| | Script: read a registry key I need a script that I read a registry key and tell me whether or not, and if it exists, delete it. Can be done through a batch script? Thank you. |
| | Re: Script: read a registry key "Jim" <jim.gutierrrez@xxxxxx> wrote in message news:%2316z1BbcJHA.1328@xxxxxx Quote: >I need a script that I read a registry key and tell me whether or not, and >if it exists, delete it. > Can be done through a batch script? > Thank you. http://support.microsoft.com/?kbid=310516 If you want to delete the key then you don't need to read it first - just go ahead and attempt to delete it, whether it exists or not. |
| Script for Windows registry | VB Script | |||
| Need to read 64-bit registry from 32-bit RegRead | VB Script | |||
| Re: Printer cannot read registry key? | Vista print fax & scan | |||
| Read from Registry on Vista | Vista security | |||
| Read from Registry on Vista | Vista General | |||
