd, 2, True) Wscript.Echo "Return code: " & CStr(intReturn) The parameter "2" means to run minimized. The "True" means to wait for the command to complete so we can retrieve the return code. This way we can echo the return code. If it is non-zero, the csccmd returned an error code that may help troubleshoot. One possibility is that there is a permission issue. If the OS is Vista, for example, you may need to use "Run as Administrator" when you run the script. Being logged in as Administrator means nothing in Vista. Also, is csccmd on the path? If not, you should include the path in the command. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- "wcmulligan" <wcmulligan@xxxxxx> wrote in message news:244C53E3-8A62-420B-9405-02E407BA57B0@xxxxxx Quote: > Thank you Richard, but this didn't do the trick either. > > I can run csccmd /moveshare:\\OldShare\%sername%$ > \\DFS\user\shares\%username% from the command line or a batch file, but I > can't get it to run in a script. > > I've checked and it runs up to the point of the command and then stops. > > Anyone have any ideas that might help? > > "Richard Mueller [MVP]" wrote: > Quote: >> >> "wcmulligan" <wcmulligan@xxxxxx> wrote in message >> news:CEDB4345-D420-4F3D-BDD5-64716B7C5651@xxxxxx Quote: >> > Hello, >> > >> > I am editing a script to move users to a new file share. The changes >> > to >> > the >> > new server work fine, but the last part of the script to change the >> > offline >> > files server never seems to run. >> > >> > WshShell.Run "c:\csccmd.exe /moveshare:\\OldShare\%username%$ >> > \\DFS\user\shares\%username%" >> > >> > Never seems to run. Is there something wrong with this line or is >> > their >> > something I am missing. >> > >> > I'm on a deadline any help is appreciated. >> I always prefix commands with "%comspec% /c" when I use the Run method of >> the wshShell object. >> >> -- >> Richard Mueller >> MVP Directory Services >> Hilltop Lab - http://www.rlmueller.net >> -- >> >> >> |
| | Re: csccmd not running in script Thanks again Richard, but I don't get a return value. I moved the code around a little so that csccmd runs before anything else and I get no echo. I do get an echo in other parts of the script, so I don't know why it is not working. I am running the command with full admin priveledges on an xp box for testing. this util won't work with Vista. FYI here is a link to Microsoft's csccmd.exe syntax http://support.microsoft.com/default.aspx/kb/884739 "Richard Mueller [MVP]" wrote: Quote: > I'm not familiar with the csccmd utility, but the %username% environment > variable resolves correctly when I run commands with the Run method. I would > use: > > strCmd = "%comspec% /c csccmd /moveshare:\\OldShare\%username%$ > \\DFS\user\shares\%username%" > Set objShell = CreateObject("Wscript.Shell") > intReturn = objShell.Run(strCmd, 2, True) > Wscript.Echo "Return code: " & CStr(intReturn) > > The parameter "2" means to run minimized. The "True" means to wait for the > command to complete so we can retrieve the return code. This way we can echo > the return code. If it is non-zero, the csccmd returned an error code that > may help troubleshoot. > > One possibility is that there is a permission issue. If the OS is Vista, for > example, you may need to use "Run as Administrator" when you run the script. > Being logged in as Administrator means nothing in Vista. Also, is csccmd on > the path? If not, you should include the path in the command. > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab - http://www.rlmueller.net > -- > > "wcmulligan" <wcmulligan@xxxxxx> wrote in message > news:244C53E3-8A62-420B-9405-02E407BA57B0@xxxxxx Quote: > > Thank you Richard, but this didn't do the trick either. > > > > I can run csccmd /moveshare:\\OldShare\%sername%$ > > \\DFS\user\shares\%username% from the command line or a batch file, but I > > can't get it to run in a script. > > > > I've checked and it runs up to the point of the command and then stops. > > > > Anyone have any ideas that might help? > > > > "Richard Mueller [MVP]" wrote: > > Quote: > >> > >> "wcmulligan" <wcmulligan@xxxxxx> wrote in message > >> news:CEDB4345-D420-4F3D-BDD5-64716B7C5651@xxxxxx > >> > Hello, > >> > > >> > I am editing a script to move users to a new file share. The changes > >> > to > >> > the > >> > new server work fine, but the last part of the script to change the > >> > offline > >> > files server never seems to run. > >> > > >> > WshShell.Run "c:\csccmd.exe /moveshare:\\OldShare\%username%$ > >> > \\DFS\user\shares\%username%" > >> > > >> > Never seems to run. Is there something wrong with this line or is > >> > their > >> > something I am missing. > >> > > >> > I'm on a deadline any help is appreciated. > >> > >> I always prefix commands with "%comspec% /c" when I use the Run method of > >> the wshShell object. > >> > >> -- > >> Richard Mueller > >> MVP Directory Services > >> Hilltop Lab - http://www.rlmueller.net > >> -- > >> > >> > >> > > |
