| | Java Script Syntax Problem Do not program JScript or Java Script! Here is my code: <Script Language="JavaScript"> function ChangeRecord(){ var boolValid = true; if (document.FormA.txtPassWordA <> document.FormA.txtPassWordB)} var incomplete = "PassWords Do Not Match, Please Re-Enter"; alert(incomplete); boolValid = false;} } </Script> <Form Name="FormA"> <Input Type="PassWord" Name="txtPassWordA" Size="40"><br><br> <Input Type="PassWord" Name="txtPassWordB" Size="40"><br><br> <Input Type="Button" Value="Change Information" Name="B1" OnClick="ChangeRecord();"> When I click on the Button, I get Error On Page. What am I doing wrong. My colleague entered this earlier, but under JScript. He did not get a response as of this time. Thanks Granny Leona |
| | Re: Java Script Syntax Problem On Jan 15, 5:26*pm, Leona Leal Educator <LeonaLealEduca...@xxxxxx> wrote: Quote: > Do not program JScript or Java Script! > > Here is my code: > > <Script Language="JavaScript"> > > * * * * * * * * function ChangeRecord(){ > * * * * * * * * var boolValid = true; > * * * * * * * * * * * * * * * * if (document.FormA.txtPassWordA <> > document.FormA.txtPassWordB)} > * * * * * * * * * * * * * * * * var incomplete = "PassWords Do Not Match, > Please Re-Enter"; > * * * * * * * * * * * * * * * * alert(incomplete); > * * * * * * * * boolValid = false;}} > > </Script> > > <Form Name="FormA"> > > <Input Type="PassWord" Name="txtPassWordA" Size="40"><br><br> > <Input Type="PassWord" Name="txtPassWordB" Size="40"><br><br> > > <Input Type="Button" Value="Change Information" Name="B1" > OnClick="ChangeRecord();"> > > When I click on the Button, I get Error On Page. > > What am I doing wrong. > > My colleague entered this earlier, but under JScript. *He did not get a > response as of this time. > > Thanks > > Granny Leona lack of understanding of JScript. The typo is that the closing curly bracket on this line should be an open curly bracket ... if (document.FormA.txtPassWordA <> document.FormA.txtPassWordB)} The syntax error is on the same line. The not equal operator in JScript is !==, not <>. This is the same as in C, C++, Java, etc. So, try this ... <Script Language="JavaScript"> function ChangeRecord() { var boolValid = true; if (document.FormA.txtPassWordA !== document.FormA.txtPassWordB) { var incomplete = "PassWords Do Not Match, Please Re-Enter"; alert(incomplete); boolValid = false; } } </Script> I reformatted the layout a bit to make it more readable, I think. BTW, why are you asking this question in a VBScript group? Tom Lavedas *********** http://there.is.no.more/tglbatch/ |
| | Re: Java Script Syntax Problem I put it here because my associate put it in JScript this AM. He did not get a response and I had trouble bringing JScript up. Our district is off and on a military base, most of the software was written in Assembler. Why, I do not know, but it is very good, but very old. Thanks for helping us out! Granny "Tom Lavedas" wrote: Quote: > On Jan 15, 5:26 pm, Leona Leal Educator > <LeonaLealEduca...@xxxxxx> wrote: Quote: > > Do not program JScript or Java Script! > > > > Here is my code: > > > > <Script Language="JavaScript"> > > > > function ChangeRecord(){ > > var boolValid = true; > > if (document.FormA.txtPassWordA <> > > document.FormA.txtPassWordB)} > > var incomplete = "PassWords Do Not Match, > > Please Re-Enter"; > > alert(incomplete); > > boolValid = false;}} > > > > </Script> > > > > <Form Name="FormA"> > > > > <Input Type="PassWord" Name="txtPassWordA" Size="40"><br><br> > > <Input Type="PassWord" Name="txtPassWordB" Size="40"><br><br> > > > > <Input Type="Button" Value="Change Information" Name="B1" > > OnClick="ChangeRecord();"> > > > > When I click on the Button, I get Error On Page. > > > > What am I doing wrong. > > > > My colleague entered this earlier, but under JScript. He did not get a > > response as of this time. > > > > Thanks > > > > Granny Leona > Your script has two errors. One is a typo, the other a substantial > lack of understanding of JScript. > > The typo is that the closing curly bracket on this line should be an > open curly bracket ... > > if (document.FormA.txtPassWordA <> document.FormA.txtPassWordB)} > > The syntax error is on the same line. The not equal operator in > JScript is !