| | Extract names of running applications. (Excel) Hi If a sheet is open while the vb script is writing new data, I got something like this: Microsoft Excel: Can't access 'R.XLS' Is there a way to check for Excel is running, so I can let the script write a message, "PLEASE CLOSE ANY EXCEL SHEET before you continue the script!" How to check is running? Benny Pedersen, PS: Below is three functions for your code archives. ![]() 1: getF. Use it to get a file or folder... 2: ShowFile. Use it to open a folder (intended for CScript, not WScript). 3: KillApp. Kill any app you want to quit. set fso= createObject("scripting.fileSystemObject") set wso= createObject("wScript.shell") function getF(byVal sFSpec, byVal sWhat) sWhat= lCase(sWhat) sFSpec= wso.expandEnvironmentStrings(sFSpec) sFSpec= fso.getAbsolutePathName(sFSpec) on error resume next if sWhat = "file" then getF= fso.getFile(sFSpec) else if sWhat="parent" then sFSpec= fso.getParentFolderName(sFSpec) ' sFSpec= fso.buildPath(sFSpec,"\") getF= fso.buildPath(fso.getFolder(sFSpec),"\") end if if err then getF= sFSpec: err.clear ' end function sub ShowFile(sFile) dim sPath:sPath= getF(sFile, "parent") wScript.echo "--> Open folder, """ & sPath & """" if fso.fileExists(sFile) then dim oFile: set oFile= fso.getFile(sFile) wScript.echo vbCrLf & vbTab & oFile.type & " """ & fso._ getFileName(sFile) & """, " & oFile.size & " byte."& vbCrLf &_ vbTab & "Created: "& oFile.dateCreated & vbCrLf &_ vbTab & "Modified: "& oFile.dateLastModified & vbCrLf set oFile= nothing wso.run "explorer.exe /select,"""& sFile & """" else wso.run "explorer.exe """& sPath & """" end if wScript.echo "--> Folder is open." & vbCrLf end sub sub KillApp(byVal app) dim KillExe: KillExe= "%windir%\system32\atskill.exe" if fso.fileExists(getF(KillExe,"file")) then wso.run """" & KillExe & """ """ & app & """", 7, true wso.run""""& KillExe &""" """& KillExe & """", 7, false else msgBox "File not found, ""TSKILL.EXE""" & vbLf _ & "Tips: Search KILL on your system.", 4096 end if end sub |
| | Re: Extract names of running applications. (Excel) "Benny Pedersen" <b.pedersen@xxxxxx> wrote in message news:b34d1356-a5c4-43b9-b4fe-07c14bfae04e@xxxxxx Quote: > Hi > > If a sheet is open while the vb script is writing new data, > > I got something like this: Microsoft Excel: Can't access 'R.XLS' > > Is there a way to check for Excel is running, so I can let the > script write a message, "PLEASE CLOSE ANY EXCEL SHEET before you > continue the script!" > > How to check is running? > > Benny Pedersen, > > PS: Below is three functions for your code archives. ![]() > > 1: getF. Use it to get a file or folder... > 2: ShowFile. Use it to open a folder (intended for CScript, not > WScript). > 3: KillApp. Kill any app you want to quit. > > set fso= createObject("scripting.fileSystemObject") > set wso= createObject("wScript.shell") > > function getF(byVal sFSpec, byVal sWhat) > sWhat= lCase(sWhat) > sFSpec= wso.expandEnvironmentStrings(sFSpec) > sFSpec= fso.getAbsolutePathName(sFSpec) > on error resume next > if sWhat = "file" then > getF= fso.getFile(sFSpec) > else > if sWhat="parent" then sFSpec= fso.getParentFolderName(sFSpec) ' > sFSpec= fso.buildPath(sFSpec,"\") > getF= fso.buildPath(fso.getFolder(sFSpec),"\") > end if > if err then getF= sFSpec: err.clear ' > end function > > sub ShowFile(sFile) > dim sPath:sPath= getF(sFile, "parent") > wScript.echo "--> Open folder, """ & sPath & """" > if fso.fileExists(sFile) then > dim oFile: set oFile= fso.getFile(sFile) > wScript.echo vbCrLf & vbTab & oFile.type & " """ & fso._ > getFileName(sFile) & """, " & oFile.size & " byte."& vbCrLf &_ > vbTab & "Created: "& oFile.dateCreated & vbCrLf &_ > vbTab & "Modified: "& oFile.dateLastModified & vbCrLf > set oFile= nothing > wso.run "explorer.exe /select,"""& sFile & """" > else wso.run "explorer.exe """& sPath & """" > end if > wScript.echo "--> Folder is open." & vbCrLf > end sub > > sub KillApp(byVal app) > dim KillExe: KillExe= "%windir%\system32\atskill.exe" > if fso.fileExists(getF(KillExe,"file")) then > wso.run """" & KillExe & """ """ & app & """", 7, true > wso.run""""& KillExe &""" """& KillExe & """", 7, false > else msgBox "File not found, ""TSKILL.EXE""" & vbLf _ > & "Tips: Search KILL on your system.", 4096 > end if > end sub script that exist in the universe", you appear to suffer from a pronounced lack imagination when it comes to performing everyday scripting tasks. C'mon, do a bit of your own thinking before posting and use the countless clues you received to your previous posts! |
