| | Vista - Script Execution Over Network |
| 12-19-2008 | #1 |
| | Script Execution Over Network I'm currently working on revising my company's logon script. When a user logs on, a remote batch file is executed that checks if the client already has a file named "logonscript.vbs" on their PC. If they do, it generates and compares the CRC checksum of the file to a "logonscript.vbs" that exists on the domain controller. If the two CRCs match, we know that the client has the latest version of the script. However, if they do not, the latest version of the script is copied from the domain controller to the client, and then executed by the client workstation. This seems like a lot of back-and-forth to me, and I'm having trouble gauging whether it's the most efficient way of doing things. Part of me wants to simplify things by simply running "logonscript.vbs" from the domain controller without making a copy on the client's PC first. This would eliminate the need to perform a CRC checksum comparison. Is there a way for me to figure out how much bandwidth this would cost on a per-logon basis? Any thoughts or suggestions? I'm pulling my hair out over this (it doesn't really need much help, though, but that's a separate issue entirely). Thanks in advance. |
| My System Specs |
| 12-19-2008 | #2 |
| | Re: Script Execution Over Network "Justin R." <JRusbatch@xxxxxx> wrote in message news:9e2823a0-65b3-4495-bc99-b4fcb984fd4d@xxxxxx Quote: > I'm currently working on revising my company's logon script. When a > user logs on, a remote batch file is executed that checks if the > client already has a file named "logonscript.vbs" on their PC. If > they do, it generates and compares the CRC checksum of the file to a > "logonscript.vbs" that exists on the domain controller. If the two > CRCs match, we know that the client has the latest version of the > script. However, if they do not, the latest version of the script is > copied from the domain controller to the client, and then executed by > the client workstation. > > This seems like a lot of back-and-forth to me, and I'm having trouble > gauging whether it's the most efficient way of doing things. Part of > me wants to simplify things by simply running "logonscript.vbs" from > the domain controller without making a copy on the client's PC first. > This would eliminate the need to perform a CRC checksum comparison. > Is there a way for me to figure out how much bandwidth this would cost > on a per-logon basis? Any thoughts or suggestions? I'm pulling my > hair out over this (it doesn't really need much help, though, but > that's a separate issue entirely). > > Thanks in advance. minimal. What is the size of your script? A few kBytes? Trivial! Remember: A 100 MBits Ethernet can transfer up to 10 MBytes per second. If you're still reluctant to have your script reside on the server then you could use "xcopy.exe /d" to ensure that the user has the latest version of the script. This is a single line of code and it is much simpler than creating and comparing CRC checksums. |
| My System Specs |
| 12-19-2008 | #3 |
| | Re: Script Execution Over Network "Pegasus (MVP)" <I.can@xxxxxx> wrote in message news:OHiOBMeYJHA.5156@xxxxxx Quote: > > "Justin R." <JRusbatch@xxxxxx> wrote in message > news:9e2823a0-65b3-4495-bc99-b4fcb984fd4d@xxxxxx Quote: >> I'm currently working on revising my company's logon script. When a >> user logs on, a remote batch file is executed that checks if the >> client already has a file named "logonscript.vbs" on their PC. If >> they do, it generates and compares the CRC checksum of the file to a >> "logonscript.vbs" that exists on the domain controller. If the two >> CRCs match, we know that the client has the latest version of the >> script. However, if they do not, the latest version of the script is >> copied from the domain controller to the client, and then executed by >> the client workstation. >> >> This seems like a lot of back-and-forth to me, and I'm having trouble >> gauging whether it's the most efficient way of doing things. Part of >> me wants to simplify things by simply running "logonscript.vbs" from >> the domain controller without making a copy on the client's PC first. >> This would eliminate the need to perform a CRC checksum comparison. >> Is there a