Vista - URGENT - Please help me for a VB Script requiremnt....
Old 01-20-2009   #1 (permalink)
Virendra Sharma
Hi can anybody help me as I am not a scripting guy.
I urgently need a script which can perform following tasks
1. Input Box for Source path(dropdown list of folders) and filename need to
be copied.
2. Input Box or Dropdown list for destination path.
3. Rename the existing file with filename_current system date.
4. Prompt if the file in use.
4. Input Box or dropdownlist to move the renamed file.
5. Copy and paste the new file.
6. Finish
Thanks in Advance
Virendra Sharma
Old 02-03-2009   #2 (permalink)
Python42
Re: URGENT - Please help me for a VB Script requiremnt....
I'll see what I can do, however, I have a question or two...
Do you have a specific list of source folders? Do you need to allow a
"browse for source folder" functionality for ad-hoc folders?
I presume it would work something like this...
1) user selects a source folder (or browses to pick an ad-hoc folder)
2) user picks one or more files in the selected folder
3) user selects a destination folder (or browses to pick an ad-hoc folder)
4) user clicks on MOVE button to rename and move files to destination folder
How are the files to be renamed? For example
file -> myfile.txt renamed to -> myfile 2009_02_02 14_23_17.txt
or -> myfile 2009_02_02.txt
If the new name already exists, could we just pick a new name such as
myfile 2009_02_02 14_23_17(2).txt
or myfile 2009_02_02(2).txt
Your step 4 says to move the renamed file
Your step 5 says to copy and paste the new file
Which is is going to be - move or copy?
"Virendra Sharma" <VirendraSharma@xxxxxx> wrote in
message news:E33F2C61-D001-4AD6-998B-790DDE3939C0@xxxxxx
> to
> be copied.
> 6. Finish
> Thanks in Advance
> Virendra Sharma
Logon Script Causing Laptops To Hang - Problems in script? VB Script
Please help me for a VB Script requiremnt.... VB Script
problem passing args to script 'There is no script engine for file extenstion' VB Script
Include another script, keep variables in included script? PowerShell
Can you drag-n-drop a file on top of a PS script to run the script? PowerShell
