Vista - copy and rename into same dir
Old 02-03-2009   #1 (permalink)
rodchar
hey all,
is there an easy way to copy each file in my directory and paste into the
same diretory but with a number 1 appended to the filename?
dir1 before
fileA
fileB
dir2 after script
fileA
fileA1
fileB
fileB1
thanks,
rodchar
Old 02-03-2009   #2 (permalink)
Dirk Stegemann
Re: copy and rename into same dir
Hi rodchar,
hope this one helps you a little bit...
--Start --
Set oFSO = CreateObject("Scripting.FileSystemObject")
Set oFolder = oFSO.GetFolder(".")
ReDim aFile(500)
i = 0
For Each oFile In oFolder.Files
aFile(i) = oFile.Name
i= i+1
Next
ReDim Preserve aFile(i -1)
For i = LBound (aFile) To UBound (aFile)
If aFile(i) <> "" then
sFilename = Left(aFile(i), InStr(aFile(i), ".") -1)
sEndung = Mid(aFile(i), InStr(aFile(i), "."), _
Len(aFile(i))- InStr(aFile(i), ".")+1)
sFilename = sFilename & "1" & sEndung
If MsgBox("File """ & aFile(i) & """ will be " _
& "renamed To """ & sFilename & """" , _
1, "OK") <> 1 _
Then WScript.Quit
If Not oFSO.Fileexists(sFilename) Then
' oFSO.CopyFile aFile(i), sFilename
End If
End If
Next
-- End --
The script looks in the directory where it resides and copies all File to the same folder...
Try it first.
If it satisfies your needs the only things you have to do are the following..
Delete this code
1, "OK") <> 1 _
Then WScript.Quit
This is for the messagebox.
And uncomment this one
regards
Dirk
Old 02-05-2009   #3 (permalink)
rodchar
thanks for the help,
rod.
"Dirk Stegemann" wrote:
Quote:
> Hi rodchar,
> --Start --
> ReDim aFile(500)
> i = 0
> i= i+1
> Next
> 1, "OK") <> 1 _
> Then WScript.Quit
> End If
> End If
> Next
> -- End --
> Try it first.
> Delete this code
> 1, "OK") <> 1 _
> Then WScript.Quit
> regards
> Dirk
Copy/Move file and rename if destination exist PowerShell
In Vista Home Premium - Can not copy, move, rename or delete a fil Vista file management
Can the copy-item cmdlet be used to copy public folders to C: ? PowerShell
Rename errorin Vista - multiple file rename Vista file management
copy-item changing files attributes on network copy failures PowerShell