way for me to figure out how much bandwidth this would cost >> on a per-logon basis? Any thoughts or suggestions? I'm pulling my >> hair out over this (it doesn't really need much help, though, but >> that's a separate issue entirely). >> >> Thanks in advance. > Unless you have a huge logon script, the bandwidth requirements would be > minimal. What is the size of your script? A few kBytes? Trivial! Remember: > A 100 MBits Ethernet can transfer up to 10 MBytes per second. > > If you're still reluctant to have your script reside on the server then > you could use "xcopy.exe /d" to ensure that the user has the latest > version of the script. This is a single line of code and it is much > simpler than creating and comparing CRC checksums. > -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| My System Specs |
| 12-19-2008 | #4 |
| | Re: Script Execution Over Network On Dec 19, 12:46*pm, "Richard Mueller [MVP]" <rlmueller- nos...@xxxxxx> wrote: Quote: > "Pegasus (MVP)" <I....@xxxxxx> wrote in message > > news:OHiOBMeYJHA.5156@xxxxxx > > > > > Quote: > > "Justin R." <JRusba...@xxxxxx> wrote in message > >news:9e2823a0-65b3-4495-bc99-b4fcb984fd4d@xxxxxx Quote: > >> I'm currently working on revising my company's logon script. *When a > >> user logs on, a remote batch file is executed that checks if the > >> client already has a file named "logonscript.vbs" on their PC. *If > >> they do, it generates and compares the CRC checksum of the file to a > >> "logonscript.vbs" that exists on the domain controller. *If the two > >> CRCs match, we know that the client has the latest version of the > >> script. *However, if they do not, the latest version of the script is > >> copied from the domain controller to the client, and then executed by > >> the client workstation. Quote: Quote: > >> This seems like a lot of back-and-forth to me, and I'm having trouble > >> gauging whether it's the most efficient way of doing things. *Part of > >> me wants to simplify things by simply running "logonscript.vbs" from > >> the domain controller without making a copy on the client's PC first. > >> This would eliminate the need to perform a CRC checksum comparison. > >> Is there a way for me to figure out how much bandwidth this would cost > >> on a per-logon basis? *Any thoughts or suggestions? *I'm pulling my > >> hair out over this (it doesn't really need much help, though, but > >> that's a separate issue entirely). Quote: Quote: > >> Thanks in advance. Quote: > > Unless you have a huge logon script, the bandwidth requirements would be > > minimal. What is the size of your script? A few kBytes? Trivial! Remember: > > A 100 MBits Ethernet can transfer up to 10 MBytes per second. Quote: > > If you're still reluctant to have your script reside on the server then > > you could use "xcopy.exe /d" to ensure that the user has the latest > > version of the script. This is a single line of code and it is much > > simpler than creating and comparing CRC checksums. > Of course there is the bandwidth required to copy the logon script. > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab -http://www.rlmueller.net > -- your point was that simple. Can you elaborate, Richard? |
| My System Specs |
| 12-19-2008 | #5 |
| | Re: Script Execution Over Network "Justin R." <JRusbatch@xxxxxx> wrote in message news:f0db0038-7739-4369-97cd-96d0865c5f71@xxxxxx On Dec 19, 12:46 pm, "Richard Mueller [MVP]" <rlmueller- nos...@xxxxxx> wrote: Quote: > "Pegasus (MVP)" <I....@xxxxxx> wrote in message > > news:OHiOBMeYJHA.5156@xxxxxx > > > > > Quote: > > "Justin R." <JRusba...@xxxxxx> wrote in message > >news:9e2823a0-65b3-4495-bc99-b4fcb984fd4d@xxxxxx Quote: > >> I'm currently working on revising my company's logon script. When a > >> user logs on, a remote batch file is executed that checks if the > >> client already has a file named "logonscript.vbs" on their PC. If > >> they do, it generates and compares the CRC checksum of the file to a > >> "logonscript.vbs" that exists on the domain controller. If the two > >> CRCs match, we know that the client has the latest version of the > >> script. However, if they do not, the latest version of the script is > >> copied from the domain controller to the client, and then executed by > >> the client workstation. Quote: Quote: > >> This seems like a lot of back-and-forth to me, and I'm having trouble > >> gauging whether it's the most efficient way of doing things. Part of > >> me wants to simplify things by simply running "logonscript.vbs" from > >> the domain controller without making a copy on the client's PC first. > >> This would eliminate the need to perform a CRC checksum comparison. > >> Is there a way for me to figure out how much bandwidth this would cost > >> on a per-logon basis? Any thoughts or suggestions? I'm pulling my > >> hair out over this (it doesn't really need much help, though, but > >> that's a separate issue entirely). Quote: Quote: > >> Thanks in advance. Quote: > > Unless you have a huge logon script, the bandwidth requirements would be > > minimal. What is the size of your script? A few kBytes? Trivial! > > Remember: > > A 100 MBits Ethernet can transfer up to 10 MBytes per second. Quote: > > If you're still reluctant to have your script reside on the server then > > you could use "xcopy.exe /d" to ensure that the user has the latest > > version of the script. This is a single line of code and it is much > > simpler than creating and comparing CRC checksums. > Of course there is the bandwidth required to copy the logon script. > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab -http://www.rlmueller.net > -- your point was that simple. Can you elaborate, Richard? ------ I don't know the details, so I hesitate to say too much. However, I think more bandwidth is required to copy a program than to execute the program. When a program is run it is loaded into memory, which is fast, so the transfer over the network doesn't need to wait much. A logon script should run from local memory. When a program is copied the local drive controller is the bottleneck. The same number of bytes are transferred, but more traffic may be needed. Long ago when we had 10 Mbps networks and 100 MHz clients we never had trouble running logon scripts over the network, even when many people logged on at once (such as after a server reboot). And we had some elaborate logon scripts. The exception was logon scripts that installed software over the network. That caused problems. My recollection is that batch files are loaded and run one line at a time, but VBScript programs (and all *.exe programs) are loaded all at once and then run. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| My System Specs |
| 12-19-2008 | #6 |
| | Re: Script Execution Over Network "Richard Mueller [MVP]" <rlmueller-nospam@xxxxxx> wrote in message news:uKE6YEiYJHA.5476@xxxxxx Quote: > > "Justin R." <JRusbatch@xxxxxx> wrote in message > news:f0db0038-7739-4369-97cd-96d0865c5f71@xxxxxx > On Dec 19, 12:46 pm, "Richard Mueller [MVP]" <rlmueller- > nos...@xxxxxx> wrote: Quote: >> "Pegasus (MVP)" <I....@xxxxxx> wrote in message >> >> news:OHiOBMeYJHA.5156@xxxxxx >> >> >> >> >> Quote: >> > "Justin R." <JRusba...@xxxxxx> wrote in message >> >news:9e2823a0-65b3-4495-bc99-b4fcb984fd4d@xxxxxx >> >> I'm currently working on revising my company's logon script. When a >> >> user logs on, a remote batch file is executed that checks if the >> >> client already has a file named "logonscript.vbs" on their PC. If >> >> they do, it generates and compares the CRC checksum of the file to a >> >> "logonscript.vbs" that exists on the domain controller. If the two >> >> CRCs match, we know that the client has the latest version of the >> >> script. However, if they do not, the latest version of the script is >> >> copied from the domain controller to the client, and then executed by >> >> the client workstation. Quote: >> >> This seems like a lot of back-and-forth to me, and I'm having trouble >> >> gauging whether it's the most efficient way of doing things. Part of >> >> me wants to simplify things by simply running "logonscript.vbs" from >> >> the domain controller without making a copy on the client's PC first. >> >> This would eliminate the need to perform a CRC checksum comparison. >> >> Is there a way for me to figure out how much bandwidth this would cost >> >> on a per-logon basis? Any thoughts or suggestions? I'm pulling my >> >> hair out over this (it doesn't really need much help, though, but >> >> that's a separate issue entirely). Quote: >> >> Thanks in advance. Quote: >> > Unless