Vista - WScript.Shell echo command?
Old 01-03-2009   #1 (permalink)
ryan
I'm trying to run a program within vbs using WScript.Shell that
requires a pipe. The command i need to run is
echo <text> | clip
But when i run the following as a test i get WshShell.Exec: The system
cannot find the file specified.
sCmd = "echo test | clip"
Set oShell = CreateObject("WScript.Shell")
Set oExCmd = oShell.Exec(sCmd)
How can i use the echo command or another command to pipe text into
the another program?
Old 01-03-2009   #2 (permalink)
Pegasus \(MVP\)
Re: WScript.Shell echo command?
<ryan@xxxxxx> wrote in message
news:9b701477-e182-44c1-8792-91877ef30fe4@xxxxxx
> echo <text> | clip
"echo" is an internal Command Processor command, same as "cd" or "copy". To
invoke it from another program you need to invoke it through the Command
Processor like so:
cmd.exe /c echo Hello World or
%comspec" /c echo Hello World
A much simpler method would be to echo the desired string directly from
within VB Script instead of shelling out to to Command Processor, by using
this code:
wscript.echo "Hello World"
Old 01-03-2009   #3 (permalink)
Ruediger Roesler
ryan@xxxxxx <ryan@xxxxxx> typed:
> echo <text> | clip
This example 'ReadOutput.vbs' demonstrates catching the output of a
process at the command-line:
Dim wshShell, wshExec, strResult
Set wshShell = CreateObject("WScript.Shell")
strObjekt = """svchost.exe"""
strCmdLine = wshShell.ExpandEnvironmentStrings("%COMSPEC%")
strCmdLine = strCmdLine & " /c tasklist | find /c " & strObjekt
Set wshExec = wshShell.Exec(strCmdLine)
Do While Not(wshExec.StdOut.AtEndOfStream)
strResult = wshExec.StdOut.ReadLine
Loop
WScript.Echo "There were " & strResult & " processes found of " & _
strObjekt & "."
To execute this example, it requires at least Windows XP Professional
because the program TaskList.exe is not a component of the Home version
of XP.
ЯR
Old 01-03-2009   #4 (permalink)
Richard Mueller [MVP]
"Pegasus (MVP)" <I.can@xxxxxx> wrote in message
news:uB6naYXbJHA.1328@xxxxxx
>> echo <text> | clip
> To invoke it from another program you need to invoke it through the
> Command Processor like so:
> this code:
I would suggest:
Dim objShell, strCmd, objExecObject, strResults
Set objShell = CreateObject("Wscript.Shell")
strCmd = "%comspec% /c echo test | clip"
Set objExecObject = objShell.Exec(strCmd)
Do Until objExecObject.StdOut.AtEndOfStream
strResults = objExecObject.StdOut.ReadAll
Loop
If the OS is not XP or above you will need to use the Run method of the
wshShell object.
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
Old 01-04-2009   #5 (permalink)
Tom Lavedas
> echo <text> | clip
Beside the approach you have chosen, there is this one that works in
script using IE ...
putClipBoardText4 InputBox("Enter some text", "Test Clip Write/Read")
wsh.sleep 50
wsh.echo GetClipBoardText4
' Requires IE v5.0+
Function getClipBoardText5()
With CreateObject("htmlfile")
On Error Resume Next
getClipBoardText5 = .ParentWindow.ClipboardData.GetData("text")
end with ' htmlfile
End Function
' Requires IE v5.0+
sub putClipBoardText5(sText)
With CreateObject("InternetExplorer.Application")
.Navigate "about:blank"
Do Until .ReadyState = 4 : WScript.Sleep 50 : Loop
.document.ParentWindow.ClipboardData.SetData "text", sText
end with ' IE
End Sub
IE 7 protests and requires a security change to use the clipboard.
Unfortunately, I can't remember now what the proper setting is. I
still try to avoid IE 7 and my work IT group forbids it.
Tom Lavedas
Old 01-04-2009   #6 (permalink)
mayayana
I think it actually requires so-called IE 5.01
to run your sample. (Also, there's a minor
typo. with GetClipBoardText4.) I'm not sure what
the problem is, but I think that part of the DOM
just wasn't finished in IE 5.0. The objects and methods
are there and don't cause any errors. But GetData
always comes back empty and SetData has no effect.
So it's limited to Windows 2000/ME/XP. Win98SE
had IE 5.00.2614. Anything higher than 5.00.26xx
is called "IE 5.01", which came in with Win2000. Yet
although there were a number of versions of 5.00.26xx+,
there was never actually any version numbered 5.01.xxxx!
It jumped to 5.5 in WinME. That numbering pattern is all
the more strange given that Win2000's 5.00.29xx+ seemed
to have been a fairly major update. So they made a major
update with a minor build number change, and then
referred to it by a different version number -- 5.01 --
as though it were numbered with a minor *version* number
change.
I think of "5.01", 5.5 and 6 all being pretty much the same
thing. I'm not sure how accurate that perception is in terms of
HTML rendering because I've never used 5.01 and rarely
used 5.5, but in terms of bugs and vulnerabilities it
seemed that 5.01 -> 6 had about the same ones, while
IE5 was not vulnerable to some of those.
wsh.sleep 50
' Requires IE v5.0+
end with ' htmlfile
End Function
' Requires IE v5.0+
end with ' IE
End Sub
Tom Lavedas
wscript.echo only a new line / embed a "CR" in a text string ? VB Script
WScript.Shell -> Terminal Server 2008... VB Script
echo out interactive parameters that were entered for a command PowerShell
WScript.Echo VB Script
Powershell starts but never exits when invoked from Wscript shell PowerShell
