| | Logon Script Causing Laptops To Hang - Problems in script? Hi, I'm using the following script to map drives, and perform a few functions when users logon to our domain. However, in the past 2 or 3 months it seems that when a laptop is away from the domain, logon takes several minutes, and applications can take up to 2 minutes to start/open. The only way around tis is to disable the wi-fi connection, or pull the cable out of a LAN connection. However, when back in the office, on our network, start up is perfectly fine, and applications open in seconds. I've been advised that this behaviour is probably due to the logon script, somehow hunting for a domain controller to logon, waiting a number of minutes to try and find it, then failing. The only error messages in the event log are: Event Type: Error Event Source: UserInit Event Category: None Event ID: 1000 Date: 02/02/2009 Time: 12:51:30 User: N/A Computer: LAPTOP1 Description: Could not execute the following script \\server1.domain.com\NETLOGON \logon.vbs. The network location cannot be reached. Having watched the network traffic using Ethereal/Wireshark, I can't see anything else that looks obviously wrong. Could someone see if there is something in the logon script that is wrong? Someone suggested adding a section that exits if it can't find the logon server. However, if the event log is saying it can't find the logon script to run, I can't see how this would help!? Any help or suggests would be much appreciated! Ben logon.vbs '******************************************* On Error Resume Next '******************************************* 'Initialize common scripting objects '******************************************* Set objNetwork = CreateObject("WScript.Network") Set objFSO = CreateObject("Scripting.FileSystemObject") Set oShell = CreateObject("Wscript.Shell") Set objPrinter = CreateObject("WScript.Network") Set oSF = oShell.SpecialFolders '******************************************* ' Define Variables and ConstantsobjUser '******************************************* Dim objNetwork, objFSO, objUser, objFlrGrp strUserName = objNetwork.userName strSvrName = "server1.domain.com" strPtr1Name = "ptr01" strPtr2Name = "ptr02" strPtr3Name = "ptr03" strPtr1Path = "\\" & strSvrName & "\" & strPtr1Name strPtr2Path = "\\" & strSvrName & "\" & strPtr2Name strPtr3Path = "\\" & strSvrName & "\" & strPtr3Name strGrpDrv = "G:" strCnsltsDrv = "J:" strAppsDrv = "K:" strLibrDrv = "L:" strMarketDrv = "M:" strInvoiceDrv = "N:" strDictrDrv = "O:" strAcntsDrv = "P:" strHrDrv = "R:" strSaleDrv = "S:" strTrainDrv = "T:" strAcntsShr = "\accounts" strInvoiceShr = "\InvoiceProc" strAppsShr = "\apps" strCnsltsShr = "\consultants" strDictrShr = "\directors" strGrpShr = "\group" strLibrShr = "\library" strHrShr = "\hr" strSaleShr = "\sales" strMarketShr = "\marketing" strTrainShr = "\training" '******************************************* 'Disconnects Drives This assures everyone has the same drive mappings. '******************************************* Dim objDrive objDrives = array ("G:","J:","K:","L:","M:","N:","P:","P:","R:","S:","T:") For Each oDrive in objDrives IF objFSO.DriveExists(oDrive) = True Then objNetwork.RemoveNetworkDrive oDrive, true End IF Next '******************************************* 'Audit's Laptop Software Once Every Seven Days '******************************************* oPath = "\\server1.domain.com\Audits\" oComputer = oPath & objNetwork.ComputerName & "-audit.txt" If objFSO.FileExists(oComputer) = True Then Set ofile = objFSO.GetFile(oComputer)'get the file fDate = ofile.DateLastModified 'file date tdate = Now 'todays date dDate = DateDiff("d", fdate, tdate) 'calculate the number of days difference if dDate > 7 then Call Audit else Set ofile = Nothing end if else Call Audit End if Function Audit strCommand="%comspec% /c" & oPath & "psinfo.exe -s * >" & oPath & "%ComputerName%-audit.txt" intWindowStyle=0 oShell.Run strCommand, intWindowStyle end Function '******************************************* ' Map global Drives & Drives based on Group Membership '******************************************* 'Group drive strPath = "\\" & strSvrName & strGrpShr objNetwork.MapNetworkDrive strGrpDrv, strPath 'Training strPath = "\\" & strSvrName & strTrainShr objNetwork.MapNetworkDrive strTrainDrv, strPath 'Library strPath = "\\" & strSvrName & strLibrShr objNetwork.MapNetworkDrive strLibrDrv, strPath if