Vista - Include AM or PM using DatePart Function
Old 01-15-2009   #1 (permalink)
Len
I do not know how to extract the AM or PM in the DatePart Function
My Code is:
tmCurrentTime = Now()
tmCurrentTime = DatePart("h",tmCurrentTime) & ":" &
DatePart("n",tmCurrentTime)
This works, but I do not know how to get the AM or PM.
If DatePart("h",tmCurrentTime) is 4, how do I know if it is AM or PM?
Thanks for the help.
Len
Old 01-15-2009   #2 (permalink)
James Whitlow
Re: Include AM or PM using DatePart Function
"Len" <Len@xxxxxx> wrote in message
newsF5AE6E6-CB72-451F-A6BF-EE57A8C0B34B@xxxxxx
> My Code is:
It should return the hour of the day starting from midnight. In your
example above, it should return '4' for 4 AM and '16' for 4 PM.
Script that uses the DatePart & Case select VB Script
How to reverse DatePart("y",Date) ? VB Script
Week number with DatePart syntax, and Server... VB Script
BUG: Redirecting function contents to a file truncates function lines at the width of the console PowerShell
Tab Completion customization to include function search? PowerShell
