Vista - Array help please
Old 12-30-2008   #1 (permalink)
Bob Smith
Array help please
I need to know how I can query the size of the second element in 2 two
dimentional array. In the example below it would be 3. I tried UBound and
LBound but they don't give me the result.
Dim myarray
ReDim myarray(1,3)
myarray(0,0)="A"
myarray(0,1)="AA"
myarray(0,2)="AAA"
myarray(0,3)="AAAA"
myarray(1,0)="A"
myarray(1,1)="AA"
myarray(1,2)="AAA"
myarray(1,3)="AAAA"
Old 12-30-2008   #2 (permalink)
Pegasus \(MVP\)
Re: Array help please
"Bob Smith" <BobSmith@xxxxxx> wrote in message
news:E4424F42-C075-44EB-A2A4-322E6366B177@xxxxxx
> Dim myarray
> ReDim myarray(1,3)
> myarray(0,0)="A"
> myarray(0,1)="AA"
> myarray(0,2)="AAA"
> myarray(0,3)="AAAA"
> myarray(1,0)="A"
> myarray(1,1)="AA"
> myarray(1,2)="AAA"
> myarray(1,3)="AAAA"
Try this:
wscript.echo UBound(myarray,2)
(found in the downloadable VB Script help file script56.chm)
Old 12-30-2008   #3 (permalink)
ekkehard.horner
> Dim myarray
> ReDim myarray(1,3)
> myarray(0,0)="A"
> myarray(0,1)="AA"
> myarray(0,2)="AAA"
> myarray(0,3)="AAAA"
> myarray(1,0)="A"
> myarray(1,1)="AA"
> myarray(1,2)="AAA"
> myarray(1,3)="AAAA"
I'm not sure, I understand your "the size of the second element" correctly,
but if you mean "size of the second dimension":
WScript.Echo "UBound( myarray, 1 [= first dimension] )", UBound( myarray, 1 )
WScript.Echo "UBound( myarray, 2 [= second dimension] )", UBound( myarray, 2 )
output:
UBound( myarray, 1 [= first dimension] ) 1
UBound( myarray, 2 [= second dimension] ) 3
Old 12-30-2008   #4 (permalink)
Bob Smith
Thanks for your help!
"ekkehard.horner" wrote:
> > Dim myarray
> > ReDim myarray(1,3)
> > myarray(0,0)="A"
> > myarray(0,1)="AA"
> > myarray(0,2)="AAA"
> > myarray(0,3)="AAAA"
> > myarray(1,0)="A"
> > myarray(1,1)="AA"
> > myarray(1,2)="AAA"
> > myarray(1,3)="AAAA"
> output:
Old 12-30-2008   #5 (permalink)
Bob Smith
Thanks for the help!
> > Dim myarray
> > ReDim myarray(1,3)
> > myarray(0,0)="A"
> > myarray(0,1)="AA"
> > myarray(0,2)="AAA"
> > myarray(0,3)="AAAA"
> > myarray(1,0)="A"
> > myarray(1,1)="AA"
> > myarray(1,2)="AAA"
> > myarray(1,3)="AAAA"
> Try this:
Fast copy method of sub array (=array range) possible? VB Script
How to create array without quotes? $array = (a,b,c) PowerShell
Array indexing: Want to say "Item #2 through the rest of the array." PowerShell
Stupid Array Tricks: Initializing an Array to a Certain Size PowerShell
how to assign values to array and how to create array via variable PowerShell
