| | Regular Expression Help Required Hi, I have written a Vbscript which will search for a specific pattern of text in a text file and if there is match found then the script will write that corresponding line to word file. Now i am trying to accomplish the same with excel file as input instead of text file, but i am not able to do so. I think i am doing some mistake in reading the excel file. Can anyone help me with this. Below is my code. Any help is greatly appreciated. Const ForReading = 1 Set objRegEx = CreateObject("VBScript.RegExp") objRegEx.Pattern = "abc|tree" objRegEx.IgnoreCase = True Set objExcel = CreateObject("Excel.Application") objExcel.Visible = true objExcel.DisplayAlerts = FALSE Set objWorkbook = objExcel.Workbooks.Open("Z:\RegEX\Test.xls") intRow = 2 Set objWord = CreateObject("Word.Application") objWord.Visible = True Set objDoc = objWord.Documents.Add() Set objSelection = objWord.Selection Do Until objExcel.Cells(intRow, 1).Value = "" strSearchString = objExcel.Cells(intRow, 1).Value Set colMatches = objRegEx.Execute(strSearchString) If colMatches.Count > 0 Then For Each strMatch in colMatches objSelection.TypeText " " & strSearchString & vbCRLF Next End If Loop |
| | Re: Regular Expression Help Required Have you tried outputting what is found in each cell, just to make sure it's retrieving the expected value? -- Joe Fawcett (MVP - XML) http://joe.fawcett.name "Codeblack" <Codeblack@xxxxxx> wrote in message news:953BFCB1-F771-457C-A269-F26E92E45B70@xxxxxx Quote: > Hi, > > I have written a Vbscript which will search for a specific pattern of text > in a text file and if there is match found then the script will write that > corresponding line to word file. Now i am trying to accomplish the same > with > excel file as input instead of text file, but i am not able to do so. I > think > i am doing some mistake in reading the excel file. Can anyone help me with > this. Below is my code. Any help is greatly appreciated. > > > Const ForReading = 1 > > Set objRegEx = CreateObject("VBScript.RegExp") > objRegEx.Pattern = "abc|tree" > objRegEx.IgnoreCase = True > > Set objExcel = CreateObject("Excel.Application") > objExcel.Visible = true > objExcel.DisplayAlerts = FALSE > Set objWorkbook = objExcel.Workbooks.Open("Z:\RegEX\Test.xls") > intRow = 2 > > Set objWord = CreateObject("Word.Application") > objWord.Visible = True > Set objDoc = objWord.Documents.Add() > Set objSelection = objWord.Selection > > Do Until objExcel.Cells(intRow, 1).Value = "" > strSearchString = objExcel.Cells(intRow, 1).Value > Set colMatches = objRegEx.Execute(strSearchString) > If colMatches.Count > 0 Then > For Each strMatch in colMatches > objSelection.TypeText " " & strSearchString & vbCRLF > Next > End If > Loop |
| | Re: Regular Expression Help Required The other things are that you don't increment the intRows variable and you only open the workbook, you never select a particular worksheet. -- Joe Fawcett (MVP - XML) http://joe.fawcett.name "Codeblack" <Codeblack@xxxxxx> wrote in message news:953BFCB1-F771-457C-A269-F26E92E45B70@xxxxxx Quote: > Hi, > > I have written a Vbscript which will search for a specific pattern of text > in a text file and if there is match found then the script will write that > corresponding line to word file. Now i am trying to accomplish the same > with > excel file as input instead of text file, but i am not able to do so. I > think > i am doing some mistake in reading the excel file. Can anyone help me with > this. Below is my code. Any help is greatly appreciated. > > > Const ForReading = 1 > > Set objRegEx = CreateObject("VBScript.RegExp") > objRegEx.Pattern = "abc|tree" > objRegEx.IgnoreCase = True > > Set objExcel = CreateObject("Excel.Application") > objExcel.Visible = true > objExcel.DisplayAlerts = FALSE > Set objWorkbook = objExcel.Workbooks.Open("Z:\RegEX\Test.xls") > intRow = 2 > > Set objWord = CreateObject("Word.Application") > objWord.Visible = True > Set objDoc = objWord.Documents.Add() > Set objSelection = objWord.Selection > > Do Until objExcel.Cells(intRow, 1).Value = "" > strSearchString = objExcel.Cells(intRow, 1).Value > Set colMatches = objRegEx.Execute(strSearchString) > If colMatches.Count > 0 Then > For Each strMatch in colMatches > objSelection.TypeText " " & strSearchString & vbCRLF > Next > End If > Loop |
| | Re: Regular Expression Help Required Codeblack schrieb: Quote: > Hi, > > I have written a Vbscript which will search for a specific pattern of text > in a text file and if there is match found then the script will write that > corresponding line to word file. Now i am trying to accomplish the same with > excel file as input instead of text file, but i am not able to do so. I think Quote: > i am doing some mistake in reading the excel file. Can anyone help me with > this. Below is my code. Any help is greatly appreciated. > > > Const ForReading = 1 > > Set objRegEx = CreateObject("VBScript.RegExp") > objRegEx.Pattern = "abc|tree" > objRegEx.IgnoreCase = True > > Set objExcel = CreateObject("Excel.Application") > objExcel.Visible = true > objExcel.DisplayAlerts = FALSE > Set objWorkbook = objExcel.Workbooks.Open("Z:\RegEX\Test.xls") > intRow = 2 > > Set objWord = CreateObject("Word.Application") > objWord.Visible = True > Set objDoc = objWord.Documents.Add() > Set objSelection = objWord.Selection > > Do Until objExcel.Cells(intRow, 1).Value = "" > ... strSearchString = objExcel.Cells(intRow, 1).Value > ... Set colMatches = objRegEx.Execute(strSearchString) > ... If colMatches.Count > 0 Then > ...... For Each strMatch in colMatches > ......... objSelection.TypeText " " & strSearchString & vbCRLF > ...... Next > ... End If ... intRow = intRow + 1 missing here Quote: > Loop |
| | Re: Regular Expression Help Required "Codeblack" <Codeblack@xxxxxx> wrote in message news:953BFCB1-F771-457C-A269-F26E92E45B70@xxxxxx Quote: > Hi, > > I have written a Vbscript which will search for a specific pattern of text > in a text file and if there is match found then the script will write that > corresponding line to word file. Now i am trying to accomplish the same > with > excel file as input instead of text file, but i am not able to do so. I > think > i am doing some mistake in reading the excel file. Can anyone help me with > this. Below is my code. Any help is greatly appreciated. > > > Const ForReading = 1 > > Set objRegEx = CreateObject("VBScript.RegExp") > objRegEx.Pattern = "abc|tree" > objRegEx.IgnoreCase = True > > Set objExcel = CreateObject("Excel.Application") > objExcel.Visible = true > objExcel.DisplayAlerts = FALSE > Set objWorkbook = objExcel.Workbooks.Open("Z:\RegEX\Test.xls") > intRow = 2 > > Set objWord = CreateObject("Word.Application") > objWord.Visible = True > Set objDoc = objWord.Documents.Add() > Set objSelection = objWord.Selection > > Do Until objExcel.Cells(intRow, 1).Value = "" > strSearchString = objExcel.Cells(intRow, 1).Value > Set colMatches = objRegEx.Execute(strSearchString) > If colMatches.Count > 0 Then > For Each strMatch in colMatches > objSelection.TypeText " " & strSearchString & vbCRLF > Next > End If > Loop forgot to increment your 'intRow' variable. You might also consider changing your loop from: Do Until objExcel.Cells(intRow, 1).Value = "" [...your code...] Loop To: For intRow = 2 to objExcel.Range("A65536").End(-4162).Row [...your code...] Next Even if you increment your variable, your code will stop at the first blank cell. The above change should resolve this issue. If that was your intention, please disregard this suggestion. |