you have a huge logon script, the bandwidth requirements would >> > be >> > minimal. What is the size of your script? A few kBytes? Trivial! >> > Remember: >> > A 100 MBits Ethernet can transfer up to 10 MBytes per second. Quote: >> > If you're still reluctant to have your script reside on the server then >> > you could use "xcopy.exe /d" to ensure that the user has the latest >> > version of the script. This is a single line of code and it is much >> > simpler than creating and comparing CRC checksums. >> Of course there is the bandwidth required to copy the logon script. >> >> -- >> Richard Mueller >> MVP Directory Services >> Hilltop Lab -http://www.rlmueller.net >> -- > I think I know what you mean, but I don't think you would've posted if > your point was that simple. Can you elaborate, Richard? > > ------ > I don't know the details, so I hesitate to say too much. However, I think > more bandwidth is required to copy a program than to execute the program. script on the server to compute its CRC checksum... Quote: > When a program is run it is loaded into memory, which is fast, so the > transfer over the network doesn't need to wait much. A logon script should > run from local memory. When a program is copied the local drive controller > is the bottleneck. The same number of bytes are transferred, but more > traffic may be needed. > > Long ago when we had 10 Mbps networks and 100 MHz clients we never had > trouble running logon scripts over the network, even when many people > logged on at once (such as after a server reboot). And we had some > elaborate logon scripts. The exception was logon scripts that installed > software over the network. That caused problems. > > My recollection is that batch files are loaded and run one line at a time, > but VBScript programs (and all *.exe programs) are loaded all at once and > then run. there *might* be some efficiencies involved in copying them down locally, but there are reasons why you would not want to, including: - all users would need to have write access to a local folder assumed to contain trusted executables; - complexity itself will increase the cost of maintenance and the risk of changes causing unexpected errors. My suggestion: concentrate on simplifying the code itself, rather than introducing complexity, as the best way to make your logon script operate efficiently (and reliably). /Al |
| My System Specs |
| 12-19-2008 | #7 |
| | Re: Script Execution Over Network "Richard Mueller [MVP]" <rlmueller-nospam@xxxxxx> wrote in message news:uKE6YEiYJHA.5476@xxxxxx Quote: > > "Justin R." <JRusbatch@xxxxxx> wrote in message > news:f0db0038-7739-4369-97cd-96d0865c5f71@xxxxxx > On Dec 19, 12:46 pm, "Richard Mueller [MVP]" <rlmueller- > nos...@xxxxxx> wrote: Quote: >> "Pegasus (MVP)" <I....@xxxxxx> wrote in message >> >> news:OHiOBMeYJHA.5156@xxxxxx >> >> >> >> >> Quote: >> > "Justin R." <JRusba...@xxxxxx> wrote in message >> >news:9e2823a0-65b3-4495-bc99-b4fcb984fd4d@xxxxxx >> >> I'm currently working on revising my company's logon script. When a >> >> user logs on, a remote batch file is executed that checks if the >> >> client already has a file named "logonscript.vbs" on their PC. If >> >> they do, it generates and compares the CRC checksum of the file to a >> >> "logonscript.vbs" that exists on the domain controller. If the two >> >> CRCs match, we know that the client has the latest version of the >> >> script. However, if they do not, the latest version of the script is >> >> copied from the domain controller to the client, and then executed by >> >> the client workstation. Quote: >> >> This seems like a lot of back-and-forth to me, and I'm having trouble >> >> gauging whether it's the most efficient way of doing things. Part of >> >> me wants to simplify things by simply running "logonscript.vbs" from >> >> the domain controller without making a copy on the client's PC first. >> >> This would eliminate the need to perform a CRC checksum comparison. >> >> Is there a way for me to figure out how much bandwidth this would cost >> >> on a per-logon basis? Any thoughts or suggestions? I'm pulling my >> >> hair out over this (it doesn't really need much help, though, but >> >> that's a separate issue entirely). Quote: >> >> Thanks in advance. Quote: >> > Unless you