| | How to check if the OS is 64 bit or 32 bit? Hi all, I want to check if the OS is 64 bit or 32 bit using vbscript. I'm currently reading the registry key - HKEY_LOCAL_MACHINE\SYSTEM \CurrentControlSet\Control\Session Manager\Environment \PROCESSOR_ARCHITECTURE and checking the architecture. My question is - Will this return the architecture of the OS or the architecture of the processor? i.e., if a 32-bit Windows OS is installed on 64 bit Processor, what will this return? Thanks in advance for your help! |
| | Re: How to check if the OS is 64 bit or 32 bit? "Gugle" <gugle.rulez@xxxxxx> wrote in message news:86d06b46-12bb-47b5-b8cc-57d0389f1643@xxxxxx Quote: > Hi all, > I want to check if the OS is 64 bit or 32 bit using vbscript. I'm > currently reading the registry key - HKEY_LOCAL_MACHINE\SYSTEM > \CurrentControlSet\Control\Session Manager\Environment > \PROCESSOR_ARCHITECTURE and checking the architecture. My question is > - Will this return the architecture of the OS or the architecture of > the processor? i.e., if a 32-bit Windows OS is installed on 64 bit > Processor, what will this return? > > Thanks in advance for your help! with 32-bit Vista. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| | Re: How to check if the OS is 64 bit or 32 bit? "Richard Mueller [MVP]" <rlmueller-nospam@xxxxxx> wrote in message news:uiupR6ZdJHA.1528@xxxxxx Quote: > > "Gugle" <gugle.rulez@xxxxxx> wrote in message > news:86d06b46-12bb-47b5-b8cc-57d0389f1643@xxxxxx Quote: >> Hi all, >> I want to check if the OS is 64 bit or 32 bit using vbscript. I'm >> currently reading the registry key - HKEY_LOCAL_MACHINE\SYSTEM >> \CurrentControlSet\Control\Session Manager\Environment >> \PROCESSOR_ARCHITECTURE and checking the architecture. My question is >> - Will this return the architecture of the OS or the architecture of >> the processor? i.e., if a 32-bit Windows OS is installed on 64 bit >> Processor, what will this return? >> >> Thanks in advance for your help! > Mine shows "x86" or that registry setting. I have AMD Turion 64 X2 TL-56 > with 32-bit Vista. > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab - http://www.rlmueller.net > -- > =========== Option Explicit Dim strComputer, objWMIService, colSettings, objProcessor strComputer = "." Set objWMIService = GetObject("winmgmts:" _ & "{impersonationLevel=impersonate,authenticationLevel=Pkt}!\\" _ & strComputer & "\root\cimv2") Set colSettings = objWMIService.ExecQuery _ ("SELECT * FROM Win32_Processor") For Each objProcessor In colSettings Wscript.Echo "System Type: " & objProcessor.Architecture Wscript.Echo "Processor: " & objProcessor.Description Next ====== You can parse objProcessor.Description for "x64" to check for 64-bit (or "x86" for 32-bit). The system type (objProcessor.Architure) returns 9 on my machine, but I need to research what the number means. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| | Re: How to check if the OS is 64 bit or 32 bit? On Jan 13, 9:57*pm, "Richard Mueller [MVP]" <rlmueller- nos...@xxxxxx> wrote: Quote: > "Richard Mueller [MVP]" <rlmueller-nos...@xxxxxx> wrote in > messagenews:uiupR6ZdJHA.1528@xxxxxx > > > > > Quote: > > "Gugle" <gugle.ru...@xxxxxx> wrote in message > >news:86d06b46-12bb-47b5-b8cc-57d0389f1643@xxxxxx Quote: > >> Hi all, > >> I want to check if the OS is 64 bit or 32 bit using vbscript. I'm > >> currently reading the registry key - HKEY_LOCAL_MACHINE\SYSTEM > >> \CurrentControlSet\Control\Session Manager\Environment > >> \PROCESSOR_ARCHITECTURE and checking the architecture. My question is > >> - Will this return the architecture of the OS or the architecture of > >> the processor? i.e., if a 32-bit Windows OS is installed on 64 bit > >> Processor, what will this return? Quote: Quote: > >> Thanks in advance for your help! Quote: > > Mine shows "x86" or that registry setting. I have AMD Turion 64 X2 TL-56 > > with 32-bit Vista. Quote: > > -- > > Richard Mueller > > MVP Directory Services > > Hilltop Lab -http://www.rlmueller.net > > -- > You should be able to use the Win32_Processor class of WMI. For example: > =========== > Option Explicit > > Dim strComputer, objWMIService, colSettings, objProcessor > > strComputer = "." > > Set objWMIService = GetObject("winmgmts:" _ > * * & "{impersonationLevel=impersonate,authenticationLevel=Pkt}!\\" _ > * * & strComputer & "\root\cimv2") > > Set colSettings = objWMIService.ExecQuery _ > * * ("SELECT * FROM Win32_Processor") > > For Each objProcessor In colSettings > * * Wscript.Echo "System Type: " & objProcessor.Architecture > * * Wscript.Echo "Processor: " & objProcessor.Description > Next > ====== > You can parse objProcessor.Description for "x64" to check for 64-bit (or > "x86" for 32-bit). The system type (objProcessor.Architure) returns 9 on my > machine, but I need to research what the number means. > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab -http://www.rlmueller.net > -- |
| spell check wont check english/ | Vista mail | |||
| Anyone know how to fix/check WU? | Windows Updates | |||
| You really need to check this out | PowerShell | |||
| check this out | Vista General | |||
| Newbie: Nagios with nrpe_nt, check for diskspace; check services,returncode | PowerShell | |||