| | Re: Extract names of running applications. (Excel) On Jan 12, 11:26*pm, "Monitor" <nos...@xxxxxx> wrote: Quote: > "Benny Pedersen" <b.peder...@xxxxxx> wrote in message > > news:b34d1356-a5c4-43b9-b4fe-07c14bfae04e@xxxxxx > > > > > Quote: > > Hi Quote: > > If a sheet is open while the vb script is writing new data, Quote: > > I got something like this: Microsoft Excel: Can't access 'R.XLS' Quote: > > Is there a way to check for Excel is running, so I can let the > > script write a message, "PLEASE CLOSE ANY EXCEL SHEET before you > > continue the script!" Quote: > > How to check is running? Quote: > > Benny Pedersen, Quote: > > PS: Below is three functions for your code archives. ![]() Quote: > > 1: getF. Use it to get a file or folder... > > 2: ShowFile. Use it to open a folder (intended for CScript, not > > WScript). > > 3: KillApp. Kill any app you want to quit. Quote: > > set fso= createObject("scripting.fileSystemObject") > > set wso= createObject("wScript.shell") Quote: > > function getF(byVal sFSpec, byVal sWhat) > > * sWhat= lCase(sWhat) > > * sFSpec= wso.expandEnvironmentStrings(sFSpec) > > * sFSpec= fso.getAbsolutePathName(sFSpec) > > * on error resume next > > * if sWhat = "file" then > > * * getF= fso.getFile(sFSpec) > > * else > > * * if sWhat="parent" then sFSpec= fso.getParentFolderName(sFSpec) ' > > * * sFSpec= fso.buildPath(sFSpec,"\") > > * * getF= fso.buildPath(fso.getFolder(sFSpec),"\") > > * end if > > * if err then getF= sFSpec: err.clear ' > > end function Quote: > > sub ShowFile(sFile) > > * dim sPath:sPath= getF(sFile, "parent") > > * wScript.echo "--> Open folder, """ & sPath & """" > > * if fso.fileExists(sFile) then > > * * dim oFile: set oFile= fso.getFile(sFile) > > * * wScript.echo vbCrLf & vbTab & oFile.type & " """ & fso._ > > * * getFileName(sFile) & """, " & oFile.size & " byte."& vbCrLf &_ > > * * vbTab & "Created: *"& oFile.dateCreated & vbCrLf &_ > > * * vbTab & "Modified: "& oFile.dateLastModified & vbCrLf > > * * set oFile= nothing > > * * wso.run "explorer.exe /select,"""& sFile & """" > > * else wso.run "explorer.exe """& sPath & """" > > * end if > > * wScript.echo "--> Folder is open." & vbCrLf > > end sub Quote: > > sub KillApp(byVal app) > > * dim KillExe: KillExe= "%windir%\system32\atskill.exe" > > * if fso.fileExists(getF(KillExe,"file")) then > > * * wso.run """" & KillExe & """ """ & app & """", 7, true > > * * wso.run""""& KillExe &""" """& KillExe & """", 7, false > > * else msgBox "File not found, ""TSKILL.EXE""" & vbLf _ > > * * & "Tips: Search KILL on your system.", 4096 > > * end if > > end sub > For someone who previously boasted "writting [sic] the fastest sorting > script that exist in the universe", you appear to suffer from a pronounced > lack imagination when it comes to performing everyday scripting tasks. > C'mon, do a bit of your own thinking before posting and use the countless > clues you received to your previous posts!- Hide quoted text - > > - Show quoted text - About my previous sorting script: I'm still working on it, but since it became faster each time I worked on it, it maybe was not the fastest sorting script in the univerce. Anyhow, since I haven't published the faster version, I maybe did learned something. In other words: I won't show the sorting script now, tomorrow nither... ![]() Benny |
| running Excel Macro in in specified Excel files in spe | PowerShell | |||
| Excel / .Net: Extract a given Range into Picture or X(HT)ML? | .NET General | |||
| Programs/Applications running | Vista performance & maintenance | |||
| iis 7.0 - applications running under dot net framework 1.1 | Vista installation & setup | |||