IsMember("Accountants") then strPath = "\\" & strSvrName & strAcntsShr objNetwork.MapNetworkDrive strAcntsDrv, strPath end if if IsMember("Consultants") then strPath = "\\" & strSvrName & strCnsltsShr objNetwork.MapNetworkDrive strCnsltsDrv, strPath end if if IsMember("Admins") then strPath = "\\" & strSvrName & strItShr objNetwork.MapNetworkDrive strItDrv, strPath end if if IsMember("Directors") then strPath = "\\" & strSvrName & strDictrShr objNetwork.MapNetworkDrive strDictrDrv, strPath end if if IsMember("HumanResources") then strPath = "\\" & strSvrName & strHrShr objNetwork.MapNetworkDrive strHrDrv, strPath end if if IsMember("SalesGroup") then strPath = "\\" & strSvrName & strSaleShr objNetwork.MapNetworkDrive strSaleDrv, strPath strPath = "\\" & strSvrName & strMarketShr objNetwork.MapNetworkDrive strMarketDrv, strPath strPath = "\\" & strSvrName & strInvoiceShr objNetwork.MapNetworkDrive strInvoiceDrv, strPath end if '******************************************* ' This section sets default printers depending on location '******************************************* if IsMember("PTR01 Users") then objNetwork.SetDefaultPrinter strPtr1Path elseif IsMember("PTR02 Users") then objNetwork.SetDefaultPrinter strPtr2Path elseif IsMember("PTR03 Users") then objNetwork.SetDefaultPrinter strPtr3Path end if '******************************************* ' This Function Gets Domain Group Membership '******************************************* Function IsMember(strGroup) Dim objNetwork, objSysInfo, strUserDN, objUser Set objSysInfo = CreateObject("ADSystemInfo") strUserDN = objSysInfo.userName Set objUser = GetObject("LDAP://" & strUserDN) Dim objGroup If IsEmpty(objGroupList) Then Set objGroupList = CreateObject("Scripting.Dictionary") objGroupList.CompareMode = vbTextCompare For Each objGroup In objUser.Groups objGroupList(objGroup.sAMAccountName) = True Next End If IsMember = objGroupList.Exists(strGroup) End Function Set objGroupList = Nothing '******************************************* '*Create Outlook signature if it doesn't exist '******************************************* oSigPath = "C:\Documents and Settings\" & strUserName & "\Application Data\Microsoft\Signatures\AD Signature.rtf" If objFSO.FileExists(oSigPath) = True Then else oShell.Run "\\server1.domain.com\NETLOGON\ADSignatureSetup.vbs" End if Set objNetwork = Nothing Set objFSO = Nothing Set oShell = Nothing Set objPrinter = Nothing Set objUser = Nothing Set objSysInfo = Nothing Set colProcess = Nothing Set objWMIService = Nothing ' Exit Script WSCript.Quit |
| | Re: Logon Script Causing Laptops To Hang - Problems in script? "Ben" <bjblackmore@xxxxxx> wrote in message news:8c7e5928-b141-4abb-b722-e32157efe408@xxxxxx Quote: > Hi, > > I'm using the following script to map drives, and perform a few > functions when users logon to our domain. However, in the past 2 or 3 > months it seems that when a laptop is away from the domain, logon > takes several minutes, and applications can take up to 2 minutes to > start/open. The only way around tis is to disable the wi-fi > connection, or pull the cable out of a LAN connection. However, when > back in the office, on our network, start up is perfectly fine, and > applications open in seconds. > > I've been advised that this behaviour is probably due to the logon > script, somehow hunting for a domain controller to logon, waiting a > number of minutes to try and find it, then failing. The only error > messages in the event log are: > > Event Type: Error > Event Source: UserInit > Event Category: None > Event ID: 1000 > Date: 02/02/2009 > Time: 12:51:30 > User: N/A > Computer: LAPTOP1 > Description: > Could not execute the following script \\server1.domain.com\NETLOGON > \logon.vbs. The network location cannot be reached. > > Having watched the network traffic using Ethereal/Wireshark, I can't > see anything else that looks obviously wrong. > > Could someone see if there is something in the logon script that is > wrong? Someone suggested adding a section that exits if it can't find > the logon server. However, if the event log is saying it can't find > the logon script to run, I can't see how this would help!? > > Any help or suggests would be much appreciated! > > Ben if the domain controller is inaccessible. |
