Vista - Need a vbscript to fix virusguard.vbs effecting ie
Old 12-26-2008   #1 (permalink)
Want some help
Hi Guys,
This is the first time i login to this vbscript forum. I need help really.
Recently I found a name (Dipak Bhattrai) on internet explorer title bar
insted of Windows Internet Explorer. I read some articles and found that all
this is because of a culprit VirusGuard.vbs file located at
"c:\windows\system32\" It is hidden.
I also found the solution to getrid of this. The steps to follow are
1. End task the process called wscript.exe through taskmanager
2. Unhide all the hidden files and folders including the protected operating
files
3. Go to c:\windows\system32 and find VirusGuard.vbs and delete that file.
4. Editing the following registry entry
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\Window Title
again as Windows Internet Explorer
After doing all the above steps we will have the default title as Windows
Internet Explorer.
But still there is another entry in registry.
The effect is everytime we start windows an error message will come like
unable to locate c:\windows\system32\VirusGuard.vbs file.
This is because of there is the following added entry in "userinit"
the location of the entry is
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\
Windows NT\CurrentVersion\Winlogon
the added entry is something like
C:\WINDOWS\system32\userinit.exe,c:\windows\system32\wscript.exe,c:\windows\system32\VirusGuard.vbs
So we have to make it as the default entry as
Thats all we have to do.
I am doing all this manually every time when i found this problem in the
systems. I know that it is also possible through vbscript. If there is a
single vbscript to do all this it will be very helpful for me.
So Please help me in fixing this issue through a vbscript.
Thanks in advance....
Old 12-26-2008   #2 (permalink)
Pegasus \(MVP\)
Re: Need a vbscript to fix virusguard.vbs effecting ie
"Want some help" <Wantsomehelp@xxxxxx> wrote in message
news:5E720E4E-CB9B-4BDE-9C44-3BC16C3AAA28@xxxxxx
Quote:
> Hi Guys,
> all
> operating
> files
> Internet Explorer.
If your manual registry change of "C:\WINDOWS\system32\userinit.exe" is not
persistent then you haven't gotten rid of your virus. Trying to script the
registry change is merely addressing the symptoms. You must now find out how
to remove your virus properly. Install a good virus scanner or go to
www.trend.com and look for "HouseCall" to scan/clean your system on-line.
Old 12-26-2008   #3 (permalink)
Richard Mueller [MVP]
"Pegasus (MVP)" <I.can@xxxxxx> wrote in message
news:ObwC%23m3ZJHA.2620@xxxxxx
Quote:
>> Hi Guys,
>> really.
>> all
>> operating
>> files
>> file.
>> Internet Explorer.
> not persistent then you haven't gotten rid of your virus. Trying to script
> the registry change is merely addressing the symptoms. You must now find
> out how to remove your virus properly. Install a good virus scanner or go
> to www.trend.com and look for "HouseCall" to scan/clean your system
> on-line.
Agreed. From the little research I just did, it might be an autorun on an
infected cd that repeatedly re-infects you. However, assuming your steps are
correct (and they could well be incomplete if you keep getting reinfected),
the following untested program might help. Note that it should be run using
cscript, or stopping the wscript process will stop this script as well.
Option Explicit
Dim strComputer, objReg, strKeyPath, strEntryName, strValue
Dim objWMIService, colFiles, objFiles, colProcesses objProcess
Const HKEY_LOCAL_MACHINE = &H80000002
Const HKEY_CURRENT_USER = &H80000001
strComputer = "."
' Terminate process wscript.exe
Set objWMIService = GetObject("winmgmts:" _
& "{impersonationLevel=impersonate,authenticationLevel=Pkt}!\\" _
& strComputer & "\root\cimv2")
Set colProcesses = objWMIService.ExecQuery _
("SELECT * FROM Win32_Process WHERE Name = 'wscript.exe'")
For Each objProcess In colProcesses
objProcess.Terminate()
Next
' Delete file VirusGuard.vbs.
Set colFiles = objWMIService.ExecQuery _
("SELECT * FROM CIM_DataFile WHERE Name =
'c:\\Windows\\system32\\VirusGuard.vbs'")
For Each objFile In colFiles
objFile.Delete
Next
' Modify IE title in registry.
Set objReg = GetObject("winmgmts:" _
& strComputer & "\root\default:StdRegProv")
strKeyPath = "Software\Microsoft\Internet Explorer\Main"
strEntryName = "Window Title"
strValue = "Windows Internet Explorer"
objReg.SetStringValue HKEY_CURRENT_USER, strKeyPath, strEntryName, strValue
' Modify Winlogon Userinit.
strKeyPath = "Software\Microsoft\Windows NT\CurrentVersion\Winlogon"
strEntryName = "Userinit"
strValue = "C:\Windows\system32\userinit.exe,"
objReg.SetStringValue HKEY_LOCAL_MACHINE, strKeyPath, strEntryName, strValue
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
"the family safety service has been disabled" error, effecting internet Network & Sharing
Where is VBscript now? VB Script
VBscript Help VB Script
How to do No hang up VBScript (nohup for VBScript) VB Script
Vista Bug Effecting Explorer 7.0 Vista General
