RB
Vista - How to get DOM on the landing page after a submit using aInternetExplorer.Application Obj
01-12-2009   #1
gimme_this_gimme_that
The following script visits a website log in page, does a POST, and
then navigates to the site's welcome page.
The Welcome page has a div whose id is "AAA".
But the IE object isn't getting refreshed with the DOM on the Welcome
page to see it.
What do I need to do?
Thanks.
Set IE = CreateObject("InternetExplorer.Application")
IE.Visible = True
IE.navigate "http://www.mywebsite.com"
Do while IE.Busy
Loop
Set doc = IE.Document
Set form = doc.forms("login_form")
form.elements("password").value = "mypassword"
form.elements("logon").value = "mylogin"
form.submit
Do while IE.Busy
Loop
IE.Refresh -- Refresh isn't making it so I can see the DOM on the
Welcome page
Set msg = doc.getElementById("AAA")
MsgBox msg.innerHTML ' Always null
01-12-2009   #2
Re: How to get DOM on the landing page after a submit using aInternetExplorer.Application Obj
Nevermind. This did it:
IE.Navigate IE.LocationURL
IE.Visible = True
Do while IE.Busy
Loop
form.submit
Do while IE.Busy
Loop
MsgBox msg.innerHTML ' Works now
RB
Similar Threads for: How to get DOM on the landing page after a submit using aInternetExplorer.Application Obj
Can'T submit form data from mail Vista mail
Using only 1/3 page file, but unable to load application Vista General
submit page PowerShell
How to submit page PowerShell
