Vista - How change frame location.
Old 12-23-2008   #1 (permalink)
K4nd1
Hi. i have a question for all, how to change frame location with 1
button and 1 textbox. example we type www.google.com if we klik button
then frame location is www.google.com.
I hope anybody to answer my question.....
Thanks.
kandi irawan
Old 12-23-2008   #2 (permalink)
mayayana
Re: How change frame location.
You need to provide more details. What button and
textbox? What frame? Are you sure that you have a
VBScript question? It sounds like you might be working
with some kind of programming language. VBScript does
not have "controls" such as buttons and textboxes.
> Thanks.
> kandi irawan
Old 12-24-2008   #3 (permalink)
K4nd1
i know vbscript din't have button. but we can make button or textbox
with HTML language...!!!
Old 12-24-2008   #4 (permalink)
mayayana
OK. How was anyone supposed to know that?
You need to explain what you're trying to do if
you want help with it. We can't read your mind.
This group is for general VBScript questions. Most
of those are *not* about using VBScript in a browser.
So far you've said you have a button and textbox
in a webpage and it sounds like you're using a
frameset, with the button in frame1 and "frame location"
being frame2. If that's the case, you can write a
navigation function in the frameset page to navigate
in frame2. Then call that from the frame1 button click
by using: parent.NavigationFunction(URL)
where URL is your textbox text.
You also haven't mentioned whether this is server-side
or client-side. As Joe Fawcett explained in your other post,
if you want to do this server-side, from a website, then
you need to use javascript. VBScript is a Microsoft product
that won't work in any browser except IE.
Please, allow to change C:\Users[\xxx] location Vista General
Best way to change location of offline files Vista General
ow to change storage location Vista mail
Vista - How to change Office 2003 Frame/Window Theme Colors Vista installation & setup
Why can't I change the location of the message store? Vista mail