| | #6 (permalink) |
| | Re: csccmd not running in script On Dec 18, 1:33*pm, wcmulligan <wcmulli...@xxxxxx> wrote: Quote: > Thanks again Richard, but I don't get a return value. > > I moved the code around a little so that csccmd runs before anything else > and I get no echo. *I do get an echo in other parts of the script, so Idon't > know why it is not working. > > I am running the command with full admin priveledges on an xp box for > testing. this util won't work with Vista. > > FYI here is a link to Microsoft's csccmd.exe syntaxhttp://support.microsoft.com/default.aspx/kb/884739 > > "Richard Mueller [MVP]" wrote: Quote: > > I'm not familiar with the csccmd utility, but the %username% environment > > variable resolves correctly when I run commands with the Run method. I would > > use: Quote: > > strCmd = "%comspec% /c csccmd /moveshare:\\OldShare\%username%$ > > \\DFS\user\shares\%username%" > > Set objShell = CreateObject("Wscript.Shell") > > intReturn = objShell.Run(strCmd, 2, True) > > Wscript.Echo "Return code: " & CStr(intReturn) Quote: > > The parameter "2" means to run minimized. The "True" means to wait for the > > command to complete so we can retrieve the return code. This way we canecho > > the return code. If it is non-zero, the csccmd returned an error code that > > may help troubleshoot. Quote: > > One possibility is that there is a permission issue. If the OS is Vista, for > > example, you may need to use "Run as Administrator" when you run the script. > > Being logged in as Administrator means nothing in Vista. Also, is csccmd on > > the path? If not, you should include the path in the command. Quote: > > -- > > Richard Mueller > > MVP Directory Services > > Hilltop Lab -http://www.rlmueller.net > > -- Quote: > > "wcmulligan" <wcmulli...@xxxxxx> wrote in message > >news:244C53E3-8A62-420B-9405-02E407BA57B0@xxxxxx Quote: > > > Thank you Richard, but this didn't do the trick either. Quote: Quote: > > > I can run csccmd /moveshare:\\OldShare\%sername%$ > > > \\DFS\user\shares\%username% *from the command line or a batch file, but I > > > can't get it to run in a script. Quote: Quote: > > > I've checked and it runs up to the point of the command and then stops. Quote: Quote: > > > Anyone have any ideas that might help? Quote: Quote: > > > "Richard Mueller [MVP]" wrote: Quote: Quote: > > >> "wcmulligan" <wcmulli...@xxxxxx> wrote in message > > >>news:CEDB4345-D420-4F3D-BDD5-64716B7C5651@xxxxxx > > >> > Hello, Quote: Quote: > > >> > I am editing a script to move users to a new file share. *The changes > > >> > to > > >> > the > > >> > new server work fine, but the last part of the script to change the > > >> > offline > > >> > files server never seems to run. Quote: Quote: > > >> > WshShell.Run "c:\csccmd.exe /moveshare:\\OldShare\%username%$ > > >> > \\DFS\user\shares\%username%" Quote: Quote: > > >> > Never seems to run. *Is there something wrong with this line or is > > >> > their > > >> > something I am missing. Quote: Quote: > > >> > I'm on a deadline any help is appreciated. Quote: Quote: > > >> I always prefix commands with "%comspec% /c" when I use the Run method of > > >> the wshShell object. Quote: Quote: > > >> -- > > >> Richard Mueller > > >> MVP Directory Services > > >> Hilltop Lab -http://www.rlmueller.net > > >> -- logged in user? Is the error trapping disabled in the script disabled? If so, re-enable it (remove ON ERROR RESUME NEXT line) and report what the real error is. I say that because you say you get no output, when you really should. Finally, can you show us the EXACT (cut and paste) code for the objShell.Run line (with Richard's proposed fix - which is correct)? Someone might see something you've missed. Tom Lavedas *********** http://there.is.no.more/tglbatch/ |