| | Re: Logon Script Causing Laptops To Hang - Problems in script? On 2 Feb, 17:01, "Pegasus \(MVP\)" <I....@xxxxxx> wrote: Quote: > "Ben" <bjblackm...@xxxxxx> wrote in message > > news:8c7e5928-b141-4abb-b722-e32157efe408@xxxxxx > > > > > Quote: > > Hi, Quote: > > I'm using the following script to map drives, and perform a few > > functions when users logon to our domain. However, in the past 2 or 3 > > months it seems that when a laptop is away from the domain, logon > > takes several minutes, and applications can take up to 2 minutes to > > start/open. The only way around tis is to disable the wi-fi > > connection, or pull the cable out of a LAN connection. However, when > > back in the office, on our network, start up is perfectly fine, and > > applications open in seconds. Quote: > > I've been advised that this behaviour is probably due to the logon > > script, somehow hunting for a domain controller to logon, waiting a > > number of minutes to try and find it, then failing. The only error > > messages in the event log are: Quote: > > Event Type: Error > > Event Source: UserInit > > Event Category: None > > Event ID: 1000 > > Date: 02/02/2009 > > Time: 12:51:30 > > User: N/A > > Computer: LAPTOP1 > > Description: > > Could not execute the following script \\server1.domain.com\NETLOGON > > \logon.vbs. The network location cannot be reached. Quote: > > Having watched the network traffic using Ethereal/Wireshark, I can't > > see anything else that looks obviously wrong. Quote: > > Could someone see if there is something in the logon script that is > > wrong? Someone suggested adding a section that exits if it can't find > > the logon server. However, if the event log is saying it can't find > > the logon script to run, I can't see how this would help!? Quote: > > Any help or suggests would be much appreciated! Quote: > > Ben > I would insert an instruction right at the beginning of the script to exit > if the domain controller is inaccessible.- Hide quoted text - > > - Show quoted text - Would the following code work? Set oRootDSE = GetObject("LDAP://RootDSE") strDNC = oRootDSE.get("DefaultNamingContext") If (Err.Number <> 0) Then WScript.Quit End If |
| | Re: Logon Script Causing Laptops To Hang - Problems in script? "Ben" <bjblackmore@xxxxxx> wrote in message news:935b1e32-784a-4474-8605-da86d34eaa9f@xxxxxx Quote: > On 2 Feb, 17:01, "Pegasus \(MVP\)" <I....@xxxxxx> wrote: Quote: >> "Ben" <bjblackm...@xxxxxx> wrote in message >> >> news:8c7e5928-b141-4abb-b722-e32157efe408@xxxxxx >> >> >> >> >> Quote: >> > Hi, Quote: >> > I'm using the following script to map drives, and perform a few >> > functions when users logon to our domain. However, in the past 2 or 3 >> > months it seems that when a laptop is away from the domain, logon >> > takes several minutes, and applications can take up to 2 minutes to >> > start/open. The only way around tis is to disable the wi-fi >> > connection, or pull the cable out of a LAN connection. However, when >> > back in the office, on our network, start up is perfectly fine, and >> > applications open in seconds. Quote: >> > I've been advised that this behaviour is probably due to the logon >> > script, somehow hunting for a domain controller to logon, waiting a >> > number of minutes to try and find it, then failing. The only error >> > messages in the event log are: Quote: >> > Event Type: Error >> > Event Source: UserInit >> > Event Category: None >> > Event ID: 1000 >> > Date: 02/02/2009 >> > Time: 12:51:30 >> > User: N/A >> > Computer: LAPTOP1 >> > Description: >> > Could not execute the following script \\server1.domain.com\NETLOGON >> > \logon.vbs. The network location cannot be reached. Quote: >> > Having watched the network traffic using Ethereal/Wireshark, I can't >> > see anything else that looks obviously wrong. Quote: >> > Could someone see if there is something in the logon script that is >> > wrong? Someone suggested adding a section that exits if it can't find >> > the logon server. However, if the event log is saying it can't find >> > the logon script to run, I can't see how this would help!? Quote: >> > Any help or suggests would be much appreciated! Quote: >> > Ben >> I would insert an instruction right at the beginning of the script to >> exit >> if the domain controller is inaccessible.