have a huge logon script, the bandwidth requirements would >> > be >> > minimal. What is the size of your script? A few kBytes? Trivial! >> > Remember: >> > A 100 MBits Ethernet can transfer up to 10 MBytes per second. Quote: >> > If you're still reluctant to have your script reside on the server then >> > you could use "xcopy.exe /d" to ensure that the user has the latest >> > version of the script. This is a single line of code and it is much >> > simpler than creating and comparing CRC checksums. >> Of course there is the bandwidth required to copy the logon script. >> >> -- >> Richard Mueller >> MVP Directory Services >> Hilltop Lab -http://www.rlmueller.net >> -- > I think I know what you mean, but I don't think you would've posted if > your point was that simple. Can you elaborate, Richard? > > ------ > I don't know the details, so I hesitate to say too much. However, I think > more bandwidth is required to copy a program than to execute the program. > When a program is run it is loaded into memory, which is fast, so the > transfer over the network doesn't need to wait much. A logon script should > run from local memory. When a program is copied the local drive controller > is the bottleneck. The same number of bytes are transferred, but more > traffic may be needed. > > Long ago when we had 10 Mbps networks and 100 MHz clients we never had > trouble running logon scripts over the network, even when many people > logged on at once (such as after a server reboot). And we had some > elaborate logon scripts. The exception was logon scripts that installed > software over the network. That caused problems. > > My recollection is that batch files are loaded and run one line at a time, > but VBScript programs (and all *.exe programs) are loaded all at once and > then run. > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab - http://www.rlmueller.net > -- issue then it can easily be overcome by using the following code: @echo off if /i "%1"=="run" then goto Run xcopy /d /y \\server\netlogon\netlogon.bat c:\Windows > nul & c:\Windows\netlogon.bat run :Run [Remaining lines of code] This method has the following properties: - Only three lines of code need to be read from the server's netlogon share. - All remaining lines are read from a local file. - The local copy of the script is always up-to-date. |
| My System Specs |
| 12-19-2008 | #8 |
| | Re: Script Execution Over Network "Pegasus (MVP)" <I.can@xxxxxx> wrote in message news:eJ4j7niYJHA.1328@xxxxxx Quote: > > "Richard Mueller [MVP]" <rlmueller-nospam@xxxxxx> wrote in > message news:uKE6YEiYJHA.5476@xxxxxx Quote: >> >> "Justin R." <JRusbatch@xxxxxx> wrote in message >> news:f0db0038-7739-4369-97cd-96d0865c5f71@xxxxxx >> On Dec 19, 12:46 pm, "Richard Mueller [MVP]" <rlmueller- >> nos...@xxxxxx> wrote: Quote: >>> "Pegasus (MVP)" <I....@xxxxxx> wrote in message >>> >>> news:OHiOBMeYJHA.5156@xxxxxx >>> >>> >>> >>> >>> >>> > "Justin R." <JRusba...@xxxxxx> wrote in message >>> >news:9e2823a0-65b3-4495-bc99-b4fcb984fd4d@xxxxxx >>> >> I'm currently working on revising my company's logon script. When a >>> >> user logs on, a remote batch file is executed that checks if the >>> >> client already has a file named "logonscript.vbs" on their PC. If >>> >> they do, it generates and compares the CRC checksum of the file to a >>> >> "logonscript.vbs" that exists on the domain controller. If the two >>> >> CRCs match, we know that the client has the latest version of the >>> >> script. However, if they do not, the latest version of the script is >>> >> copied from the domain controller to the client, and then executed by >>> >> the client workstation. >>> >>> >> This seems like a lot of back-and-forth to me, and I'm having trouble >>> >> gauging whether it's the most efficient way of doing things. Part of >>> >> me wants to simplify things by simply running "logonscript.vbs" from >>> >> the domain controller without making a copy on the client's PC first. >>> >> This would eliminate the need to perform a CRC checksum comparison. >>> >> Is there a way for me to figure out how much bandwidth this would >>> >> cost >>> >> on a per-logon basis? Any thoughts or suggestions? I'm pulling my >>> >> hair out over this (it doesn't really need much help, though, but >>> >> that's a separate