| | #7 (permalink) |
| | Re: csccmd not running in script "wcmulligan" <wcmulligan@xxxxxx> wrote in message news:3C72CBCD-3778-4258-8F18-4CBED452F04C@xxxxxx Quote: > Thanks again Richard, but I don't get a return value. > > I moved the code around a little so that csccmd runs before anything else > and I get no echo. I do get an echo in other parts of the script, so I > don't > know why it is not working. > > I am running the command with full admin priveledges on an xp box for > testing. this util won't work with Vista. > > FYI here is a link to Microsoft's csccmd.exe syntax > http://support.microsoft.com/default.aspx/kb/884739 > > "Richard Mueller [MVP]" wrote: > Quote: >> I'm not familiar with the csccmd utility, but the %username% environment >> variable resolves correctly when I run commands with the Run method. I >> would >> use: >> >> strCmd = "%comspec% /c csccmd /moveshare:\\OldShare\%username%$ >> \\DFS\user\shares\%username%" >> Set objShell = CreateObject("Wscript.Shell") >> intReturn = objShell.Run(strCmd, 2, True) >> Wscript.Echo "Return code: " & CStr(intReturn) >> >> The parameter "2" means to run minimized. The "True" means to wait for >> the >> command to complete so we can retrieve the return code. This way we can >> echo >> the return code. If it is non-zero, the csccmd returned an error code >> that >> may help troubleshoot. >> >> One possibility is that there is a permission issue. If the OS is Vista, >> for >> example, you may need to use "Run as Administrator" when you run the >> script. >> Being logged in as Administrator means nothing in Vista. Also, is csccmd >> on >> the path? If not, you should include the path in the command. >> >> -- >> Richard Mueller >> MVP Directory Services >> Hilltop Lab - http://www.rlmueller.net >> -- >> >> "wcmulligan" <wcmulligan@xxxxxx> wrote in message >> news:244C53E3-8A62-420B-9405-02E407BA57B0@xxxxxx Quote: >> > Thank you Richard, but this didn't do the trick either. >> > >> > I can run csccmd /moveshare:\\OldShare\%sername%$ >> > \\DFS\user\shares\%username% from the command line or a batch file, >> > but I >> > can't get it to run in a script. >> > >> > I've checked and it runs up to the point of the command and then stops. >> > >> > Anyone have any ideas that might help? >> > >> > "Richard Mueller [MVP]" wrote: >> > >> >> >> >> "wcmulligan" <wcmulligan@xxxxxx> wrote in message >> >> news:CEDB4345-D420-4F3D-BDD5-64716B7C5651@xxxxxx >> >> > Hello, >> >> > >> >> > I am editing a script to move users to a new file share. The >> >> > changes >> >> > to >> >> > the >> >> > new server work fine, but the last part of the script to change the >> >> > offline >> >> > files server never seems to run. >> >> > >> >> > WshShell.Run "c:\csccmd.exe /moveshare:\\OldShare\%username%$ >> >> > \\DFS\user\shares\%username%" >> >> > >> >> > Never seems to run. Is there something wrong with this line or is >> >> > their >> >> > something I am missing. >> >> > >> >> > I'm on a deadline any help is appreciated. >> >> >> >> I always prefix commands with "%comspec% /c" when I use the Run method >> >> of >> >> the wshShell object. >> >> >> >> -- >> >> Richard Mueller >> >> MVP Directory Services >> >> Hilltop Lab - http://www.rlmueller.net >> >> -- >> >> >> >> >> >> command you scripted: c:\csccmd.exe /moveshare:\\OldShare\%username%$ \\DFS\user\shares\%username%" csccmd /moveshare:\\OldShare\%sername%$ \\DFS\user\shares\%username% The scripted command states explicitly the location of csccmd.exe. The manual command relies on the %path%. It gives no file extension. It also refers to %sername% instead of %username%, which is probably a typo. Questions: - Where does csccmd reside? - Is it an .exe file or is it something else? Lastly: If the command runs while embedded in a batch file then you could take a pragmatic view and invoke that batch file from your script. To avoid having to maintain two files, you could generate the batch file from within your script with a single writeline statement. |
| error running script | PowerShell | |||
| Running PowerShell script from within an MSI? | PowerShell | |||
| Logon script not running? | Vista General | |||
| trouble running a script | PowerShell | |||
| Help on running a a script | PowerShell | |||