- Hide quoted text - >> >> - Show quoted text - > Thanks for the reply. > > Would the following code work? > > Set oRootDSE = GetObject("LDAP://RootDSE") > strDNC = oRootDSE.get("DefaultNamingContext") > If (Err.Number <> 0) Then > WScript.Quit > End If that will provide a clue. It could be a specific computer, like Server1, cannot be contacted, rather than a DC. After a quick glance the only part I see that requires a DC is where you bind to "ADSystemInfo". You might use error trapping in the function IsMember method. However, the script will still fail if Server1 is not available. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| | Re: Logon Script Causing Laptops To Hang - Problems in script? On 2 Feb, 18:44, "Richard Mueller [MVP]" <rlmueller- nos...@xxxxxx> wrote: Quote: > "Ben" <bjblackm...@xxxxxx> wrote in message > > news:935b1e32-784a-4474-8605-da86d34eaa9f@xxxxxx > > > > > Quote: > > On 2 Feb, 17:01, "Pegasus \(MVP\)" <I....@xxxxxx> wrote: Quote: > >> "Ben" <bjblackm...@xxxxxx> wrote in message Quote: Quote: > >>news:8c7e5928-b141-4abb-b722-e32157efe408@xxxxxx Quote: Quote: > >> > Hi, Quote: Quote: > >> > I'm using the following script to map drives, and perform a few > >> > functions when users logon to our domain. However, in the past 2 or 3 > >> > months it seems that when a laptop is away from the domain, logon > >> > takes several minutes, and applications can take up to 2 minutes to > >> > start/open. The only way around tis is to disable the wi-fi > >> > connection, or pull the cable out of a LAN connection. However, when > >> > back in the office, on our network, start up is perfectly fine, and > >> > applications open in seconds. Quote: Quote: > >> > I've been advised that this behaviour is probably due to the logon > >> > script, somehow hunting for a domain controller to logon, waiting a > >> > number of minutes to try and find it, then failing. The only error > >> > messages in the event log are: Quote: Quote: > >> > Event Type: Error > >> > Event Source: UserInit > >> > Event Category: None > >> > Event ID: 1000 > >> > Date: 02/02/2009 > >> > Time: 12:51:30 > >> > User: N/A > >> > Computer: LAPTOP1 > >> > Description: > >> > Could not execute the following script \\server1.domain.com\NETLOGON > >> > \logon.vbs. The network location cannot be reached. Quote: Quote: > >> > Having watched the network traffic using Ethereal/Wireshark, I can't > >> > see anything else that looks obviously wrong. Quote: Quote: > >> > Could someone see if there is something in the logon script that is > >> > wrong? Someone suggested adding a section that exits if it can't find > >> > the logon server. However, if the event log is saying it can't find > >> > the logon script to run, I can't see how this would help!? Quote: Quote: > >> > Any help or suggests would be much appreciated! Quote: Quote: > >> > Ben Quote: Quote: > >> I would insert an instruction right at the beginning of the script to > >> exit > >> if the domain controller is inaccessible.- Hide quoted text - Quote: Quote: > >> - Show quoted text - Quote: > > Thanks for the reply. Quote: > > Would the following code work? Quote: > > Set oRootDSE = GetObject("LDAP://RootDSE") > > strDNC = oRootDSE.get("DefaultNamingContext") > > If (Err.Number <> 0) Then > > WScript.Quit > > End If > Yes. Also, I would remove "On Error Resume Next" so you get an error message > that will provide a clue. It could be a specific computer, like Server1, > cannot be contacted, rather than a DC. After a quick glance the only part I > see that requires a DC is where you bind to "ADSystemInfo". You might use > error trapping in the function IsMember method. However, the script will > still fail if Server1 is not available. > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab -http://www.rlmueller.net > --- Hide quoted text - > > - Show quoted text - One last question - I'm just wondering how all this works? The error in the event logs says "Could not execute the following script \\server1.domain.com\NETLOGON\logon.vbs. The network location cannot be reached." Does this mean it can't find the script to execute, in which case, will adding the above code make any difference? Or is the script cached (its a logon script in a group policy, so possibly), and the error means it can't find the network while running the script? Thanks again Ben |
| | #6 (permalink) |
