Vista - Logon Script under Vista running painfully slow
Old 02-02-2009   #1 (permalink)
The Evil Overlord
I have written a logon script. One of the first things it does is check
Active Directory for a user's group membership. The code is below:
Function ReturnGroupMembership(strUserName)
'Output is a recordset
Dim objConnection
Dim objCommand
Dim objRecordSet
Log_Event vbTab & "Creating ADODB Connection Object", boolLog_Screen,
boolLog_File
Set objConnection = CreateObject("ADODB.Connection")
Log_Event vbTab & "Creating ADODB Command Object", boolLog_Screen,
boolLog_File
Set objCommand = CreateObject("ADODB.Command")
Log_Event vbTab & "Setting Connection Properties", boolLog_Screen,
boolLog_File
objConnection.Open "Provider=ADsDSOObject;"
Log_Event vbTab & "Setting Command Properties", boolLog_Screen,
boolLog_File
objCommand.ActiveConnection = objConnection
objCommand.Properties("Sort On") = "sAMAccountName"
objCommand.CommandText =
"<LDAP://dc=domain,dc=com>;(&(objectCategory=user)(sAMAccountName=" &
strUserName &
")(objectCategory=person)(!(objectClass=Contact)));memberOf;subtree"
Log_Event vbTab & "Executing Search", boolLog_Screen, boolLog_File
Set objRecordSet = objCommand.Execute
Log_Event vbTab & "Returning Search Results as a Recordset",
Set ReturnGroupMembership = objRecordSet
End Function
This code generates log file entries that look like this:
2/2/2009 7:29:04 AM Getting User's Group Membership
2/2/2009 7:29:04 AM * Creating ADODB Connection Object
2/2/2009 7:29:05 AM * Creating ADODB Command Object
2/2/2009 7:29:05 AM * Setting Connection Properties
2/2/2009 7:29:05 AM * Setting Command Properties
2/2/2009 7:29:05 AM * Executing Search
2/2/2009 7:43:17 AM * Returning Search Results as a Recordset
You can see from the last two lines of the output (above) that it took 14
minutes for the LDAP query to return results. I'm at a loss to explain this.
We have two Domain Controllers. The replication between the DCs is healthy.
There are no time differences between the DCs and the workstations. Our
windows XP clients do not display this behavior, only Vista. What should I
look at to figure out why this problem exists?
Thank you for your time and assistance.
Old 02-04-2009   #2 (permalink)
Al Dunbar
Re: Logon Script under Vista running painfully slow
"The Evil Overlord" <TheEvilOverlord@xxxxxx> wrote in
message news:7C86A42C-3764-4B0E-987A-647680610B7A@xxxxxx
> Dim objConnection
> Dim objCommand
> Dim objRecordSet
> boolLog_File
> boolLog_File
> boolLog_File
> boolLog_File
> strUserName &
> End Function
> this.
> healthy.
> I
It might be more efficient to query or test the user's membership in those
groups you want to test his/her membership in as and where required rather
than collecting his/her full membership in advance, and qureying or testing
that instead. Richard Mueller has pretty much said all that need be said
about this here:
http://www.rlmueller.net/freecode1.htm
/Al
Old 02-06-2009   #3 (permalink)
Richard Mueller [MVP]
> Dim objConnection
> Dim objCommand
> Dim objRecordSet
> boolLog_File
> boolLog_File
> boolLog_File
> boolLog_File
> strUserName &
> End Function
> this.
> healthy.
> I
There is no need to sort on sAMAccountName. You don't even return that
attribute. Your filter is too complex. Since sAMAccountName must be unique
in the domain, regardless of object class, you might as well use:
objCommand.CommandText = "<LDAP://dc=domain,dc=com>;" _
& "(sAMAccountName=" & strUserName & ");" _
& "memberOf;subtree"
I cannot explain why performance would be slower on Vista, but you do not
specify parameters that could improve efficiency. I always use:
adoCommand.Properties("Page Size") = 100
adoCommand.Properties("Timeout") = 30
adoCommand.Properties("Cache Results") = False
Now ADO is generally very efficient, but in this case you are only
retrieving the information for one user, and the current user at that.
Rather than searching AD, just bind to the current user. The ADSystemInfo
object providers the Distinguished Name. Then you can retrieve the memberOf
attribute directly. In any case, the code should account for the three
possible situations: there are no DN's in the multi-valued attribute, there
is one DN, or there is more than one DN. For example:
' Bind to current user object.
Set objSysInfo = CreateObject("ADSystemInfo")
strUserDN = objSysInfo.UserName
Set objUser = GetObject("LDAP://" & strUserDN)
' Retrieve direct group memberships.
arrGroups = objUser.memberOf
If IsNull(arrGroups) Then
' There are no group memberships.
strDisplay = "<None>"
ElseIf (TypeName(arrGroups) = "String") Then
' There is one group membership
strDisplay = arrGroups
Else
strDisplay = ""
For Each strGroup In arrGroups
If (strDisplay = "") Then
strDisplay = strGroup
Else
strDisplay = strDisplay & "," & strGroup
End If
Next
End If
Wscript.Echo "Groups: " & strDisplay
Finally, if the ultimate aim is to check group membership (rather than just
displaying it), perhaps it makes more sense to bind to each group you want
to check and use the IsMember method of the group object. In brief:
' Bind to a group to check.
Set objGroup = GetObject("LDAP://cn=Sales,ou=West,dc=MyDomain,dc=com")
' Check if the current user is a member of this group.
If (objGroup.IsMember(objUser.AdsPath) = True) Then
' Do something.
End If
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
Painfully slow access to files in Vista Public folder Vista networking & sharing
Logon script not running? Vista General
Painfully slow Windows Vista Startup after upgrade from XPP (Help Vista General
PAINFULLY SLOW Windows Mail in Vista Vista mail
SLOW...good grief, this thing is painfully slow Vista performance & maintenance