| | #6 (permalink) |
| | Re: Regular Expression Help Required Thanks everyone for your prompt response. As per your suggestion, i made changes to the script, but now the script dosen't throw any error neither it writes the output to word file. Below is the updated code. Any inputs please. Const ForReading = 1 Set objRegEx = CreateObject("VBScript.RegExp") objRegEx.Pattern = "abc|tree" objRegEx.IgnoreCase = True Set objExcel = CreateObject("Excel.Application") objExcel.Visible = true objExcel.DisplayAlerts = FALSE Set objWorkbook = objExcel.Workbooks.Open("Z:\RegEX\Test.xls") intRow = 1 Set objWord = CreateObject("Word.Application") objWord.Visible = True Set objDoc = objWord.Documents.Add() Set objSelection = objWord.Selection For Each objWorkSheet In objWorkBook.Sheets intRow = introw+1 objWorkSheet.Activate Set objCell = objWorkSheet.Cells(1, "A") strSearchString = objExcel.Cells(intRow, 1).Value Set colMatches = objRegEx.Execute(strSearchString) If colMatches.Count > 0 Then For Each strMatch in colMatches objSelection.TypeText " " & strSearchString & vbCRLF Next End If Next |
| | #7 (permalink) |
| | Re: Regular Expression Help Required Can anyone suggest on this. I am completely lost. Any help on this will be greatly appreciated. |
| | #8 (permalink) |
| | Re: Regular Expression Help Required Can anyone please help me with this. |
| | #9 (permalink) |
| | Re: Regular Expression Help Required "Codeblack" <Codeblack@xxxxxx> wrote in message news:914CB3C4-D5DF-456F-A87E-9292DF9598E5@xxxxxx Quote: > Thanks everyone for your prompt response. As per your suggestion, i made > changes to the script, but now the script dosen't throw any error neither > it > writes the output to word file. Below is the updated code. Any inputs > please. > > > Const ForReading = 1 > > Set objRegEx = CreateObject("VBScript.RegExp") > objRegEx.Pattern = "abc|tree" > objRegEx.IgnoreCase = True > > Set objExcel = CreateObject("Excel.Application") > objExcel.Visible = true > objExcel.DisplayAlerts = FALSE > Set objWorkbook = objExcel.Workbooks.Open("Z:\RegEX\Test.xls") > intRow = 1 > > Set objWord = CreateObject("Word.Application") > objWord.Visible = True > Set objDoc = objWord.Documents.Add() > Set objSelection = objWord.Selection > > > For Each objWorkSheet In objWorkBook.Sheets > intRow = introw+1 > objWorkSheet.Activate > Set objCell = objWorkSheet.Cells(1, "A") > > strSearchString = objExcel.Cells(intRow, 1).Value > Set colMatches = objRegEx.Execute(strSearchString) > If colMatches.Count > 0 Then > For Each strMatch in colMatches > objSelection.TypeText " " & strSearchString & vbCRLF > Next > End If > Next cells / rows. You need another loop. I have some questions. Are you wanting to search only column 'A' in each worksheet in the workbook or search all columns? If a match is found, do you want only the match returned or the entire row? If the entire row is desired, do you want the data delimited? If so, how? In either case, do you want the output to include the location (sheet name / number & row number) the discovery was made at? |
| | #10 (permalink) |
| | Re: Regular Expression Help Required James, Thanks a lot for looking into this. Please find my answers below. I want to search all the columns in the sheet and if a match is found then the script should write the contents of that cell to a word file. The output should contain the Sheet Number, Row Number and the cell value where the match is found. |
| Regular Expression help C# | .NET General | |||
| Books on Regular Expression | PowerShell | |||
| Regular Expression for ../ | .NET General | |||
| Help with a regular expression | VB Script | |||
| regular expression help | VB Script | |||
