| | Please help me for a VB Script requiremnt.... Hi can anybody help me as I am not a scripting guy. I urgently need a script which can perform following tasks 1. Input Box for Source path(dropdown list of folders) and filename need to be copied. 2. Input Box or Dropdown list for destination path. 3. Rename the existing file with filename_current system date. 4. Input Box or dropdownlist to move the renamed file. 5. Copy and paste the new file. 6. Finish Thanks in Advance Virendra Sharma |
| Logon Script Causing Laptops To Hang - Problems in script? | VB Script | |||
| URGENT - Please help me for a VB Script requiremnt.... | VB Script | |||
| problem passing args to script 'There is no script engine for file extenstion' | VB Script | |||
| Script file has 'OS Handle' error when run from script | PowerShell | |||
| Can you drag-n-drop a file on top of a PS script to run the script? | PowerShell | |||