==, not <>. This is the same as in C, C++, Java, etc. > > So, try this ... > > <Script Language="JavaScript"> > > function ChangeRecord() > { > var boolValid = true; > if (document.FormA.txtPassWordA !== document.FormA.txtPassWordB) > { > var incomplete = "PassWords Do Not Match, Please Re-Enter"; > alert(incomplete); > boolValid = false; > } > } > > </Script> > > I reformatted the layout a bit to make it more readable, I think. > > BTW, why are you asking this question in a VBScript group? > > Tom Lavedas > *********** > http://there.is.no.more/tglbatch/ > |
| | Re: Java Script Syntax Problem Tom; Thanks for getting back to me, but it is better, but still not working. I get the message that the password are not equal even if they are: Current Code: <Script Language="JavaScript"> function ChangeRecord(){ var boolValid=true; if (document.forms.txtPasswordA !== document.forms.txtPasswordB) { var incomplete = "PassWords Do Not Match, Please Re-Enter!"; alert(incomplete); boolValid = false; } if (boolValid==true) { document.FormA.action = "NewMemB.Asp"; document.FormA.submit(); } } </Script> Password <Input Type="PassWord" Name="txtPasswordA" Size="10" MaxLength="11"><%Response.Write Sp04%> Retype Password<%Response.Write Sp04%><Input Type="PassWord" Name="txtPasswordB" Size="10" MaxLength="11"> <Input Type="Button" Value="Update Information" Name="B3" OnClick="ChangeRecord()"> Thanks Again "Leona Leal Educator" wrote: Quote: > I put it here because my associate put it in JScript this AM. He did not get > a response and I had trouble bringing JScript up. > > Our district is off and on a military base, most of the software was written > in Assembler. > > Why, I do not know, but it is very good, but very old. > > Thanks for helping us out! > > Granny > > "Tom Lavedas" wrote: > Quote: > > On Jan 15, 5:26 pm, Leona Leal Educator > > <LeonaLealEduca...@xxxxxx> wrote: Quote: > > > Do not program JScript or Java Script! > > > > > > Here is my code: > > > > > > <Script Language="JavaScript"> > > > > > > function ChangeRecord(){ > > > var boolValid = true; > > > if (document.FormA.txtPassWordA <> > > > document.FormA.txtPassWordB)} > > > var incomplete = "PassWords Do Not Match, > > > Please Re-Enter"; > > > alert(incomplete); > > > boolValid = false;}} > > > > > > </Script> > > > > > > <Form Name="FormA"> > > > > > > <Input Type="PassWord" Name="txtPassWordA" Size="40"><br><br> > > > <Input Type="PassWord" Name="txtPassWordB" Size="40"><br><br> > > > > > > <Input Type="Button" Value="Change Information" Name="B1" > > > OnClick="ChangeRecord();"> > > > > > > When I click on the Button, I get Error On Page. > > > > > > What am I doing wrong. > > > > > > My colleague entered this earlier, but under JScript. He did not get a > > > response as of this time. > > > > > > Thanks > > > > > > Granny Leona > > Your script has two errors. One is a typo, the other a substantial > > lack of understanding of JScript. > > > > The typo is that the closing curly bracket on this line should be an > > open curly bracket ... > > > > if (document.FormA.txtPassWordA <> document.FormA.txtPassWordB)} > > > > The syntax error is on the same line. The not equal operator in > > JScript is !==, not <>. This is the same as in C, C++, Java, etc. > > > > So, try this ... > > > > <Script Language="JavaScript"> > > > > function ChangeRecord() > > { > > var boolValid = true; > > if (document.FormA.txtPassWordA !== document.FormA.txtPassWordB) > > { > > var incomplete = "PassWords Do Not Match, Please Re-Enter"; > > alert(incomplete); > > boolValid = false; > > } > > } > > > > </Script> > > > > I reformatted the layout a bit to make it more readable, I think. > > > > BTW, why are you asking this question in a VBScript group? > > > > Tom Lavedas > > *********** > > http://there.is.no.more/tglbatch/ > > |