issue entirely). >>> >>> >> Thanks in advance. >>> >>> > Unless you have a huge logon script, the bandwidth requirements would >>> > be >>> > minimal. What is the size of your script? A few kBytes? Trivial! >>> > Remember: >>> > A 100 MBits Ethernet can transfer up to 10 MBytes per second. >>> >>> > If you're still reluctant to have your script reside on the server >>> > then >>> > you could use "xcopy.exe /d" to ensure that the user has the latest >>> > version of the script. This is a single line of code and it is much >>> > simpler than creating and comparing CRC checksums. >>> >>> Of course there is the bandwidth required to copy the logon script. >>> >>> -- >>> Richard Mueller >>> MVP Directory Services >>> Hilltop Lab -http://www.rlmueller.net >>> -- >> I think I know what you mean, but I don't think you would've posted if >> your point was that simple. Can you elaborate, Richard? >> >> ------ >> I don't know the details, so I hesitate to say too much. However, I think >> more bandwidth is required to copy a program than to execute the program. >> When a program is run it is loaded into memory, which is fast, so the >> transfer over the network doesn't need to wait much. A logon script >> should run from local memory. When a program is copied the local drive >> controller is the bottleneck. The same number of bytes are transferred, >> but more traffic may be needed. >> >> Long ago when we had 10 Mbps networks and 100 MHz clients we never had >> trouble running logon scripts over the network, even when many people >> logged on at once (such as after a server reboot). And we had some >> elaborate logon scripts. The exception was logon scripts that installed >> software over the network. That caused problems. >> >> My recollection is that batch files are loaded and run one line at a >> time, but VBScript programs (and all *.exe programs) are loaded all at >> once and then run. >> >> -- >> Richard Mueller >> MVP Directory Services >> Hilltop Lab - http://www.rlmueller.net >> -- > If reading the logon batch file on a line-by-line basis is a > speed/bandwidth issue then it can easily be overcome by using the > following code: > @echo off > if /i "%1"=="run" then goto Run > xcopy /d /y \\server\netlogon\netlogon.bat c:\Windows > nul & > c:\Windows\netlogon.bat run > :Run > [Remaining lines of code] > > This method has the following properties: > - Only three lines of code need to be read from the server's netlogon > share. > - All remaining lines are read from a local file. > - The local copy of the script is always up-to-date. access to the "C:\windows" folder. IMHO, that is just too dangerous a configuration change to make in order to attempt to speed up the logon process. How much of a performance improvement would result is questionable, but this would seem to be greater for a long batch file. But I suspect that a long batch file would be better optimized by rewriting in vsbcript. But for those who insist, I would shorten the number of lines read in from the netlogon share by cmd.exe to one, by moving the operational logon script code to a separate file. The actual domain logon script file could contain this: @copy /d /y "%~dpn0_copy.cmd" "%appdata%" & "%appdata%\%~no_copy.cmd" If that file were called logon.cmd, then a file called logon_copy.cmd would be updated in the user's local profile from the netlogon share. Not ideal, as someone could substitute a rogue logon_copy.cmd file into the appdata folder with an old timestamp on it. And it still introduces a level of complexity probably not warranted for the gains to be made (imho, at least). /Al |
| My System Specs |
| 12-19-2008 | #9 |