| | Re: Logon Script Causing Laptops To Hang - Problems in script? "Ben" <bjblackmore@xxxxxx> wrote in message news:16fe10da-8ab8-4f57-a827-e0f37e5e296d@xxxxxx Quote: > On 2 Feb, 18:44, "Richard Mueller [MVP]" <rlmueller- > nos...@xxxxxx> wrote: Quote: >> "Ben" <bjblackm...@xxxxxx> wrote in message >> >> news:935b1e32-784a-4474-8605-da86d34eaa9f@xxxxxx >> >> >> >> >> Quote: >> > On 2 Feb, 17:01, "Pegasus \(MVP\)" <I....@xxxxxx> wrote: >> >> "Ben" <bjblackm...@xxxxxx> wrote in message Quote: >> >>news:8c7e5928-b141-4abb-b722-e32157efe408@xxxxxx Quote: >> >> > Hi, Quote: >> >> > I'm using the following script to map drives, and perform a few >> >> > functions when users logon to our domain. However, in the past 2 or >> >> > 3 >> >> > months it seems that when a laptop is away from the domain, logon >> >> > takes several minutes, and applications can take up to 2 minutes to >> >> > start/open. The only way around tis is to disable the wi-fi >> >> > connection, or pull the cable out of a LAN connection. However, when >> >> > back in the office, on our network, start up is perfectly fine, and >> >> > applications open in seconds. Quote: >> >> > I've been advised that this behaviour is probably due to the logon >> >> > script, somehow hunting for a domain controller to logon, waiting a >> >> > number of minutes to try and find it, then failing. The only error >> >> > messages in the event log are: Quote: >> >> > Event Type: Error >> >> > Event Source: UserInit >> >> > Event Category: None >> >> > Event ID: 1000 >> >> > Date: 02/02/2009 >> >> > Time: 12:51:30 >> >> > User: N/A >> >> > Computer: LAPTOP1 >> >> > Description: >> >> > Could not execute the following script \\server1.domain.com\NETLOGON >> >> > \logon.vbs. The network location cannot be reached. Quote: >> >> > Having watched the network traffic using Ethereal/Wireshark, I can't >> >> > see anything else that looks obviously wrong. Quote: >> >> > Could someone see if there is something in the logon script that is >> >> > wrong? Someone suggested adding a section that exits if it can't >> >> > find >> >> > the logon server. However, if the event log is saying it can't find >> >> > the logon script to run, I can't see how this would help!? Quote: >> >> > Any help or suggests would be much appreciated! Quote: >> >> > Ben Quote: >> >> I would insert an instruction right at the beginning of the script to >> >> exit >> >> if the domain controller is inaccessible.- Hide quoted text - Quote: >> >> - Show quoted text - Quote: >> > Thanks for the reply. Quote: >> > Would the following code work? Quote: >> > Set oRootDSE = GetObject("LDAP://RootDSE") >> > strDNC = oRootDSE.get("DefaultNamingContext") >> > If (Err.Number <> 0) Then >> > WScript.Quit >> > End If >> Yes. Also, I would remove "On Error Resume Next" so you get an error >> message >> that will provide a clue. It could be a specific computer, like Server1, >> cannot be contacted, rather than a DC. After a quick glance the only part >> I >> see that requires a DC is where you bind to "ADSystemInfo". You might use >> error trapping in the function IsMember method. However, the script will >> still fail if Server1 is not available. >> >> -- >> Richard Mueller >> MVP Directory Services >> Hilltop Lab -http://www.rlmueller.net >> --- Hide quoted text - >> >> - Show quoted text - > Thanks RIchard. > > One last question - I'm just wondering how all this works? > > The error in the event logs says "Could not execute the following > script \\server1.domain.com\NETLOGON\logon.vbs. The network location > cannot be reached." Does this mean it can't find the script to > execute, in which case, will adding the above code make any > difference? Or is the script cached (its a logon script in a group > policy, so possibly), and the error means it can't find the network > while running the script? > > Thanks again > > Ben You say the logon script is specified in a group policy, but if so that is the wrong location. That is the location for logon scripts specified on the Profile tab of ADUC. Best would be to copy the logon script file, logon.vbs, to the clipboard, then navigate in Group Policy, open the "Logon" setting in the Group Policy editor, press the "Show Files..." button, and paste the file in the dialog. Then you can select the file as the logon script. This ensure the file is in the correct location. See this link for more on configuring logon scripts: http://www.rlmueller.net/LogonScriptFAQ.htm -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| Logon script | PowerShell | |||
| Logon Script | VB Script | |||
| Script for every logon in the last 90 days | VB Script | |||
| CDO script causes Exchange Server to hang | VB Script | |||
| Logon Script | Vista General | |||