| | Re: Java Script Syntax Problem I GOOFED, TRYING SO MANY THINGS, THAT I SUBMITTED A TYPO! "Leona Leal Educator" wrote: Quote: > Tom; > > Thanks for getting back to me, but it is better, but still not working. I > get the message that the password are not equal even if they are: > > Current Code: > > <Script Language="JavaScript"> > function ChangeRecord(){ > > var boolValid=true; > > if (document.FormA.txtPasswordA !== document.FormA.txtPasswordB) > { > var incomplete = "PassWords Do Not Match, Please Re-Enter!"; > alert(incomplete); > boolValid = false; > } > > if (boolValid==true) > { > document.FormA.action = "NewMemB.Asp"; > document.FormA.submit(); > } > } > > </Script> Quote: > Password <Input Type="PassWord" Name="txtPasswordA" Size="10" > MaxLength="11"><%Response.Write Sp04%> > Retype Password<%Response.Write Sp04%><Input Type="PassWord" > Name="txtPasswordB" Size="10" MaxLength="11"> > > <Input Type="Button" Value="Update Information" Name="B3" > OnClick="ChangeRecord()"> > > Thanks Again > > "Leona Leal Educator" wrote: > Quote: > > I put it here because my associate put it in JScript this AM. He did not get > > a response and I had trouble bringing JScript up. > > > > Our district is off and on a military base, most of the software was written > > in Assembler. > > > > Why, I do not know, but it is very good, but very old. > > > > Thanks for helping us out! > > > > Granny > > > > "Tom Lavedas" wrote: > > Quote: > > > On Jan 15, 5:26 pm, Leona Leal Educator > > > <LeonaLealEduca...@xxxxxx> wrote: > > > > Do not program JScript or Java Script! > > > > > > > > Here is my code: > > > > > > > > <Script Language="JavaScript"> > > > > > > > > function ChangeRecord(){ > > > > var boolValid = true; > > > > if (document.FormA.txtPassWordA <> > > > > document.FormA.txtPassWordB)} > > > > var incomplete = "PassWords Do Not Match, > > > > Please Re-Enter"; > > > > alert(incomplete); > > > > boolValid = false;}} > > > > > > > > </Script> > > > > > > > > <Form Name="FormA"> > > > > > > > > <Input Type="PassWord" Name="txtPassWordA" Size="40"><br><br> > > > > <Input Type="PassWord" Name="txtPassWordB" Size="40"><br><br> > > > > > > > > <Input Type="Button" Value="Change Information" Name="B1" > > > > OnClick="ChangeRecord();"> > > > > > > > > When I click on the Button, I get Error On Page. > > > > > > > > What am I doing wrong. > > > > > > > > My colleague entered this earlier, but under JScript. He did not get a > > > > response as of this time. > > > > > > > > Thanks > > > > > > > > Granny Leona > > > > > > Your script has two errors. One is a typo, the other a substantial > > > lack of understanding of JScript. > > > > > > The typo is that the closing curly bracket on this line should be an > > > open curly bracket ... > > > > > > if (document.FormA.txtPassWordA <> document.FormA.txtPassWordB)} > > > > > > The syntax error is on the same line. The not equal operator in > > > JScript is !==, not <>. This is the same as in C, C++, Java, etc. > > > > > > So, try this ... > > > > > > <Script Language="JavaScript"> > > > > > > function ChangeRecord() > > > { > > > var boolValid = true; > > > if (document.FormA.txtPassWordA !== document.FormA.txtPassWordB) > > > { > > > var incomplete = "PassWords Do Not Match, Please Re-Enter"; > > > alert(incomplete); > > > boolValid = false; > > > } > > > } > > > > > > </Script> > > > > > > I reformatted the layout a bit to make it more readable, I think. > > > > > > BTW, why are you asking this question in a VBScript group? > > > > > > Tom Lavedas > > > *********** > > > http://there.is.no.more/tglbatch/ > > > |
| | #6 (permalink) |