| | Re: Script Execution Over Network Having read the very enlightening thread, my mind got to wondering about what happens if the network is down - do the Logon Scripts cater for it satisfactorily ?? Pete (Northolt UK) "Justin R." wrote: Quote: > I'm currently working on revising my company's logon script. When a > user logs on, a remote batch file is executed that checks if the > client already has a file named "logonscript.vbs" on their PC. If > they do, it generates and compares the CRC checksum of the file to a > "logonscript.vbs" that exists on the domain controller. If the two > CRCs match, we know that the client has the latest version of the > script. However, if they do not, the latest version of the script is > copied from the domain controller to the client, and then executed by > the client workstation. > > This seems like a lot of back-and-forth to me, and I'm having trouble > gauging whether it's the most efficient way of doing things. Part of > me wants to simplify things by simply running "logonscript.vbs" from > the domain controller without making a copy on the client's PC first. > This would eliminate the need to perform a CRC checksum comparison. > Is there a way for me to figure out how much bandwidth this would cost > on a per-logon basis? Any thoughts or suggestions? I'm pulling my > hair out over this (it doesn't really need much help, though, but > that's a separate issue entirely). > > Thanks in advance. |
| My System Specs |
| 12-20-2008 | #10 |
| | Re: Script Execution Over Network "p byers" <pb@xxxxxx-ltd.co.uk> wrote in message news:494C89C3.2A1C8813@xxxxxx-ltd.co.uk... Quote: > Having read the very enlightening thread, my mind got to wondering about > what happens if the network is down - do the Logon Scripts cater for it > satisfactorily ?? Domain-based logon scripts will only run for domain users logging on at workstations having network connectivity to at least one domain controller. They will not run for local user accounts, or for anybody if the network is not accessible. So, the basic answer would be that the logon scripts themselves, since they would not run at all without network connectivity, would not cater for anything. That said, once a domain user is logged on with cached credentials he could certainly run a "local copy" of the domain logon script manually if such a file was maintained as per some of the suggestions in this thread. But the "satisfactoriness" of the result would depend on what that script was supposed to accomplish, and whether or not network connectivity was required for it to succeed. If the network is down, then no drives will be mapped to any server shares, and no network printers will be installed. Our workstations map the "my documents" folder to a folder in the user's home directory, which is on a server share. If they logon with cached credentials, they can work locally, but if their profile has not yet run MS office, they will have some problems. In some cases I have setup a batch script that runs from the START - All Programs - Startup folder. If it finds that the drive letter normally mapped to their home folder does not exist, it will do something like this: subst M: "%USERPROFILE%\mY dOCUMENT Quote: > Pete (Northolt UK) > > "Justin R." wrote: > Quote: >> I'm currently working on revising my company's logon script. When a >> user logs on, a remote batch file is executed that checks if the >> client already has a file named "logonscript.vbs" on their PC. If >> they do, it generates and compares the CRC checksum of the file to a >> "logonscript.vbs" that exists on the domain controller. If the two >> CRCs match, we know that the client has the latest version of the >> script. However, if they do not, the latest version of the script is >> copied from the domain controller to the client, and then executed by >> the client workstation. >> >> This seems like a lot of back-and-forth to me, and I'm having trouble >> gauging whether it's the most efficient way of doing things. Part of >> me wants to simplify things by simply running "logonscript.vbs" from >> the domain controller without making a copy on the client's PC first. >> This would eliminate the need to perform a CRC checksum comparison. >> Is there a way for me to figure out how much bandwidth this would cost >> on a per-logon basis? Any thoughts or suggestions? I'm pulling my >> hair out over this (it doesn't really need much help, though, but >> that's a separate issue entirely). >> >> Thanks in advance. |
| My System Specs |
| Similar Threads for: Script Execution Over Network | ||||
| Conditional execution of script for logged-on user | VB Script | |||
| Retaining variables after script execution | PowerShell | |||
| Server execution failed... network doesn't work | Vista networking & sharing | |||
| Re: No network - server execution failed | Vista networking & sharing | |||
| Terminate Script Execution? | PowerShell | |||