| | Re: Java Script Syntax Problem Leona; You need to tell Java that the field has a value. Change to: if (document.FormA.txtPasswordA.value != document.FormA.txtPasswordB.value) I am sure it will work. Good Luck Toni "Leona Leal Educator" wrote: Quote: > I GOOFED, TRYING SO MANY THINGS, THAT I SUBMITTED A TYPO! > > "Leona Leal Educator" wrote: > Quote: > > Tom; > > > > Thanks for getting back to me, but it is better, but still not working. I > > get the message that the password are not equal even if they are: > > > > Current Code: > > > > <Script Language="JavaScript"> > > function ChangeRecord(){ > > > > var boolValid=true; > > > > if (document.FormA.txtPasswordA !== document.FormA.txtPasswordB) > > { > > var incomplete = "PassWords Do Not Match, Please Re-Enter!"; > > alert(incomplete); > > boolValid = false; > > } > > > > if (boolValid==true) > > { > > document.FormA.action = "NewMemB.Asp"; > > document.FormA.submit(); > > } > > } > > > > </Script> > <form name="FormA"> > Quote: > > Password <Input Type="PassWord" Name="txtPasswordA" Size="10" > > MaxLength="11"><%Response.Write Sp04%> > > Retype Password<%Response.Write Sp04%><Input Type="PassWord" > > Name="txtPasswordB" Size="10" MaxLength="11"> > > > > <Input Type="Button" Value="Update Information" Name="B3" > > OnClick="ChangeRecord()"> > > > > Thanks Again > > > > "Leona Leal Educator" wrote: > > Quote: > > > I put it here because my associate put it in JScript this AM. He did not get > > > a response and I had trouble bringing JScript up. > > > > > > Our district is off and on a military base, most of the software was written > > > in Assembler. > > > > > > Why, I do not know, but it is very good, but very old. > > > > > > Thanks for helping us out! > > > > > > Granny > > > > > > "Tom Lavedas" wrote: > > > > > > > On Jan 15, 5:26 pm, Leona Leal Educator > > > > <LeonaLealEduca...@xxxxxx> wrote: > > > > > Do not program JScript or Java Script! > > > > > > > > > > Here is my code: > > > > > > > > > > <Script Language="JavaScript"> > > > > > > > > > > function ChangeRecord(){ > > > > > var boolValid = true; > > > > > if (document.FormA.txtPassWordA <> > > > > > document.FormA.txtPassWordB)} > > > > > var incomplete = "PassWords Do Not Match, > > > > > Please Re-Enter"; > > > > > alert(incomplete); > > > > > boolValid = false;}} > > > > > > > > > > </Script> > > > > > > > > > > <Form Name="FormA"> > > > > > > > > > > <Input Type="PassWord" Name="txtPassWordA" Size="40"><br><br> > > > > > <Input Type="PassWord" Name="txtPassWordB" Size="40"><br><br> > > > > > > > > > > <Input Type="Button" Value="Change Information" Name="B1" > > > > > OnClick="ChangeRecord();"> > > > > > > > > > > When I click on the Button, I get Error On Page. > > > > > > > > > > What am I doing wrong. > > > > > > > > > > My colleague entered this earlier, but under JScript. He did not get a > > > > > response as of this time. > > > > > > > > > > Thanks > > > > > > > > > > Granny Leona > > > > > > > > Your script has two errors. One is a typo, the other a substantial > > > > lack of understanding of JScript. > > > > > > > > The typo is that the closing curly bracket on this line should be an > > > > open curly bracket ... > > > > > > > > if (document.FormA.txtPassWordA <> document.FormA.txtPassWordB)} > > > > > > > > The syntax error is on the same line. The not equal operator in > > > > JScript is !==, not <>. This is the same as in C, C++, Java, etc. > > > > > > > > So, try this ... > > > > > > > > <Script Language="JavaScript"> > > > > > > > > function ChangeRecord() > > > > { > > > > var boolValid = true; > > > > if (document.FormA.txtPassWordA !== document.FormA.txtPassWordB) > > > > { > > > > var incomplete = "PassWords Do Not Match, Please Re-Enter"; > > > > alert(incomplete); > > > > boolValid = false; > > > > } > > > > } > > > > > > > > </Script> > > > > > > > > I reformatted the layout a bit to make it more readable, I think. > > > > > > > > BTW, why are you asking this question in a VBScript group? > > > > > > > > Tom Lavedas > > > > *********** > > > > http://there.is.no.more/tglbatch/ > > > > |
| Install flash player (done! ) then java script..where..how?? | Vista General | |||
| Move computer in AD based on DSQUERY script syntax help! | VB Script | |||
| downloading java script to window vista | Vista General | |||
| Example of a script converted to HTML with syntax highlighting | PowerShell | |||
| Time Java script | Vista security | |||
